wemay
Site Donor 2023
Some here have said UOA don't tell you if wear is occurring, only the condition of the oil...
https://www.machinerylubrication.com/Read/29004/oil-analysis-benefits
"The levels of iron and aluminum can warn of piston and cylinder wear before a major failure occurs. Bearing wear rates can be determined and action taken before the crankshaft becomes badly scored. Fuel dilution, anti‑freeze leaks and water entry can be detected while they are still minor problems. The levels of contamination and combustion soot within the oil can indicate a restricted air intake system, ineffective oil filters, poor combustion or a rich air/fuel ratio."
