Barkeepers Friend
by jerseyguy123. 01/22/19 02:23 AM
Bag-in-a-box motor oils
by jtr990. 01/22/19 02:10 AM
Inventions of the 1950's - 1970's
by StevieC. 01/21/19 10:26 PM
Fireplace cleaners and price
by 97prizm. 01/21/19 10:23 PM
M1 0w40 extended oci??
by Pinoak. 01/21/19 09:46 PM
Best propane fireplace insert?
by SOHCman. 01/21/19 08:51 PM
Save 1/4 on gas!! Guaranteed!!
by Linctex. 01/21/19 08:50 PM
Funny names
by Chris142. 01/21/19 08:45 PM
Kendall vs Total Qaurtz
by zeke1985. 01/21/19 08:32 PM
Got a weird one - Helping a friend
by StevieC. 01/21/19 08:32 PM
Thanks 14Accent
by clinebarger. 01/21/19 08:07 PM
Mobil 1 5W30 C7 Z06
by PLRX. 01/21/19 07:40 PM
How cold is it? (Humor)
by StevieC. 01/21/19 07:13 PM
Slight performance decrease
by A_User55555. 01/21/19 06:54 PM
how to keep your vehicle battery...
by Char Baby. 01/21/19 06:31 PM
2012 to 2016 ford focus
by WhyMe. 01/21/19 06:30 PM
LHM anyone?
by mistersooty. 01/21/19 06:30 PM
Walmart Oil Changes.
by Bill7. 01/21/19 06:10 PM
Coolbreez1973, jmcast1127, DF8005, FT86dude11, RTSAllison
67008 Registered Users
26 registered members (DaHen, brianw, Char Baby, billt460, AurionX2, 6 invisible), 948 guests, and 46 spiders.
Topics296,961
Posts4,962,408
Members67,008
Most Online2,821
Jan 21st, 2019
Benefits of Oil Analysis -Machinery Lubrication #4777966
06/05/18 08:00 AM
06/05/18 08:00 AM
Kendall, FL
wemay Offline OP
wemay  Offline OP
Kendall, FL
Some here have said UOA don't tell you if wear is occurring, only the condition of the oil...
https://www.machinerylubrication.com/Read/29004/oil-analysis-benefits
"The levels of iron and aluminum can warn of piston and cylinder wear before a major failure occurs. Bearing wear rates can be determined and action taken before the crankshaft becomes badly scored. Fuel dilution, anti‑freeze leaks and water entry can be detected while they are still minor problems. The levels of contamination and combustion soot within the oil can indicate a restricted air intake system, ineffective oil filters, poor combustion or a rich air/fuel ratio."
18 Sportage 2.4L AWD:
Now: M1AP 5/20 + M1-104
Next: QSUD 5/30 + S2808XL
13 Santa Fe Sport 2.0T:
Now: PPEuroL 5/30 + OEM
Next: EDGE 5/40 + S2808XL
Re: Benefits of Oil Analysis -Machinery Lubrication [Re: wemay] #4778010
06/05/18 09:00 AM
06/05/18 09:00 AM
Michigan
ZZman Offline
ZZman  Offline
Michigan
I think most would agree that wear happens. I think they would agree analysis can show wear. However most would probably agree that it is hard to determine wear patterns to an exact level to determine what oils may be better or worse. Driving styles, mileage, dirt ingestion, driving style, idle time, cold starts, cold weather starts etc can all affect the numbers.
However a large abnormal reading or a spike can show a potential problem.
2003 Mercury Grand Marquis. PP HM 5w-30 and Fram Ultra
2008 Sebring Hardtop convertible. PP HM 5w-30 and Fram Ultra
2006 Kawasaki Vulcan 900 LT. Motul 7100 10w-40 and K&N
Re: Benefits of Oil Analysis -Machinery Lubrication [Re: wemay] #4778048
06/05/18 09:36 AM
06/05/18 09:36 AM
Ontario, Canada
OVERKILL Offline
OVERKILL  Offline
Ontario, Canada
I don't think that's accurately representing the consensus here, and certainly not what I've stated on the subject. What you've provided is consistent with what Doug Hillary has posted, which is that UOA's can provide valuable data to identify intake tract leaks, coolant ingress, fuel dilution...etc. When trended, significant departures from the trends in wear; that is, abnormal outliers, can indicate a mechanical problem worth investigation.
Each piece of equipment will have its own "wear rate" and engines within the same family will generally have similar wear rates. When your PPM per 1K miles changes significantly for a given metal, this can be cause for concern.
Some examples:
- GM LS1 trended analysis establishes 5ppm/1K miles (25ppm on a 5,000 mile OCI) as normal for Iron. Next UOA shows 75ppm on the same interval, 3x the wear rate. Would you go looking for something?
- Subaru H6 trended analysis establishes 0.25ppm/1K miles as normal for aluminum. Next UOA shows 10ppm on a 5K interval and 25ppm silicon. Would you go looking for something, and if so, what?
- Ford Modular trended analysis establishes 0.2ppm/1K miles as normal for aluminum. Next UOA shows 20ppm on a 5K interval as well as 10ppm of tin. Everything else seems normal. Would you go looking for something and if so, what?
- GM LT1 trended analysis establishes 0.2ppm/1K miles as normal for lead. Next UOA shows 20ppm on a 5K interval with copper pushing up slightly as well. Would you go looking for something and if so, what?
- Ford 302HO trended analysis establishes 1ppm/1K miles (5ppm on a 5,000 mile OCI) as normal for Iron. Next UOA shows 10ppm in the same interval, you changed oil brands. Would you go looking for something, if so what, and why?
2018 RAM 1500 Big Horn EcoDiesel
2016 Grand Cherokee SRT
Re: Benefits of Oil Analysis -Machinery Lubrication [Re: wemay] #4778108
06/05/18 10:56 AM
06/05/18 10:56 AM
Kendall, FL
wemay Offline OP
wemay  Offline OP
Kendall, FL
Got it.
I don't remember who stated it but it has been said a few times by different members. Maybe a misunderstanding on my part.
Every industry related piece of literature I've read unequivocally states that wear is gleaned from trending UOA. So yeah, surly my misunderstanding.
Re: Benefits of Oil Analysis -Machinery Lubrication [Re: wemay] #4778115
06/05/18 11:09 AM
06/05/18 11:09 AM
Ontario, Canada
OVERKILL Offline
OVERKILL  Offline
Ontario, Canada
Got it.
Yes, you can glean what "normal" wear, within a range, is for a piece of equipment and then watch for departures from that trend. What you can't do is run Oil A and then Oil B and determine which oil is "better" based on small variances due to the narrow range of particles sampled, chelation and other factors. UOA's simply aren't precise enough for that usage, which is outside their intended purpose anyways, and there are far too many variables in play to allow any sort of reasonable inference based on that approach.
Re: Benefits of Oil Analysis -Machinery Lubrication [Re: OVERKILL] #4778128
06/05/18 11:24 AM
06/05/18 11:24 AM
Kendall, FL
wemay Offline OP
wemay  Offline OP
Kendall, FL
Got it.
Yes, to establish any trend one would need to use the same oil/OCI throughout an established period of time. Jumping from one oil to another may throw things off.
Re: Benefits of Oil Analysis -Machinery Lubrication [Re: wemay] #4845716
08/20/18 06:23 PM
08/20/18 06:23 PM
pa
benjy Offline
benjy  Offline
pa
you can bet the cheap oil analysis most get DOES NOT compare with oils checked for very $$$$$ machinery that use a LOT of oil for as long as its still good!!
