Intel or AMD Processor
by ZeeOSix - 02/28/20 04:02 AM
Denso Reman Starter Noise
by The Critic - 02/28/20 02:59 AM
Gratitude
by rrretiree7 - 02/27/20 11:56 PM
Maxlife for 35yo Ford C6
by Cubey - 02/27/20 11:35 PM
New 2-post lift on order
by clinebarger - 02/27/20 11:07 PM
New F-150 2.7 EB recommendations?
by mattri - 02/27/20 09:37 PM
Honey I bought a set of wheels
by P10crew - 02/27/20 09:29 PM
PQIA Pennzoil Hybrid 0W-16
by kstanf150 - 02/27/20 08:32 PM
100,000 ducks sent to Pakistan.
by Vern_in_IL - 02/27/20 08:07 PM
06 Camry Coolant??
by Jcountry - 02/27/20 07:54 PM
PQIA Kirkland 5W-30 synthetic
by kstanf150 - 02/27/20 07:43 PM
401 K took a beating!
by P10crew - 02/27/20 07:30 PM
Coolant Level
by rrretiree7 - 02/27/20 07:21 PM
Techron BOGO at O'Reilly
by TheLawnRanger - 02/27/20 06:26 PM
"Follow Thread" not working anymore?
by atikovi - 02/27/20 06:25 PM
What happened at Hyundai dealers
by WhyMe - 02/27/20 06:23 PM
Using ramps for oil change?
by superfat_dad - 02/27/20 06:03 PM
Ford to reduce warranty costs ?
by marine65 - 02/27/20 06:02 PM
hogryder007, Sabbag77, RpR, jameswilliam, Agraz400
70819 Registered Users
31 registered members (Bailes1992, CB900F2, Bookmaker, Char Baby, bachman, ChrisD46, 5 invisible), 826 guests, and 17 spiders.
Topics302,027
Posts5,207,498
Members70,819
2003 VW Passat Opinion? #4778895 06/06/18 08:10 AM
M
maverickfhs Offline OP
M
So there's one 2003 passat with ~120K miles, but in non-running condition in my area for ~$1200.
Seller is advertising it as a fuel pump issue, which doesn't seem too bad in terms of replacement.
Was wondering how are these vehicles and are they money pit in terms issues(electronics)or good cars? Any thoughts?
2006 Civic EX 209K/AT
2006 Acura TSX 199K/AT
2007 Accord VP 154K/AT
Re: 2003 VW Passat Opinion? [Re: maverickfhs] #4778903 06/06/18 08:27 AM
Quattro Pete Offline
Which engine? 1.8T? 2.8 V6?
How do you know there are no other issues apart from fuel pump?
When was the timing belt and tensioner last replaced?
Not knowing all the things that may be wrong with it or the maintenance items that may be overdue, it's a big gamble, IMO.
2002 530i   2015 Q5 3.0T   2018 Charger SRT
Re: 2003 VW Passat Opinion? [Re: maverickfhs] #4778906 06/06/18 08:29 AM
K
KGMtech Offline
K
Can be a money pit. Very safe car, amazing ride & handling.
I had a 2004 for 14 years and 187,000 Km. The reliability of the car is more about the drivetrain, 1.8T FWD or V6 with AWD, or Diesel?. If the past owners have skimped on maintenance and used non VWAG parts and approved fluids, walk away! Toyota's can tolerate skimpy maintenance and non OEM parts, but VWAG is not in this category.
The fuel pump is a straightforward DIY, but you could be seeing the elephant through the keyhole....beware!
2017.5 Nissan Rogue SV FWD
2013 Nissan Maxima SV
2009 Ford Flex SEL FWD
1984 Yamaha XJ750RL
Re: 2003 VW Passat Opinion? [Re: maverickfhs] #4778908 06/06/18 08:29 AM
M
M
QP, that's exactly what I was after watched a video about it where guy was covering all the issues with that generation, I'll stay away from it.
Re: 2003 VW Passat Opinion? [Re: KGMtech] #4778909 06/06/18 08:30 AM
M
M
I believe it's a V6.
