Pennzoil GF-6 & Low Viscosity Q&A
Click here to participate in the Pennzoil Q&A
The Mysterious Mopar SAE 5W-20?
by John344. 06/25/19 10:24 PM
90915-YZZD3 particle count - ISO code 24/23/15
by newtoncd8. 06/25/19 10:12 PM
Pep Boys syn oil sale. . . $15.98 after rebate
by Robster. 06/25/19 09:47 PM
Another Amazon issue....
by mjk. 06/25/19 09:10 PM
Leupold screws
by buck91. 06/25/19 08:51 PM
2004 Lexus RX330, 5659mi, Pennzoil Platinum HM 5W30
by newtoncd8. 06/25/19 07:38 PM
Milesyn 5w/20, 5500 miles, 2007 Mazda6 2.3L
by RayCJ. 06/25/19 07:12 PM
Mystik JT-6 Green tube @ Tractor Supply
by K20FA5. 06/25/19 06:58 PM
Saw a '53 Chevy this morning
by fdcg27. 06/25/19 06:20 PM
Motorcraft Mercon V opinions?
by Vigilant. 06/25/19 05:28 PM
New Personal Best MPG
by Kjmack. 06/25/19 05:01 PM
DuraMAX Synthetic Oil?
by Torino117. 06/25/19 04:54 PM
Battery Cables!
by NYEngineer. 06/25/19 04:35 PM
Brake Rotors
by WyrTwister. 06/25/19 04:00 PM
Rubber cement tubes?
by buck91. 06/25/19 03:53 PM
2019 Camaro SS 10sp auto, brief review
by Cujet. 06/25/19 03:14 PM
John Deere LX280 Help!
by johnmichael. 06/25/19 03:01 PM
Which grease?
by maverickfhs. 06/25/19 12:43 PM
Potenza SO4 Pole Position on the 968
by BeerCan. 06/25/19 12:15 PM
Beason, Toddstephens22, Macky, javadog, giwatcher
68488 Registered Users
72 registered members (BigCahuna, aquariuscsm, bbhero, bernau, 11 invisible), 1,730 guests, and 27 spiders.
Topics290,972
Posts4,996,172
Members68,488
Most Online2,967
Mar 10th, 2019
How much refrigerant is in a can? #4771400
05/29/18 05:07 PM
05/29/18 05:07 PM
NY
joegreen Offline OP
joegreen  Offline OP
NY
So i am in the process of buying refrigerant to fill my vehicle. It seems like an easy enough question but i couldnt find any info online. Lets say i have a can of r134a and it says net weight 12oz. Does that mean the can contains 12oz of refrigerant or does the can and refrigerant weight 12oz? Im just trying to figure out how many cans of r134a i need.
1978 Chevrolet k20
Engine: Delo 10w30xle
Transmission: Castrol transmax dex/merc
1984 Mercedes-Benz 300 turbo diesel
Engine: Delo 400 15w40le
Re: How much refrigerant is in a can? [Re: joegreen] #4771401
05/29/18 05:09 PM
05/29/18 05:09 PM
Upper Midwest
kschachn Offline
kschachn  Offline
Upper Midwest
http://www.businessdictionary.com/definition/net-weight.html
1994 BMW 530i, 242K
1996 Honda Accord, 277K
1999 Toyota Sienna, 418K
2000 Toyota ECHO, 281K
Re: How much refrigerant is in a can? [Re: joegreen] #4771414
05/29/18 05:22 PM
05/29/18 05:22 PM
Illinois
mrsilv04 Offline
mrsilv04  Offline
Illinois
You have to read the can. Some will have a small amount of oil in them as well.
I have a 12 ounce can in the garage, which is labelled as containing 11.3 ounces of R-134a, and .7 ounces of refrigerant oil.
2004 Silverado - on its 3rd Jasper engine in less than one year.
Re: How much refrigerant is in a can? [Re: joegreen] #4771415
05/29/18 05:23 PM
05/29/18 05:23 PM
Western Ma.
rollinpete Offline
rollinpete  Offline
Western Ma.
