CCA va Reserve Capacity
by Gebo - 12/13/19 04:51 PM
Key fob 3v
by Duffyjr - 12/13/19 04:47 PM
car fax Diy uploads
by WhyMe - 12/13/19 04:43 PM
Jeep 4.0 - 6400MI - 22k on XG8A(Fram Ultra) - Particle Count
by thescreensavers - 12/13/19 04:34 PM
New M340i - Performance Center Delivery
by gofast182 - 12/13/19 02:47 PM
M1 EP 5w-20 burning off in focus
by volk06 - 12/13/19 02:44 PM
Book Rates vs Reality
by madRiver - 12/13/19 02:35 PM
Cheap diesel at one station
by sloinker - 12/13/19 02:18 PM
2006 Ford Fusion 3.0L - cold start issue
by DriveHard - 12/13/19 02:15 PM
BMW N52 low annual miles question +
by GJM120 - 12/13/19 02:10 PM
Wix response to filter efficiency
by mpgo4th - 12/13/19 02:03 PM
Ford warranty and DIY OCI?
by buck91 - 12/13/19 01:27 PM
Corvette C8 Sold Out, Speculating Resale
by dareo - 12/13/19 01:02 PM
1st Electric Aircraft for Commerical Flight!
by paoester - 12/13/19 12:36 PM
Calling retired detailer Rick from Texas
by Vikas - 12/13/19 11:49 AM
Why buy OE filter?
by dogememe - 12/13/19 11:16 AM
Another Massive Airbag Recall Coming?
by SubLGT - 12/13/19 11:13 AM
puppykat33, fatts, mb20music, Jaglenn, kalima
70117 Registered Users
97 registered members (2strokeNorthstar, 77GrandPrix, AC1DD, 2dogs, Aichiguy, AlaskaMike, 5 invisible), 2,057 guests, and 25 spiders.
Topics298,768
Posts5,140,736
Members70,117
Most Online3,589
Nov 2nd, 2019
2018 Accord 2.0T Touring Factory Fill #4779445 06/06/18 05:27 PM
B
Brolly Offline OP
B
Filled back up Castrol Edge Extended 0w-20 Honda filter
1999 Toyota Camry CE 2.2L
PPHM or PP or PPU
5w-30
226,344
10spd
0w-20 Castrol Edge Honda Filter
Re: 2018 Accord 2.0T Touring Factory Fill [Re: Brolly] #4779452 06/06/18 05:35 PM
A
ARB1977 Offline
A
Holy moly batman.
2015 Tacoma 4.0L 60K (as of 02/23/18)
AMSOIL SS 0W30 / Toyota filter
2018 CRV 1.5L (as of 05/11/18)
Factory fill / Honda filter
Re: 2018 Accord 2.0T Touring Factory Fill [Re: ARB1977] #4779461 06/06/18 05:42 PM
L
Leo99 Online Content
Online Content
L
Originally Posted By: ARB1977
Holy moly batman.
All down the drain, now.
Without data you're just another person with an opinion. W. E. Deming
2003 Corolla 250,000 miles (RIP)
2004 Corolla 125,000 miles
2004 Rav4 392,000 miles
2015 Camry 90,000 miles
Re: 2018 Accord 2.0T Touring Factory Fill [Re: ARB1977] #4779490 06/06/18 06:15 PM
Danh Offline
Holy moly batman.
Typical Honda factory fill. Molybdenum is presumably from assembly lubes.
UOA looks good, but viscosity suggests considerable fuel dilution despite Blackstone’s assertion to the contrary.
Re: 2018 Accord 2.0T Touring Factory Fill [Re: Brolly] #4779492 06/06/18 06:16 PM
O
oil_film_movies Offline
O
Probably should have high moly in your Honda for a few thousand miles more. Castrol Edge doesn't have the high moly.
mightymousetech, a Honda technician, last year said "I am a dealer tech (20 years with Acura/Honda) every couple years we get another service bulletin from Engineering stating that doing the first oil change early can damage the engine, and we are NOT to change the factory fill early. The factory fill oil is not the issue, it is the high moly assembly lube used they want retained in the oil. Doing the first oil change early can cause hot spots to form in the engine."
So if the issue is go with high moly in Honda new engines for a few thousand miles, then go with Zepro 0w20.
https://www.bobistheoilguy.com/forums/ub...lis#Post4768630
or go and get Mazda dealership "Mazda Genuine Motor Oil" which is the same stuff really.
(Note: There are 2 varieties of Zepro 0w20, and both have "high" moly, its just that one has insanely high moly, so either will work fine here.)
If you don't want to go thru the hassle of changing your Castrol out (understandable), then just put in a half-bottle of LiquiMoly Ceratec (napa autoparts; amazon), and that will raise the moly level safely.
