My Son Turned Me On to a New Cooking Show
by NYEngineer. 06/19/19 05:42 PM
Naphthenic Oils
by MolaKule. 06/19/19 05:06 PM
Mopar 5W-20?
by John344. 06/19/19 04:39 PM
Toyota WS UOA and Redline D6 VOA
by Patrick0525. 06/19/19 04:28 PM
2015 4Runner UOA w/ TGMO ALUMINUM
by OCDoiler. 06/19/19 04:17 PM
Evinrude oil
by FastLane. 06/19/19 03:40 PM
engine air filters...all the same?
by flinter. 06/19/19 03:37 PM
GM Dexron Developer Passes Away
by MolaKule. 06/19/19 03:20 PM
Hard Tonneau Cover Clean/Protect
by jims5600. 06/19/19 03:17 PM
2006 Camry 4 cyl. 15,000 miles on M1 5W-30
by Deontologist. 06/19/19 02:29 PM
puma oil nissan 350z? 20w50
by 1978elcamino. 06/19/19 02:04 PM
PL14612 cut open, ~5100 miles
by Sayjac. 06/19/19 01:42 PM
Best ATF for vintage Toyota P/S system
by timoboy. 06/19/19 01:16 PM
Touchless 303 thoughts?
by DriveHard. 06/19/19 12:59 PM
Napa Conventional 5qt @ $11.99
by SlavaB. 06/19/19 12:53 PM
Just spotted: 1974 Pinto!
by dadto2. 06/19/19 12:49 PM
Steering Rack Quality
by LazyDog. 06/19/19 12:43 PM
Liquid lawn fertilizer
by LeakySeals. 06/19/19 12:01 PM
HynKia Carquest filters: 85334 vs 95459
by SlavaB. 06/19/19 11:26 AM
taschnewitz, SilverFL, CactusLady, Ignatius, Kyle_O
68434 Registered Users
97 registered members (2002 Maxima SE, 4WD, 2015_PSD, 1WildPig, 53' Stude, 2oldtommy, 10 invisible), 2,139 guests, and 30 spiders.
Topics290,674
Posts4,990,699
Members68,434
Most Online2,967
Mar 10th, 2019
Page 1 of 3 1 2 3
Lucas oil stabilizer #4778333
06/05/18 04:08 PM
06/05/18 04:08 PM
so cal
daz Offline OP
daz  Offline OP
so cal
I started using this and i really like the way it has made my triumph thunderbird run. But i used only half the quart. Seems like a quart is a lot to put in a bike that holds 4.5 quarts of oil. So the question is, does anyone here use it and if so how much do you typically put in your bike and whats you bike's oil capacity?
Re: Lucas oil stabilizer [Re: daz] #4778341
06/05/18 04:18 PM
06/05/18 04:18 PM
US-WA
Dyusik Offline
Dyusik  Offline
US-WA
No one. It is an oil type from 1905, and it has a viscosity 10 times that of a light 40 weight. Just bump up a grade in an oil choice to get the same results without compromise.
95 Cherokee 190K DELO 10W30, XG8
07 IS250 110K Frankenbrew, WIX 57173
04 YZF-R1 19K DELO 15w40, XG7317
14 RX450h 41k Idemitsu 0w20, WIX 57047
18 RAM 3500 <1k FF, Mopar
Re: Lucas oil stabilizer [Re: daz] #4778355
06/05/18 04:33 PM
06/05/18 04:33 PM
Phoenix, Arizona - USA
SirTanon Online content
SirTanon  Online Content
No way would I put that in either of my cars crankcases.
2013 Nissan Altima SV - 2.5 liter/CVT - 113,000mi
2014 Nissan Altima SL - 2.5 liter/CVT - 65,000mi
2010 Ford Fusion - 274,000mi
Re: Lucas oil stabilizer [Re: SirTanon] #4778361
06/05/18 04:38 PM
06/05/18 04:38 PM
California
Billbert Offline
Billbert  Offline
California
Do you really want to dilute the additive package so carefully formulated by the manufacturer of your oil by 10-20% ?
If you think you can, or if you think you can't, You are probably right.
Auto Instructor / ASE Master Tech
Re: Lucas oil stabilizer [Re: daz] #4778384
06/05/18 05:15 PM
06/05/18 05:15 PM
Deep in the heart of Jersey
BigCahuna Online content
BigCahuna  Online Content
In all my years of riding, my oil has never needed to be stabilized.,,
Re: Lucas oil stabilizer [Re: daz] #4778411
06/05/18 05:50 PM
06/05/18 05:50 PM
NY
mx5miata Offline
mx5miata  Offline
NY
isn't that stuff labeled replace 20% of oil capacity with the lucas
NAPA FULL SYNTHETIC 0w20 Partsplus oil filter
Wix air filter
Re: Lucas oil stabilizer [Re: daz] #4778419
06/05/18 05:56 PM
06/05/18 05:56 PM
The Midwest
skyactiv Offline
skyactiv  Offline
The Midwest
A video is worth a thousand words.