Usually under the hood some where, it will tell you how much you need, for your system.
Got to go from there.
Pete.
97 Ford Expl.Sport 4.0 ohv 4wd 5spd 187k miles
03 Saturn Ion 2.2 L4 5spd 238k miles
PP, PPHM 50/50 5w30
Currently under the influence of oil shocked2
Re: How much refrigerant is in a can? [Re: joegreen] #4771428
05/29/18 05:42 PM
05/29/18 05:42 PM
USA
slacktide_bitog Offline
USA
"net weight" is the weight of just the contents inside the can smile
"tare weight" is the weight of the container itself, and "gross weight" is the "net"and "tare" weights
Re: How much refrigerant is in a can? [Re: rollinpete] #4771589
05/29/18 08:00 PM
05/29/18 08:00 PM
NY
joegreen Offline OP
joegreen  Offline OP
NY
I need 1lb 14oz. Im just trying to figure out how many cans i need to buy is all
1978 Chevrolet k20
Re: How much refrigerant is in a can? [Re: kschachn] #4771591
05/29/18 08:02 PM
05/29/18 08:02 PM
NY
joegreen Offline OP
joegreen  Offline OP
NY
Thanks i understand now
1978 Chevrolet k20
Re: How much refrigerant is in a can? [Re: slacktide_bitog] #4771593
05/29/18 08:02 PM
05/29/18 08:02 PM
NY
joegreen Offline OP
joegreen  Offline OP
NY
Thanks
1978 Chevrolet k20
Re: How much refrigerant is in a can? [Re: joegreen] #4771594
05/29/18 08:02 PM
05/29/18 08:02 PM
NY
joegreen Offline OP
joegreen  Offline OP
NY
Looks like ill get 3 cans and put 2.5 cans in.
1978 Chevrolet k20
Re: How much refrigerant is in a can? [Re: joegreen] #4771650
05/29/18 08:39 PM
05/29/18 08:39 PM
Chicago, IL
tomcat27 Offline
tomcat27  Offline
Chicago, IL
Is your system totally empty and do you have a vacuum pump?
2019 Cherokee, 2018 Jetta, 2014 Sentra, 2001 Camry, 1995 Escort, 1970 Cougar, 2013 XT250, 2010 Vstar, 2014 CTX1300
Re: How much refrigerant is in a can? [Re: joegreen] #4771752
05/29/18 10:09 PM
05/29/18 10:09 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
There's usually enough reserve in the accumulator to handle that last 1/2 a can
Re: How much refrigerant is in a can? [Re: joegreen] #4771754
05/29/18 10:12 PM
05/29/18 10:12 PM
out there
spasm3 Offline
spasm3  Offline
out there
It seems to me that the old r12 system worked well even when undercharged or overcharged a bit. It seems to me that with the r134a systems , there is a fine line between undercharged and overcharged.
13 elantra 75k 5w30 QSUD
03 chevy avalanche 80k synpwr 5w30
17 mazda cx-5 9500 miles m1 0w30
Re: How much refrigerant is in a can? [Re: tomcat27] #4778394
06/05/18 05:28 PM
06/05/18 05:28 PM
NY
joegreen Offline OP
joegreen  Offline OP
NY
Yes the system is totally empty. I have a gauge set and a vacuum pump. Anyway the a/c is all repaired now. thanks
1978 Chevrolet k20
Re: How much refrigerant is in a can? [Re: spasm3] #4778446
06/05/18 06:29 PM
06/05/18 06:29 PM
California
nthach Offline
nthach  Offline
California
Depends on the system as well, new AC systems are very sensitive to oil and refrigerant charge. That old GM accumulator and orifice tube system can tolerate some overcharge.
If you charged in with all 3 cans, I don't think an extra 5 oz of R-134a will hurt anything. You lost some while changing out cans, purging the charging hose and gauges.
