Extreme fuel dilution
by BigShug681. 02/23/19 04:52 PM
Nine PH3600-size filters FS
by SubieRubyRoo. 02/23/19 04:45 PM
2003 Accord 2.4L Valve train pics
by WagonWheel. 02/23/19 04:24 PM
Leaky FL400s
by jongies3. 02/23/19 03:55 PM
Fram Ultra with Filter Mag pics
by ZZman. 02/23/19 03:39 PM
Which 0w20 meets VW 508.00?
by 53' Stude. 02/23/19 03:28 PM
RockAuto Injectors - Return / Weird
by StevieC. 02/23/19 02:23 PM
03 Nissan Maxima stalls uphill.
by LeakySeals. 02/23/19 01:47 PM
Delvac Rebate?
by 1JZ_E46. 02/23/19 01:23 PM
Oil recommendation for Audi turbo engine
by zorba02. 02/23/19 12:41 PM
Tiger shark oil consumption
by RedOak. 02/23/19 12:14 PM
2001 Grand Cherokee Rear Diff Lube
by Plimbob. 02/23/19 12:13 PM
2005 Forester Upper Radiator Hose
by HowAboutThis. 02/23/19 12:05 PM
2016 Civic 2.0. Strange driving habits. Which oil?
by DEEPfrom1. 02/23/19 12:03 PM
Mercedes OM617 3k Chevron Delo
by gonesurfing. 02/23/19 11:38 AM
Water Pump Replacement Question
by Gebo. 02/23/19 10:55 AM
Maxx Oil ?
by lawnguy. 02/23/19 10:54 AM
Barrett, Beez1204, vmasse, zorba02, Ecodiesel
67326 Registered Users
111 registered members (2004tdigls, 2oldtommy, 240_Ed, 1WildPig, 2002 Maxima SE, 14 invisible), 1,986 guests, and 56 spiders.
Topics284,723
Posts4,875,824
Members67,326
Most Online2,548
Feb 16th, 2019
2 Stroke oil.....What's the difference ?? #4778258
06/05/18 01:56 PM
06/05/18 01:56 PM
ohio
fins Offline OP
fins  Offline OP
ohio
I wasn't sure which forum to post this in.........
I always thought 2 stroke oil was all the same, marine, chains saw, lawn mowers, motorcycle,, weed eaters etc....
What IS the Difference ??
Re: 2 Stroke oil.....What's the difference ?? [Re: fins] #4778294
06/05/18 02:32 PM
06/05/18 02:32 PM
Denmark
Motorsen Offline
Motorsen  Offline
Denmark
Lots of differences! Outboard engine is seawater cooled, thus running no more than 55C water temp. Outboard 2 stroke oil have ashless additives and have a lower viscosity due to the lower running temperature.
Motorsen
Re: 2 Stroke oil.....What's the difference ?? [Re: fins] #4778404
06/05/18 04:43 PM
06/05/18 04:43 PM
Slovenia EU
Kamele0N Offline
Kamele0N  Offline
Slovenia EU
2008 Toyota Yaris 1ND-TV 1.4 D4-D Elf FullTech FE 5w30
1997 Toyota Landcruiser KZJ95 3.0 TD Shell Rimula R6M 10w40
Re: 2 Stroke oil.....What's the difference ?? [Re: fins] #4778437
06/05/18 05:20 PM
06/05/18 05:20 PM
St. Louis, MO
Lawn_Care Offline
Lawn_Care  Offline
St. Louis, MO
I use Stihl Ultra 2-stroke oil in all my 2-stroke OPE. Never had an engine failure running this stuff at 50:1.
In fact - Stihl doubled my warranty back when I bought an FS-45 trimmer years ago just for buying a 6-pack of Stihl Ultra oil with my purchase. Been using that oil every since - even with other brands of 2-stroke equipment.
Only real difference is when you get into the Marine oils - as noted above.
True victory does not come from defeating an enemy. True victory comes from giving love and changing an enemies heart.
Re: 2 Stroke oil.....What's the difference ?? [Re: Kamele0N] #4778448
06/05/18 05:32 PM
06/05/18 05:32 PM
NJ
JLawrence08648 Offline
NJ
This was great. Anyone who has a Toro 2 cycle snowblower or any 2 cycle that requires TCW3, needs to use only TCW3! And tug cannot use TCW3 in a non TCW3 machine. This article explains it all.
Re: 2 Stroke oil.....What's the difference ?? [Re: fins] #4778615
06/05/18 08:48 PM
06/05/18 08:48 PM
South Eastern, CT
AMC Offline
AMC  Offline
South Eastern, CT
Or you can use this and there is no difference:
https://www.valvoline.com/our-products/motor-oil/multi-purpose-2stroke-engine-oil
It is both TC-W3 and Jaso-FB rated and works in all 2 stroke equipment. Air cooled, small equipment and water cooled, large marine equipment all the same. Autozone almost always has it in stock for about 6 bucks per quart. I may give it a try next time I need some 2 stroke oil.
18 Honda CR-V - Mobil-1 AFE 0w-20
17 Ram 1500 SLT - Napa Synthetic 5w-20
14 Yamaha Super Tenere - Mobil Delvac 15w-40
Re: 2 Stroke oil.....What's the difference ?? [Re: fins] #4778715
06/05/18 11:25 PM
06/05/18 11:25 PM
PR CA, USA
2strokeNorthstar Offline
PR CA, USA
I use Maxima oil in all my 2 strokes.
2001 F150 5.4L 140k miles
2013 Nissan Juke Nismo 80k
2000 Honda S2000 183k
1998 BMW 328i 170k
Re: 2 Stroke oil.....What's the difference ?? [Re: fins] #4778850
06/06/18 07:21 AM
06/06/18 07:21 AM
Port Orange, Florida
Panzerman Offline
Panzerman  Offline
I disagree. You do not want to use TCW3 oil in a air cooled two stroke. It leaves a hard carbon and siezes the rings. I very had several two strokes down and that was the case.
Use a TC rated two stroke oil with a FB/ FC or FD rating.
FD is the best rating.
2006 Dodge Ram 2500 Hemi 4x4
2016 Dodge Challenger Scat Pack
Re: 2 Stroke oil.....What's the difference ?? [Re: Panzerman] #4778882
06/06/18 07:52 AM
06/06/18 07:52 AM
NJ
NJ
Toro says to use only a TCW3 in their engines. Are you saying not to use TCW3 in their engines or the companies that say you must use TCW3 or only the engines that are not recommending TCW3?
Re: 2 Stroke oil.....What's the difference ?? [Re: fins] #4778933
06/06/18 09:03 AM
06/06/18 09:03 AM
Canada
Broo Offline
Broo  Offline
Canada
Nice to read, I didn't know there could be a difference. My only 2 stroke engines are my string trimmer and chainsaw. I use whichever 2 stroke oil is cheapest at Canadian Tire, usually Motomaster.
Re: 2 Stroke oil.....What's the difference ?? [Re: fins] #4778990
06/06/18 10:06 AM
06/06/18 10:06 AM
ohio
fins Offline OP
fins  Offline OP
ohio
So............ TCW3 in 2 cycle Marine Outboards
Regular 2 stoke oil in everything else........chainsaws, 2 stroke lawn mowers, trimmers, etc.
Moderated by  ekpolk
