Barkeepers Friend
by jerseyguy123. 01/22/19 02:23 AM
Bag-in-a-box motor oils
by jtr990. 01/22/19 02:10 AM
Inventions of the 1950's - 1970's
by StevieC. 01/21/19 10:26 PM
Fireplace cleaners and price
by 97prizm. 01/21/19 10:23 PM
M1 0w40 extended oci??
by Pinoak. 01/21/19 09:46 PM
Best propane fireplace insert?
by SOHCman. 01/21/19 08:51 PM
Save 1/4 on gas!! Guaranteed!!
by Linctex. 01/21/19 08:50 PM
Funny names
by Chris142. 01/21/19 08:45 PM
Kendall vs Total Qaurtz
by zeke1985. 01/21/19 08:32 PM
Got a weird one - Helping a friend
by StevieC. 01/21/19 08:32 PM
Thanks 14Accent
by clinebarger. 01/21/19 08:07 PM
Mobil 1 5W30 C7 Z06
by PLRX. 01/21/19 07:40 PM
How cold is it? (Humor)
by StevieC. 01/21/19 07:13 PM
Slight performance decrease
by A_User55555. 01/21/19 06:54 PM
how to keep your vehicle battery...
by Char Baby. 01/21/19 06:31 PM
2012 to 2016 ford focus
by WhyMe. 01/21/19 06:30 PM
LHM anyone?
by mistersooty. 01/21/19 06:30 PM
Walmart Oil Changes.
by Bill7. 01/21/19 06:10 PM
Coolbreez1973, jmcast1127, DF8005, FT86dude11, RTSAllison
67008 Registered Users
33 registered members (Char Baby, berniedd, alcyon, billt460, BlakeB, citationxeleven, 5 invisible), 868 guests, and 37 spiders.
Topics296,961
Posts4,962,404
Members67,008
Most Online2,821
Jan 21st, 2019
CRC Gdi intake cleaner #4778954
06/06/18 09:33 AM
06/06/18 09:33 AM
Peace valley, Missouri
Fitter30 Offline OP
Fitter30  Offline OP
2013 equinox I4 anyone use this cleaner for general maintenance? Have 64k on car having no issues with it.
Re: CRC Gdi intake cleaner [Re: Fitter30] #4778968
06/06/18 09:48 AM
06/06/18 09:48 AM
US-WA
Dyusik Offline
Dyusik  Offline
US-WA
I do on my IS. I don't "seafoam" it, I spay the valve stems down with it, and let it soak a couple hours. Once you see the results, you will not think twice to do it again. That stuff works great.
95 Cherokee 190K DELO 10W30, XG8
07 IS250 104K STP syn HM 10w30, FULL
04 YZF-R1 19K DELO 15w40, XG7317
99 HD XL1200S 21K VR1 20w50, NG1515
14 RX450h 37k Idemitsu 0w20, 57047
Re: CRC Gdi intake cleaner [Re: Dyusik] #4778987
06/06/18 10:03 AM
06/06/18 10:03 AM
MURICA
maverickfhs Offline
maverickfhs  Offline
MURICA
Could you please share the procedure?
2006 Civic EX 205K/AT
2006 Acura TSX 187K/AT
Re: CRC Gdi intake cleaner [Re: Dyusik] #4778989
06/06/18 10:05 AM
06/06/18 10:05 AM
Ocala, Florida
racin4ds Offline
racin4ds  Offline
Ocala, Florida
I'm curious as to how you're doing this and how often? I assume you pull the entire intake manifold assembly off to get right to the valves?
Just say NO to thin oils and M1!
05 F350 Powerstroke
05 Hyundai Tucson
08 Legacy GT
Re: CRC Gdi intake cleaner [Re: Fitter30] #4779040
06/06/18 11:01 AM
06/06/18 11:01 AM
USA
oldhp Offline
oldhp  Offline
USA
Had a 2012 "Nox 2.4. I drilled a small hole in the pass side air cleaner about 6" from where it goes down to the Throttle body. I put the straw in the small hole, had wife keep it at 2000RPM and sprayed shots in until can was empty and then let it sit for 15-20 mins. Put screw in small hole and went for a drive. "Nox wouldn't hardly pull itself at first and smoked a ton. Got it to back road and started going hard on the gas, finally it cleared out and took off. Kept smoking less. It did for a fact drive better with more pickup and power. It had gotten to the point where even flooring it to pass was a white knuckle no power event. The CRC GDI does work. Does it work as good as taking intake off and blasting the intake valves? No....But it does make difference. I'm thinking it cleaned more around the edges of the valves than anything else. Probably the majority of crud on the valve stems was still there. But again, I could definitely tell a difference on pickup. "Nox had around 30K miles on it with a "ton" of very short trips.
2018 RAM 1500 3.6/8 speed.
2017 Jeep Sahara Unlimited 3.6
"U kan't fixe it......if'n it ain't broke."
Re: CRC Gdi intake cleaner [Re: Fitter30] #4779074
06/06/18 11:25 AM
06/06/18 11:25 AM
Texas
GMBoy Offline
GMBoy  Offline
Texas
Good product, I use it often. Gumout now has a similar product and it works well too.
Re: CRC Gdi intake cleaner [Re: Fitter30] #4779099
06/06/18 11:46 AM
06/06/18 11:46 AM
Maryland
walterjay Offline
walterjay  Offline
Maryland
I used it last week on my Tuscon 1.6 turbo. Disconnected the pcv valve hose and shot it down there. Gas mileage went up about 1.5 mpg. 25,000 miles on engine. Changing oil today.
Re: CRC Gdi intake cleaner [Re: walterjay] #4779172
06/06/18 01:12 PM
06/06/18 01:12 PM
Cali
Malo83 Offline
Malo83  Offline
Cali
Re: CRC Gdi intake cleaner [Re: racin4ds] #4779189
06/06/18 01:20 PM
06/06/18 01:20 PM
US-WA
Dyusik Offline
Dyusik  Offline
US-WA
I have to pop off the upper intake manifold to get a clear shot at the valves, 20 min worth of moving hoses and removing plastic components. The closed valves get a much better cleaning. I just drive it until it is good a hot, get the upper intake manifold off, and just spray at the valves until the stuff pools in the ports. Give it a squirt here and there for the two hours worth of soak. Once the time passed, you can see the buildup reduced on the stems. Re assemble, drive until the gunk is done smoking, dump the oil, and be happy. Nothing complicated, really. Doing so I used a half of the can, and was not shy to get the stuff in there, so 8(?) bucks per cleaning is not a biggie.
From the looks of the conditions of the valves, I'd say it should probably be done at sub 30k intervals, but that's my car, pre catch can, and God knows if the valves were new or cleaned, and how well they were cleaned during TSB work. I'm planning to give it a looksee in 15-20k, and adjust fire from there.
Re: CRC Gdi intake cleaner [Re: Fitter30] #4779985
06/07/18 08:51 AM
06/07/18 08:51 AM
Fitter30 Offline OP
Fitter30  Offline OP
thanks or the info