Re: 2018 Accord 2.0T Touring Factory Fill [Re: Brolly] #4779500 06/06/18 06:20 PM
F
fdcg27 Offline
F
Do you think that it might have been a good idea to have left this high moly brew in for maybe double the miles, as Honda used to recommend in the earlier Accords?
Fuel dilution looks to be negligible, which means that it'll be 3X negligible on a normal 15% MM IOLM change.
Maybe the whole fuel dilution thing has been more hype than reality?
Anyway, this FF UOA looks good.
How do you like the car overall?
Have you owned earlier generation Accords?
I ask because we've had a number of them over a few generations and my Gen 8 is less satisfactory in ride compliance, handling and tracking than previous generation Accords we've had.
18 Accord Hybrid 20K HGMO 0W-20
17 Forester 30K VME 0W-20
12 Accord LX 115K SSO 0W-20
09 Forester 119K M1HM 5W-30
96 Accord LX 104K T5 10W-30
95 318i
Re: 2018 Accord 2.0T Touring Factory Fill [Re: Brolly] #4779504 06/06/18 06:23 PM
R
Ram02 Offline
R
3k should be enough for the moly to settle in the engine . You should be fine
2013 Malibu 2LT M1 5w30
2013 Accord Sport M1 AP 0w20
Re: 2018 Accord 2.0T Touring Factory Fill [Re: oil_film_movies] #4779560 06/06/18 07:09 PM
B
Brolly Offline OP
B
Thanks for the info! I probably will add some in till I get to the next change.
PPHM or PP or PPU
5w-30
226,344
10spd
Re: 2018 Accord 2.0T Touring Factory Fill [Re: oil_film_movies] #4779563 06/06/18 07:10 PM
Z
zeng Offline
Z
+1
Re: 2018 Accord 2.0T Touring Factory Fill [Re: fdcg27] #4779579 06/06/18 07:26 PM
B
Brolly Offline OP
B
Probably would have been a good idea to keep the high moly in will look to possibly add some moly in.
I had a 2008 Accord Ex 2.4 that I bought brand new. Quality is a huge step up with this 10th Gen. the 2008 Brakes were a problem with in the first 5k the pads where shot. They replaced 2-3 times I believe. Heard that the pads were made incorrectly. I got tired of dealing with it so I put some NAPA Ceramic pads and new rotors. Cured the problem. Then there was a front suspension issue that took 6 months worth of time in the shop to figure it out over 2yrs. Also had a oil leak that showed up forgot where it was but that was fixed. Before I gave it to my BIL I had Pirelli CINTURATO P7™ ALL SEASON PLUS which made the ride sooo much better. I still love the car and it will come back to me after he is done with it. I do like this one it’s a different ride and interior are much nicer in this one. The transmission is smooth the cabin is quiet. Infotainment is very well done. Sure there have been a couple resets on the infotainment but that does doesn’t bother me.
PPHM or PP or PPU
5w-30
226,344
10spd
Re: 2018 Accord 2.0T Touring Factory Fill [Re: fdcg27] #4779586 06/06/18 07:29 PM
Danh Offline
6.28 cSt @ 100C and you believe fuel dilution is negligible? This is Blackstone. Had an almost identical Blackstone report a few years ago; subsequent OAI UOA had very similar viscosity but fuel dilution > 5%.
Re: 2018 Accord 2.0T Touring Factory Fill [Re: Brolly] #4779593 06/06/18 07:33 PM
B
Brolly Offline OP
B
I took 2 samples. 1 went to Blackstone and now I need to send the other somewhere else. Napa maybe?
PPHM or PP or PPU
5w-30
226,344
10spd
Re: 2018 Accord 2.0T Touring Factory Fill [Re: Brolly] #4779596 06/06/18 07:35 PM
PimTac Offline
Does Ceratec contain moly? I thought it didn’t. LM does make a moly additive.
There will be residual moly in the engine to add to the new oil so no need to worry.
2017 Mazda CX5
Havoline Pro DS 0w20
Roki OEM filter.
Re: 2018 Accord 2.0T Touring Factory Fill [Re: Brolly] #4779602 06/06/18 07:42 PM
Danh Offline
I’d try Polaris/Oil Analyzers, Inc. They use gas chromotography to determine fuel dilution and are really nice folks to deal with. If you get a second UOA please post it as well.
Re: 2018 Accord 2.0T Touring Factory Fill [Re: Brolly] #4779759 06/06/18 11:30 PM
Marco620 Offline
Couldnt he add a bit of redline 0w20 or Lubegard Biotech to boost the moly?
15' Civic 1.8 i-vtec 294000 mi QSUD 0w20 & LG Biotech, BP CVT Fluid,GUMOUT W/ PEA
Doberman Whisperer!
Doberman,SIG SAUER & SONY Aficionado