Re: 2003 VW Passat Opinion? [Re: maverickfhs] #4778912 06/06/18 08:33 AM
M
mx5miata Offline
M
Vr6 nice engine good torque
NAPA FULL SYNTHETIC 0w20 Partsplus oil filter
Wix air filter
Re: 2003 VW Passat Opinion? [Re: mx5miata] #4778916 06/06/18 08:44 AM
AFAIK, there was no VR6 available in a 2003 Passat. There was a 4-liter W8 option though.
Re: 2003 VW Passat Opinion? [Re: maverickfhs] #4778919 06/06/18 08:46 AM
T
Trav Offline
T
Great car and worth owning with 120K on the clock, the V6 uses a timing chain with a couple of small hydraulic tensioners and slippers and are no too bad.
They are generally good cars, fuel pump failure is common. Check the maintenance history if there is one. Buying anything you cant hear run is always a gamble so you kind of have to go by what the owner tells you and how much info you can drag out of him.
Ask a lot of questions about, transmission, brakes, suspension and of course the engine. Did it run good, smoke, use oil, when was it last serviced and that sort of thing. Use your gut, is he believable?
Look the rest of the car over, look at body panels for damage or repaint, exhaust, rust underneath, look for obvious maintenance fails like fogged headlights, neglected interior, pedal wear, handbrake function, make sure everything electrical is working including the gas door and trunk release, radio reception, these use an amplified antenna make sure the reception is good.
Re: 2003 VW Passat Opinion? [Re: maverickfhs] #4778922 06/06/18 08:52 AM
W
wag123 Offline
W
I'm pretty sure that there is a good reason for why this person is getting rid of the car at this point. You have no way of knowing what other issues the car has if it doesn't run, and at 15 years old and 120k miles you can be sure that there are other issues. The fuel pump issue may be the "straw that broke the Camel's back". Money pit is an understatement, 15 years and 120k-140k miles is about the end of life for most of these because of this sort of thing. A/C is an issue with VWs, and in Texas it usually dooms the car at this age/miles. I would PASS on this one.
Re: 2003 VW Passat Opinion? [Re: maverickfhs] #4778925 06/06/18 08:54 AM
M
M
Thanks everyone, I am GOING to stay away from it.
Re: 2003 VW Passat Opinion? [Re: Trav] #4778930 06/06/18 09:00 AM
You sure it's a chain? I've seen conflicting info on that.
https://www.blauparts.com/vw_timing_belt...tion_guide.html
Re: 2003 VW Passat Opinion? [Re: maverickfhs] #4778932 06/06/18 09:02 AM
dlundblad Offline
$1200 for a non runner seems high.
See if you can talk him down before walking away.
If it's just a simple fuel pump, why isn't he fixing it?
03 Jeep WJ 4.0 202k Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 195k M1 0w40 Mahle OX149D
97 Chvy Blazer 4.3 158k M1 EP 10w30 Supertech ST3980
Re: 2003 VW Passat Opinion? [Re: Quattro Pete] #4778949 06/06/18 09:29 AM
T
Trav Offline
T
It may use both, sort of a hybrid eg cam to cam a chain.
Re: 2003 VW Passat Opinion? [Re: dlundblad] #4778951 06/06/18 09:30 AM
dogememe Offline
This. If you get it for $500 if you can't fix it you can sell some parts and send it to the junkyard and make a few bucks. Any more than that, it's another garbage VW.
2010 Ford Escape 2.5 ~102K Miles: Castrol Magnatec 5W-20, Wix Filter.
2001 Chevy Suburban 5.3 ~290K Miles: Valvoline Maxlife 10W-30, ACDelco Filter.
Re: 2003 VW Passat Opinion? [Re: maverickfhs] #4779003 06/06/18 10:22 AM
P
pandus13 Offline
P
OP,
what is your budget and what utility are you looking for?
(I noticed you posted couple other threads....)
16 Golf SportWagen
13 Mazda5
08 Yaris
04 Elantra
95 accent
95 mystique
97 concorde
