Pennzoil GF-6 & Low Viscosity Q&A
Click here to participate in the Pennzoil Q&A
Anyone Using DualLiner Pickup Truck Bed Liner?
by LoneRanger. 06/25/19 08:29 AM
Hard tonneau?
by buck91. 06/25/19 08:20 AM
What's your DIY disaster?
by newbe46. 06/25/19 08:10 AM
Synchromesh: Valvoline Vs. Pennzoil
by IndyFan. 06/25/19 07:27 AM
World’s most valuable Ford Fusion
by LotI. 06/25/19 06:45 AM
Sprinter Gen 2 oil
by Ammofirst. 06/25/19 06:39 AM
Filter Cross over to car chart anywhere
by 97K15004WD. 06/25/19 05:47 AM
Polaris Lab/Oil Analyzers Fuel Dilution
by Talent_Keyhole. 06/24/19 11:55 PM
Ecotec filter failure - w/ pics
by san123chez. 06/24/19 11:37 PM
Restored old Griswold #3
by E150GT. 06/24/19 10:38 PM
Never thought I would say this bout oil
by sixsix. 06/24/19 10:28 PM
Motor Oil for Turbo Props
by Snagglefoot. 06/24/19 10:12 PM
New laptop
by Eric Smith. 06/24/19 10:10 PM
Mahle 180713CJ2 (OEM Hyundai) C&P, 4,683 miles
by blupupher. 06/24/19 09:57 PM
1999-2004 Grand Cherokee
by Snagglefoot. 06/24/19 09:42 PM
195/65-14 Tires
by ArPix. 06/24/19 09:33 PM
Honda Element trans service-"old" Redline D4 OK?
by oilmaven. 06/24/19 09:25 PM
Pennzoil GF-6 and Low Viscosity Engine Oil Q&A
by wwillson. 06/24/19 09:13 PM
Greasing without a gun?
by maverickfhs. 06/24/19 08:56 PM
How to check for coolant flow in a Jeep 4.0L?
by atikovi. 06/24/19 08:51 PM
ml98188, 84FSP, megavoyager, thaduke2003, Vitaliy
68474 Registered Users
110 registered members (AandPDan, Alfred_B, 2015_PSD, 1978elcamino, AdditiveOCD, 2004tdigls, 10 invisible), 1,841 guests, and 23 spiders.
Topics290,938
Posts4,995,515
Members68,474
Most Online2,967
Mar 10th, 2019
2003 VW Passat Opinion? #4778895
06/06/18 09:10 AM
06/06/18 09:10 AM
MURICA
maverickfhs Offline OP
MURICA
So there's one 2003 passat with ~120K miles, but in non-running condition in my area for ~$1200.
Seller is advertising it as a fuel pump issue, which doesn't seem too bad in terms of replacement.
Was wondering how are these vehicles and are they money pit in terms issues(electronics)or good cars? Any thoughts?
2006 Civic EX 205K/AT
2006 Acura TSX 187K/AT
2007 Accord VP 151K/AT
Re: 2003 VW Passat Opinion? [Re: maverickfhs] #4778903
06/06/18 09:27 AM
06/06/18 09:27 AM
Great Lakes
Quattro Pete Offline
Great Lakes
Which engine? 1.8T? 2.8 V6?
How do you know there are no other issues apart from fuel pump?
When was the timing belt and tensioner last replaced?
Not knowing all the things that may be wrong with it or the maintenance items that may be overdue, it's a big gamble, IMO.
'02 530i (Edge 0W-40)
'15 Q5 3.0T (Edge 5W-40)
'18 Charger SRT (PUP 0W-40 SRT)
Re: 2003 VW Passat Opinion? [Re: maverickfhs] #4778906
06/06/18 09:29 AM
06/06/18 09:29 AM
SW Ontario Canada
KGMtech Offline
KGMtech  Offline
SW Ontario Canada
Can be a money pit. Very safe car, amazing ride & handling.
I had a 2004 for 14 years and 187,000 Km. The reliability of the car is more about the drivetrain, 1.8T FWD or V6 with AWD, or Diesel?. If the past owners have skimped on maintenance and used non VWAG parts and approved fluids, walk away! Toyota's can tolerate skimpy maintenance and non OEM parts, but VWAG is not in this category.
The fuel pump is a straightforward DIY, but you could be seeing the elephant through the keyhole....beware!
2017.5 Nissan Rogue SV FWD
2013 Nissan Maxima SV
2009 Ford Flex SEL FWD
1984 Yamaha XJ750RL
Re: 2003 VW Passat Opinion? [Re: maverickfhs] #4778908
06/06/18 09:29 AM
06/06/18 09:29 AM
MURICA
MURICA
QP, that's exactly what I was after watched a video about it where guy was covering all the issues with that generation, I'll stay away from it.
