My Henry 22 Magnum Rifle (pics)
by tig1 - 05/29/20 09:04 AM
overfilled my crankcase by 3/10 of a liter - problem?
by tom in boise - 05/29/20 08:49 AM
Espresso
by buster - 05/29/20 08:34 AM
I didn't believe there were fake spark plugs.
by JustinH - 05/29/20 08:14 AM
New Tire Selection
by artbuc - 05/29/20 07:44 AM
Well question
by supton - 05/29/20 07:11 AM
Cable Modem Thoughts/Recommendat
ions?
by alarmguy - 05/29/20 07:10 AM
Tire choice 2016 Lexus es 350
by Toros - 05/29/20 06:20 AM
Infineum trends: Passenger vehicles (2019)
by Gokhan - 05/29/20 05:11 AM
Another story from the service bay
by clinebarger - 05/29/20 12:11 AM
KIA TYPE 4 (M) ATF
by flinter - 05/28/20 08:49 PM
My new Henry 22 Magnum rifle
by tig1 - 05/28/20 08:45 PM
Mobil 1 M-102 for 3 6000km oil changes?
by pktrkt - 05/28/20 08:33 PM
1/2 75W-90 1/2 75W-110 Can you mix equal parts
by jrommelt - 05/28/20 08:22 PM
Mazda b4000 to the junkyard
by HyundaiAbuser - 05/28/20 08:20 PM
2017 RAM 2500 6.4 Hemi AMSoil and PUP
by Gondul - 05/28/20 07:50 PM
Nail in tire, what would you do?
by Brybo86 - 05/28/20 07:44 PM
Any decent lap tops for $200.00 or less?
by BAJA_05 - 05/28/20 06:49 PM
New PW with Honda 190 engine - Ethanol treatment?
by DirtyApe - 05/28/20 06:38 PM
What size tube should a 110/50-6.5 Tire use?
by taztheman - 05/28/20 06:14 PM
Kboggs, oldcodger, cwllams1, Danwrig, DanielR
71558 Registered Users
97 registered members (Alfred_B, ABN_CBT_ENGR, 830Lee, amh, ARCOgraphite, AandPDan, 6 invisible), 2,116 guests, and 20 spiders.
Topics306,008
Posts5,284,638
Members71,558
Page 1 of 3 1 2 3
Lucas oil stabilizer #4778333 06/05/18 04:08 PM
daz Offline OP
I started using this and i really like the way it has made my triumph thunderbird run. But i used only half the quart. Seems like a quart is a lot to put in a bike that holds 4.5 quarts of oil. So the question is, does anyone here use it and if so how much do you typically put in your bike and whats you bike's oil capacity?
Re: Lucas oil stabilizer [Re: daz] #4778341 06/05/18 04:18 PM
Dyusik Offline
No one. It is an oil type from 1905, and it has a viscosity 10 times that of a light 40 weight. Just bump up a grade in an oil choice to get the same results without compromise.
95 Cherokee 190K DELO XLE 10W30, XG8
04 YZF-R1 21K RT6 15w40, XG7317
18 RAM 3500 15k Delvac 15w40, DBL7349
96 Cherokee
Re: Lucas oil stabilizer [Re: daz] #4778355 06/05/18 04:33 PM
SirTanon Offline
No way would I put that in either of my cars crankcases.
2013 Nissan Altima SV - 2.5 liter/CVT - 125,000mi
2014 Nissan Altima SL - 2.5 liter/CVT - 68,000mi
2010 Ford Fusion - 274k mi - SOLD
Re: Lucas oil stabilizer [Re: SirTanon] #4778361 06/05/18 04:38 PM
Billbert Offline
Do you really want to dilute the additive package so carefully formulated by the manufacturer of your oil by 10-20% ?
If you think you can, or if you think you can't, You are probably right.
Auto Instructor / ASE Master Tech
Re: Lucas oil stabilizer [Re: daz] #4778384 06/05/18 05:15 PM
B
BigCahuna Offline
B
In all my years of riding, my oil has never needed to be stabilized.,,
Re: Lucas oil stabilizer [Re: daz] #4778411 06/05/18 05:50 PM
M
mx5miata Offline
M
isn't that stuff labeled replace 20% of oil capacity with the lucas
NAPA FULL SYNTHETIC 0w20 Partsplus oil filter
Wix air filter
Re: Lucas oil stabilizer [Re: daz] #4778419 06/05/18 05:56 PM
skyactiv Offline
A video is worth a thousand words.
