Bent Jack Stand Ratchet Bar
by The Critic - 05/28/20 01:44 AM
Can a 2005 Volvo go 300K Miles easily?
by VolvoZ - 05/27/20 11:17 PM
Cam specs for '62 Corvette Fulie
by JeffKeryk - 05/27/20 11:06 PM
Grub hub
by Chris142 - 05/27/20 10:52 PM
Fiat 500e In the Stable
by Scout1 - 05/27/20 10:41 PM
Windows 10 2004 (May 2020 Update) is out
by KeithS_NW_Ohio - 05/27/20 08:56 PM
Harley Davidson Lithium LiFe 6Ah Battery 66000174
by DuckRyder - 05/27/20 07:29 PM
Belron Toolbox with collapsible cart. One neat setup
by 10WSmuckers - 05/27/20 07:16 PM
[Cut Open] Mobil 1 M1-209 (5267 miles)
by DuckRyder - 05/27/20 07:15 PM
[Cut Open] FRAM TG8A (30 minutes)
by DuckRyder - 05/27/20 07:06 PM
[Cut Open] Motorcraft FL500S - 5341 miles
by DuckRyder - 05/27/20 06:59 PM
Battery powered 1/2 inch impact wrench
by RazorsEdge - 05/27/20 06:50 PM
Subaru Dealer Filter 7KMI
by Jason_Michaels - 05/27/20 05:52 PM
Vehicle sighting - 1968 AMC Javelin
by Number_35 - 05/27/20 04:22 PM
Looking for help on an old tiller
by BarryBl - 05/27/20 03:28 PM
is a larger alternator a no brainer?
by apollo18 - 05/27/20 03:02 PM
Rock Auto Code
by BAJA_05 - 05/27/20 01:42 PM
Considering 2019 VW Jetta
by KrisZ - 05/27/20 01:34 PM
Scheaffers moly worth it?
by mpgo4th - 05/27/20 10:50 AM
BlackMagicVarian, Mustache, mountaingoat, Alegrianyc, unavailable
71545 Registered Users
17 registered members (GemStater, blufeb95, ArrestMeRedZ, ctechbob, edhackett, Bscott07, 2 invisible), 1,058 guests, and 48 spiders.
Topics305,958
Posts5,283,648
Members71,545
Opinions on diff fluid change with mityvac? #4777159 06/04/18 11:39 AM
M
monster1 Offline OP
M
Hey guys, I'm wanting to change my diff gear oil in my 04 2500 5.9l cummins 4x4. Should I completely pull the covers or will using a mityvac suck and swap be ok? Odometer is about 75k. First service.
Re: Opinions on diff fluid change with mityvac? [Re: monster1] #4777181 06/04/18 12:11 PM
N
nthach Offline
N
If you can get the Mityvac to pick up from the bottom of the diff, I think it should work but it could struggle with the thicker gear oil. I would try it with the diff oil warm.
Pulling the diff cover isn't a bad idea if not messy. I would go that way to avoid any drama. If you were planning on swapping diff covers to a Mag-Hytec or similar with a drain plug it's also a good time.
Re: Opinions on diff fluid change with mityvac? [Re: monster1] #4777225 06/04/18 12:43 PM
229 Offline
Slow but better than not refreshing. Pull the covers so you can wipe out the slime. Use Mopar gear RTV or compatible black gear oil RTV silicone.
Re: Opinions on diff fluid change with mityvac? [Re: monster1] #4777249 06/04/18 01:09 PM
M
monster1 Offline OP
M
I'll pull the covers. Thanks.
Re: Opinions on diff fluid change with mityvac? [Re: monster1] #4777397 06/04/18 04:06 PM
M
monster1 Offline OP
M
Pulled the cover to the rear. Gear oil was dark. But no shavings and everything was really clean. Put in 3 quarts of Lucas full synthetic 75w-90 and tightened everything back up. I think the front diff will wait for now since the rear was so clean. Too dang hot for me to be working in the sun.
Re: Opinions on diff fluid change with mityvac? [Re: monster1] #4777405 06/04/18 04:10 PM
J
JEL01 Offline
J
Good on you for taking care of it,
You are now ahead of 99% of other drivers, BITOGers excluded smile
Cars I maintain:
02 Mercedes CLK430
09 Honda Accord V6
13 Lexus RX350 AWD
02 Toyota Tundra 4x4
18 Lexus GX460
Re: Opinions on diff fluid change with mityvac? [Re: monster1] #4777424 06/04/18 04:27 PM
B
Billy_D Offline
B
I donít bother pulling the cover on my truck. I just use an oil extractor every 40k miles. The process is painfully slow.
Re: Opinions on diff fluid change with mityvac? [Re: monster1] #4777439 06/04/18 04:45 PM
demarpaint Offline
If you don't have a drain plug, that's what I'd do. thumbsup
God Bless Our Troops
Re: Opinions on diff fluid change with mityvac? [Re: monster1] #4778998 06/06/18 11:13 AM
M
monster1 Offline OP
M
I towed my 4k lb boat yesterday on a 50 mile round trip. I know this is nothing for a 3/4 ton truck but the lazer thermometer showed the differential running at 150 degrees in 100 degree heat. Looks like that Lucas synthetic gear oil does it's job. I was a bit concerned I made a wring choice if lubricants because it's not a very popular product as far as the internet is concerned.
Re: Opinions on diff fluid change with mityvac? [Re: monster1] #4779556 06/06/18 08:05 PM
Z
zeng Offline
Z
150F diff temperature towing is fantastic for Lucas 75W90 with a high [email protected]*C of 142 cSt.