Me: 13' VW GTI 3 door 6 speed manual
Re: Lucas oil stabilizer [Re: daz] #4778593
06/05/18 09:28 PM
06/05/18 09:28 PM
so cal
daz Offline OP
daz  Offline OP
so cal
Well, i didn't post this to get opinions on whether it's good or not, but since almost all of you seem to assume it isn't, i'll just say this. Suggesting it's bad without any experience, especially long term, would be call an "assumption". There are 1000's of reviews on this stuff many of which i read and are almost all positive that are from users who HAVE EXPERIENCE WITH IT and are not just assuming based on their logic, which by the way unless you are a engineer in the field means little to nothing. If all it took was layman's logic and learning what u know by reading posts by others inexperienced with it to determine what will or won't work, there would be no debates and all products on the market would work. Now, excuse me while i find another place that might answer what i asked rather then revel in the joy of raining on someone's parade without actually knowing whether your raindrops are even valid. Good day...
Re: Lucas oil stabilizer [Re: daz] #4778602
06/05/18 09:38 PM
06/05/18 09:38 PM
out there
spasm3 Offline
spasm3  Offline
out there
When you post about a subject on a forum, its open to discussion, otherwise, why bother to post. You say that suggesting its bad without experience is an assumption.
Well there is data here about whats in lucas. So that's experience. Here is a voa thread.
https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/890132/8
There is little there other than thick base oil without additives.
Time to face the facts. If that bothers you, don't make assumptions that a product is good , just because you pour it in and nothing bad happens. It could also be nothing good is happening either.
13 elantra 75k 5w30 QSUD
03 chevy avalanche 80k synpwr 5w30
17 mazda cx-5 9500 miles m1 0w30
Re: Lucas oil stabilizer [Re: daz] #4778620
06/05/18 09:52 PM
06/05/18 09:52 PM
US
talest Offline
talest  Offline
US
It is a straight 80-weight bottle of snot with soap in it. No thanks.
As stated, going up one grade of oil should yield similar results and not compromise the oil.
Re: Lucas oil stabilizer [Re: daz] #4778628
06/05/18 10:01 PM
06/05/18 10:01 PM
Toronto
PeterPolyol Offline
PeterPolyol  Offline
Toronto
Why are bright stock products so bleddy expensive?? A dinky bottle of STP costs as much as a quart of synthetic oil. A quart of Lucas costs as much as a 5L jug of synthetic. Are the merchants of such products just blatantly ripping people off?
There's no replacement...'scosity for natural viscosity
Re: Lucas oil stabilizer [Re: PeterPolyol] #4778641
06/05/18 10:19 PM
06/05/18 10:19 PM
Texas
4WD Online confused
4WD  Online Confused
Texas
Do they really have a stadium?
Re: Lucas oil stabilizer [Re: daz] #4778685
06/05/18 11:04 PM
06/05/18 11:04 PM
'Stralia
Shannow Offline
Shannow  Offline
'Stralia
Couple of qualifiers here
* I HAVE used it in the past in my engines (I was an idiot)
* I AM an engineer
* In my turbine engineering days I DID use it on bearings during turbine overhauls.
Firstly - it makes oil thicker...for better or for worse
Secondly - being additiveless in and on itself, it dilutes your anti wear additive, your friction modifying additives, your detergents and dispersents.
So does the thickening offset the subrtractive effect on additives...unlikley.
The increasing thickness:
* will use more fuel - you may or may not be able to measure it.
* will affect your "W" rating, that is the cold weather performance of your oil - you can't and won't measure that.
So rather than being an "additive", the majority of what it does is "subtractive"...
* takes away your engine oil additive concentrations
* takes gas money out of your wallet
* takes away your cold weather performance
* takes away far more money than buying a properly formulated oil of the next grade up.
Now to why I used it on the turbines, it was SOOOO thick that it wouldn't squeeze out between the bearing and the journal (12"-20" diameter, 8-19" long), meaning that we could turn the shafts using the overhead crane without activating the shaft lifting oil system. Being essentially additive free, it didn't contaminate the bearings or the oil tanks.
Re: Lucas oil stabilizer [Re: daz] #4778707
06/06/18 12:09 AM
06/06/18 12:09 AM
The Canyons
02SE Offline
02SE  Offline
The Canyons
Forrest sure has made a lot of money selling his thick base oil to sucke.. err customers. It's been tried in Fuel cars, AFAIK no one is actually using it.
Re: Lucas oil stabilizer [Re: daz] #4778751
06/06/18 04:15 AM
06/06/18 04:15 AM
NY
mx5miata Offline
mx5miata  Offline
NY
You're going to get all sorts of opinions when you post - I wouldn't take it to heart.
My mechanic friend used this stuff back in the late 90s in a civic as a topoff or 80/20. He swore by it and had no issues. And thats all he would do 80/20.
I would sooner try the pure synthetic stabilizer but not in a brand new vehicle especially under warranty.
I'm not one to alter my oils chemistry or mask problems with oil thickeners. Only if the vehicles on its last leg.
Wix air filter
Page 1 of 3 1 2 3