Me: 18' Elantra Sport 6 speed manual
The rude guy that points out reality
Re: Lucas oil stabilizer [Re: daz] #4778593 06/05/18 09:28 PM
daz Offline OP
Well, i didn't post this to get opinions on whether it's good or not, but since almost all of you seem to assume it isn't, i'll just say this. Suggesting it's bad without any experience, especially long term, would be call an "assumption". There are 1000's of reviews on this stuff many of which i read and are almost all positive that are from users who HAVE EXPERIENCE WITH IT and are not just assuming based on their logic, which by the way unless you are a engineer in the field means little to nothing. If all it took was layman's logic and learning what u know by reading posts by others inexperienced with it to determine what will or won't work, there would be no debates and all products on the market would work. Now, excuse me while i find another place that might answer what i asked rather then revel in the joy of raining on someone's parade without actually knowing whether your raindrops are even valid. Good day...
Re: Lucas oil stabilizer [Re: daz] #4778602 06/05/18 09:38 PM
spasm3 Offline
When you post about a subject on a forum, its open to discussion, otherwise, why bother to post. You say that suggesting its bad without experience is an assumption.
Well there is data here about whats in lucas. So that's experience. Here is a voa thread.
https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/890132/8
There is little there other than thick base oil without additives.
Time to face the facts. If that bothers you, don't make assumptions that a product is good , just because you pour it in and nothing bad happens. It could also be nothing good is happening either.
13 elantra 84k 5w30 synpwr
17 mazda cx-5 19000 miles m1 0w30
Re: Lucas oil stabilizer [Re: daz] #4778620 06/05/18 09:52 PM
T
talest Offline
T
It is a straight 80-weight bottle of snot with soap in it. No thanks.
As stated, going up one grade of oil should yield similar results and not compromise the oil.
Re: Lucas oil stabilizer [Re: daz] #4778628 06/05/18 10:01 PM
P
PeterPolyol Offline
P
Why are bright stock products so bleddy expensive?? A dinky bottle of STP costs as much as a quart of synthetic oil. A quart of Lucas costs as much as a 5L jug of synthetic. Are the merchants of such products just blatantly ripping people off?
Re: Lucas oil stabilizer [Re: PeterPolyol] #4778641 06/05/18 10:19 PM
4WD Offline
Do they really have a stadium?
Re: Lucas oil stabilizer [Re: daz] #4778685 06/05/18 11:04 PM
Shannow Online Content
Online Content
Couple of qualifiers here
* I HAVE used it in the past in my engines (I was an idiot)
* I AM an engineer
* In my turbine engineering days I DID use it on bearings during turbine overhauls.
Firstly - it makes oil thicker...for better or for worse
Secondly - being additiveless in and on itself, it dilutes your anti wear additive, your friction modifying additives, your detergents and dispersents.
So does the thickening offset the subrtractive effect on additives...unlikley.
The increasing thickness:
* will use more fuel - you may or may not be able to measure it.
* will affect your "W" rating, that is the cold weather performance of your oil - you can't and won't measure that.
So rather than being an "additive", the majority of what it does is "subtractive"...
* takes away your engine oil additive concentrations
* takes gas money out of your wallet
* takes away your cold weather performance
* takes away far more money than buying a properly formulated oil of the next grade up.
Now to why I used it on the turbines, it was SOOOO thick that it wouldn't squeeze out between the bearing and the journal (12"-20" diameter, 8-19" long), meaning that we could turn the shafts using the overhead crane without activating the shaft lifting oil system. Being essentially additive free, it didn't contaminate the bearings or the oil tanks.
Re: Lucas oil stabilizer [Re: daz] #4778707 06/06/18 12:09 AM
02SE Offline
Forrest sure has made a lot of money selling his thick base oil to sucke.. err customers. It's been tried in Fuel cars, AFAIK no one is actually using it.
Re: Lucas oil stabilizer [Re: daz] #4778751 06/06/18 04:15 AM
M
mx5miata Offline
M
You're going to get all sorts of opinions when you post - I wouldn't take it to heart.
My mechanic friend used this stuff back in the late 90s in a civic as a topoff or 80/20. He swore by it and had no issues. And thats all he would do 80/20.
I would sooner try the pure synthetic stabilizer but not in a brand new vehicle especially under warranty.
I'm not one to alter my oils chemistry or mask problems with oil thickeners. Only if the vehicles on its last leg.
Wix air filter
Page 1 of 3 1 2 3
