Another Civic Down
by ctechbob - 07/06/20 01:25 AM
Garden Hose for Gasoline Transfer?
by viscous - 07/05/20 11:55 PM
Changing coolant-water ratio of 50-50 premix?
by TrustyAutos - 07/05/20 11:27 PM
ring terminals - really?
by DirtyOilGuy - 07/05/20 11:27 PM
Which oil is better out of these
by Bazza32 - 07/05/20 11:08 PM
Automatic transmission shift feel
by Spetz - 07/05/20 10:51 PM
Opinions On This Laptop
by BlueOvalFitter - 07/05/20 08:02 PM
Anyone else see Hamlin hood flap fly out?
by 555 - 07/05/20 07:54 PM
Husqvarna AWD with a Honda engine
by yeehaw1960 - 07/05/20 07:02 PM
Recommended car shipper?
by HawkeyeScott - 07/05/20 06:10 PM
My 2011 Sonata SE 2.0T
by strongt - 07/05/20 05:39 PM
Throwing in the towel on local clothing retailers
by Reddy45 - 07/05/20 05:09 PM
Castrol Edge vs Edge EP
by Gene K - 07/05/20 05:03 PM
Car related YouTube channels
by dishdude - 07/05/20 04:59 PM
Suspension Bushings Oil Resistant?
by TacoFergie - 07/05/20 03:43 PM
Building a solar generator
by BeerCan - 07/05/20 03:22 PM
Used CVT fluid in a power steering application
by mahanddeem - 07/05/20 02:06 PM
carms, Ben2, Turboman92, TrustyAutos, TacoFergie
71854 Registered Users
48 registered members (Astro14, blufeb95, Bazza32, BigCahuna, Best F100, ajchien, 7 invisible), 1,007 guests, and 24 spiders.
Topics307,469
Posts5,311,765
Members71,854
Peak Global Life Time-Is it really "Life Time" #4778105 06/05/18 11:51 AM
W
willbur Offline OP
W
Greetings-
What makes Peak Global Life Time coolant "Life Time". Is it really "Life Time", or is that just marketing? All other coolants specify a change frequency/mileage, but not this brew. I would think if its truly "Life Time", car manufactures' would be all over it.
Re: Peak Global Life Time-Is it really "Life Time" [Re: willbur] #4778146 06/05/18 12:49 PM
M
maverickfhs Offline
M
At least, I am sure there's nothing as 'lifetime'
2006 Civic EX 209K/AT
2006 Acura TSX 199K/AT
2007 Accord VP 154K/AT
Re: Peak Global Life Time-Is it really "Life Time" [Re: willbur] #4778147 06/05/18 12:50 PM
M
maverickfhs Offline
M
But subscribing to it
Re: Peak Global Life Time-Is it really "Life Time" [Re: willbur] #4778159 06/05/18 01:07 PM
SirTanon Offline
I suspect that the use of the phrase "Life Time" in this based on the following:
The coolant is a "super long-life" coolant, which an be used for a ridiculously long time. Add to that the term "Global" in the name, and you also add that it can be used in any vehicle. Your average consumer interprets that to mean that they can use it in any car they own without concern, an that they can leave it in pretty much 'forever', which since most (90+ percent) consumer car owners only keep their cars for 5 years or less means that for them, it essentially IS forever.
2013 Nissan Altima SV - 2.5 liter/CVT - 125,000mi
2014 Nissan Altima SL - 2.5 liter/CVT - 68,000mi
2010 Ford Fusion - 274k mi - SOLD
Re: Peak Global Life Time-Is it really "Life Time" [Re: willbur] #4778162 06/05/18 01:13 PM
SHOZ Offline
I use the Farm and Fleet long life universal. Made by Peak. Buy a case at a time and just about anytime the coolant gets drained for some reason new coolant goes in,long life or not.
2008 Hyundai Accent 1.6L 5 sp manual hatchback
2010 Hyundai Genesis Coupe Track 2L Turbo 6sp manual
Re: Peak Global Life Time-Is it really "Life Time" [Re: willbur] #4778177 06/05/18 01:32 PM
J
John_K Offline
J
My mechanic says lifetime means "until it fails because it needed new fluid." Applies here.
2009 Mercury Grand Marquis, 8 cyl auto, 98xxx miles, PU/Fram Ultra
2005 Hyundai Sonata, 4 cyl auto, 101xxx miles, Maxlife/OEM Filter
Current oil stash: 446 qts.