Re: 2003 VW Passat Opinion? [Re: KGMtech] #4778909
06/06/18 09:30 AM
06/06/18 09:30 AM
MURICA
MURICA
I believe it's a V6.
Re: 2003 VW Passat Opinion? [Re: maverickfhs] #4778912
06/06/18 09:33 AM
06/06/18 09:33 AM
NY
mx5miata Offline
mx5miata  Offline
NY
Vr6 nice engine good torque
NAPA FULL SYNTHETIC 0w20 Partsplus oil filter
Wix air filter
Re: 2003 VW Passat Opinion? [Re: mx5miata] #4778916
06/06/18 09:44 AM
06/06/18 09:44 AM
Great Lakes
Great Lakes
AFAIK, there was no VR6 available in a 2003 Passat. There was a 4-liter W8 option though.
Re: 2003 VW Passat Opinion? [Re: maverickfhs] #4778919
06/06/18 09:46 AM
06/06/18 09:46 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
Great car and worth owning with 120K on the clock, the V6 uses a timing chain with a couple of small hydraulic tensioners and slippers and are no too bad.
They are generally good cars, fuel pump failure is common. Check the maintenance history if there is one. Buying anything you cant hear run is always a gamble so you kind of have to go by what the owner tells you and how much info you can drag out of him.
Ask a lot of questions about, transmission, brakes, suspension and of course the engine. Did it run good, smoke, use oil, when was it last serviced and that sort of thing. Use your gut, is he believable?
Look the rest of the car over, look at body panels for damage or repaint, exhaust, rust underneath, look for obvious maintenance fails like fogged headlights, neglected interior, pedal wear, handbrake function, make sure everything electrical is working including the gas door and trunk release, radio reception, these use an amplified antenna make sure the reception is good.
Re: 2003 VW Passat Opinion? [Re: maverickfhs] #4778922
06/06/18 09:52 AM
06/06/18 09:52 AM
Texas
wag123 Offline
wag123  Offline
Texas
I'm pretty sure that there is a good reason for why this person is getting rid of the car at this point. You have no way of knowing what other issues the car has if it doesn't run, and at 15 years old and 120k miles you can be sure that there are other issues. The fuel pump issue may be the "straw that broke the Camel's back". Money pit is an understatement, 15 years and 120k-140k miles is about the end of life for most of these because of this sort of thing. A/C is an issue with VWs, and in Texas it usually dooms the car at this age/miles. I would PASS on this one.
Re: 2003 VW Passat Opinion? [Re: maverickfhs] #4778925
06/06/18 09:54 AM
06/06/18 09:54 AM
MURICA
MURICA
Thanks everyone, I am GOING to stay away from it.
Re: 2003 VW Passat Opinion? [Re: Trav] #4778930
06/06/18 10:00 AM
06/06/18 10:00 AM
Great Lakes
Great Lakes
You sure it's a chain? I've seen conflicting info on that.
https://www.blauparts.com/vw_timing_belt...tion_guide.html
Re: 2003 VW Passat Opinion? [Re: maverickfhs] #4778932
06/06/18 10:02 AM
06/06/18 10:02 AM
Indiana
dlundblad Offline
dlundblad  Offline
Indiana
$1200 for a non runner seems high.
See if you can talk him down before walking away.
If it's just a simple fuel pump, why isn't he fixing it?
03 Jeep WJ 4.0 202k Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 186k M1 0w40 Mahle OX149D
97 Chevy Blazer 4.3 158k M1 EP 10w30 Supertech ST3980 (Ecore)
Re: 2003 VW Passat Opinion? [Re: Quattro Pete] #4778949
06/06/18 10:29 AM
06/06/18 10:29 AM
Trav Offline
Trav  Offline
It may use both, sort of a hybrid eg cam to cam a chain.
Re: 2003 VW Passat Opinion? [Re: dlundblad] #4778951
06/06/18 10:30 AM
06/06/18 10:30 AM
San Rafael, CA
dogememe Offline
dogememe  Offline
San Rafael, CA
This. If you get it for $500 if you can't fix it you can sell some parts and send it to the junkyard and make a few bucks. Any more than that, it's another garbage VW.
2010 Ford Escape 2.5 ~96K Miles
Valvoline 5W-20 from Valvoline Instant Oil Change.
Re: 2003 VW Passat Opinion? [Re: maverickfhs] #4779003
06/06/18 11:22 AM
06/06/18 11:22 AM
Chicago,IL,USA
pandus13 Offline
pandus13  Offline
Chicago,IL,USA
OP,
what is your budget and what utility are you looking for?
(I noticed you posted couple other threads....)
16 Golf SportWagen
13 Mazda5
08 Yaris
04 Elantra
95 accent
95 mystique
97 concorde
