$25 Pennzoil rebate on 1 case of 6 qts
by Ride_Red - 02/20/20 08:28 AM
Ratcheting Wrenches
by Redright9 - 02/20/20 07:27 AM
Buick Regal 2.0T Ecotec Engines
by ET16 - 02/20/20 06:34 AM
Fuchs Titan GT1 Evo 0w20 LL014FE
by kr_bitog - 02/20/20 05:46 AM
Tungsten Ravenol
by V10 - 02/20/20 01:37 AM
Can an SSD make this much difference?
by 14Accent - 02/20/20 01:14 AM
The Big Oil Change - Sinclair Oil 1960's
by StevieC - 02/19/20 10:47 PM
A new topper for my truck
by HM12460 - 02/19/20 10:12 PM
AAP/Carquest platinum pads/rotors
by parshisa - 02/19/20 10:03 PM
Apple watch - high data usage
by Quattro Pete - 02/19/20 09:46 PM
Gas in the 80's vs Today
by alcyon - 02/19/20 09:34 PM
1993 Hilux 3.0 diesel
by Mayberryminitruc - 02/19/20 08:58 PM
WrightGrip 2.0 wrench set
by spasm3 - 02/19/20 08:57 PM
Don't forget about your clutch fluid
by Number_35 - 02/19/20 08:40 PM
Financial Advice
by cpayne5 - 02/19/20 08:28 PM
2003 Accord 6 Cylinder EX No start
by Gito - 02/19/20 08:03 PM
Oil Advice For 1990s Era Yamaha ATVs
by DockHoliday - 02/19/20 07:42 PM
2 quarts supertech 0w-20 for $4.56
by sjstangman - 02/19/20 07:35 PM
Mayberryminitruc, DaiwaGuy, Gunboatmac, Mad_Max_Sam, 24Carat
70756 Registered Users
101 registered members (28oz, 14Accent, ABomb369, 330indy, 64bawagon, 1foxracing, 9 invisible), 1,883 guests, and 15 spiders.
Topics301,694
Posts5,200,680
Members70,756
Opinions on diff fluid change with mityvac? #4777159 06/04/18 10:39 AM
M
monster1 Offline OP
M
Hey guys, I'm wanting to change my diff gear oil in my 04 2500 5.9l cummins 4x4. Should I completely pull the covers or will using a mityvac suck and swap be ok? Odometer is about 75k. First service.
Re: Opinions on diff fluid change with mityvac? [Re: monster1] #4777181 06/04/18 11:11 AM
N
nthach Offline
N
If you can get the Mityvac to pick up from the bottom of the diff, I think it should work but it could struggle with the thicker gear oil. I would try it with the diff oil warm.
Pulling the diff cover isn't a bad idea if not messy. I would go that way to avoid any drama. If you were planning on swapping diff covers to a Mag-Hytec or similar with a drain plug it's also a good time.
Re: Opinions on diff fluid change with mityvac? [Re: monster1] #4777225 06/04/18 11:43 AM
229 Offline
Slow but better than not refreshing. Pull the covers so you can wipe out the slime. Use Mopar gear RTV or compatible black gear oil RTV silicone.
Re: Opinions on diff fluid change with mityvac? [Re: monster1] #4777249 06/04/18 12:09 PM
M
monster1 Offline OP
M
I'll pull the covers. Thanks.
Re: Opinions on diff fluid change with mityvac? [Re: monster1] #4777397 06/04/18 03:06 PM
M
monster1 Offline OP
M
Pulled the cover to the rear. Gear oil was dark. But no shavings and everything was really clean. Put in 3 quarts of Lucas full synthetic 75w-90 and tightened everything back up. I think the front diff will wait for now since the rear was so clean. Too dang hot for me to be working in the sun.
Re: Opinions on diff fluid change with mityvac? [Re: monster1] #4777405 06/04/18 03:10 PM
J
JEL01 Offline
J
Good on you for taking care of it,
You are now ahead of 99% of other drivers, BITOGers excluded smile
Cars I maintain:
02 Mercedes CLK430
09 Honda Accord V6
13 Lexus RX350 AWD
02 Toyota Tundra 4x4
18 Lexus GX460
Re: Opinions on diff fluid change with mityvac? [Re: monster1] #4777424 06/04/18 03:27 PM
B
Billy_D Offline
B
I donít bother pulling the cover on my truck. I just use an oil extractor every 40k miles. The process is painfully slow.
Re: Opinions on diff fluid change with mityvac? [Re: monster1] #4777439 06/04/18 03:45 PM
demarpaint Offline
If you don't have a drain plug, that's what I'd do. thumbsup
God Bless Our Troops
Re: Opinions on diff fluid change with mityvac? [Re: monster1] #4778998 06/06/18 10:13 AM
M
monster1 Offline OP
M
I towed my 4k lb boat yesterday on a 50 mile round trip. I know this is nothing for a 3/4 ton truck but the lazer thermometer showed the differential running at 150 degrees in 100 degree heat. Looks like that Lucas synthetic gear oil does it's job. I was a bit concerned I made a wring choice if lubricants because it's not a very popular product as far as the internet is concerned.
Re: Opinions on diff fluid change with mityvac? [Re: monster1] #4779556 06/06/18 07:05 PM
Z
zeng Offline
Z
150F diff temperature towing is fantastic for Lucas 75W90 with a high [email protected]*C of 142 cSt.