Re: Peak Global Life Time-Is it really "Life Time" [Re: willbur] #4778185 06/05/18 01:39 PM
SHOZ Offline
On my third set of 'Lifetime Windows' in my house over 35 years
Re: Peak Global Life Time-Is it really "Life Time" [Re: willbur] #4778212 06/05/18 01:59 PM
skyactiv Online Content
Online Content
That is the coolant I had in a 07' WRX I once owned. I bought the concentrated type and mixed it 50/50. Subaru was still using traditional coolant and called for the change interval at 30K miles or 30 months. I sold the car with 136K, only changing the coolant once and never had an issue.
Me: 18' Elantra Sport 6 speed manual
The rude guy that points out reality
Re: Peak Global Life Time-Is it really "Life Time" [Re: willbur] #4778213 06/05/18 01:59 PM
M
maxdustington Offline
M
Until the system needs to be serviced (water pump, heater core, hoses, thermostat), 100k KM max before one of those events.
You have to assume low mileage cars are more likely to get the real thing, "global" coolant is for emergencies where the system is probably going to get flushed. Or some high mileage beater that just gets generic coolant now.
99 Toyota Tercel CE 5EFE/C151
PUP 5W30/Ultra
Re: Peak Global Life Time-Is it really "Life Time" [Re: skyactiv] #4778275 06/05/18 03:15 PM
Online Content
Correction: Looking at my maintenance log on the PC, I did change the coolant again at 105K miles when I changed the timing belt.
Re: Peak Global Life Time-Is it really "Life Time" [Re: willbur] #4778440 06/05/18 06:22 PM
3
3800Series Offline
3
Life time means nothing unless it's specified. You could always call and ask them "whose life time" the life of the car? The life of my pet dog? My life?
You get the point.
Re: Peak Global Life Time-Is it really "Life Time" [Re: willbur] #4778487 06/05/18 07:28 PM
P
pbm Offline
P
My 2008 Corolla came with Toyota pink which is rated for 10 years/120K on the FF....I changed it out after 7 years and 75K to PGL....I just changed it again at 112K (and 4 years) using PGL (again).....I used distilled water both times so I'll probably go 6 or 7 years or until the car is sold.
So to answer your question....I don't think any coolant is 'LIFETIME" but some, like Toyota pink and PGL can go for 7 to 10 years and over 100K.
PS: I think that changing LL coolant every year or two is a waste and unnecessary...especially with cars with timing belts where the water pump gets changed every 80 or 90K. Every 4 or 5 years is fine with a LL (EL) coolant...IMO..
'Journalism is Dead'
Re: Peak Global Life Time-Is it really "Life Time" [Re: willbur] #4779464 06/06/18 06:45 PM
Sayjac Offline
Here's what Peak Old World says the term "Lifetime" means for PGL. First bullet point.
"Provides guaranteed 'lifetime' protection for as long as you own your vehicle when a complete cooling system flush and fill is performed and specified maintenance followed." Seems a reasonable explanation and definition imo.
https://peakauto.com/wp-content/uploads/2017/01/PEAK_Global_FS_spec_sheet_2015_noback_LORES.pdf
It's good for 'at least' as long as the long(est) service interval PHOATs and OATs like Dex, which is a long time. And no 2eha. There isn't a PC application that with a complete flush I wouldn't trust PGL as the AF. Using it now in an older Tacoma originally specing red LL. Almost 5 years interval now and original radiator.
PGL a good AF imo.
Re: Peak Global Life Time-Is it really "Life Time" [Re: willbur] #4779882 06/07/18 07:45 AM
W
willbur Offline OP
W
Sayjac-
They're slick with the wording- its "Life Time" if one does the required coolant changes/maintenance specified in the Owner's Manual, most likely 5 years. Big deal- any quality coolant can do this.
Its not a fill and forget coolant like its name suggests/implies (in my opinion).
Re: Peak Global Life Time-Is it really "Life Time" [Re: willbur] #4779918 06/07/18 08:33 AM
Sayjac Offline
I'd say it would be "slick" if they didn't give or hid their definition of what Lifetime meant for warranty purposes, imo. That said, I don't get caught up in the semantics of the name. More important, it's a good AF that in my observation is generally well respected in bitog and has been since I joined.
And not just any quality coolant is an extended life OAT AF with no 2eha (found in Dex and Dexclones/Prestone) making it suitable for use many applications.
I'd think anyone with some common sense AND knows how to read would realize the term Lifetime to be taken with a grain of salt.
