JLR 0w-20w standard Huh????
by Local Color - 01/27/20 11:44 AM
Effects of increasing engine RPM?
by Avery4 - 01/27/20 11:09 AM
New C8-R Vettes at Rolex 24
by racin4ds - 01/27/20 10:39 AM
Thoughts on redline?
by BTLew81 - 01/27/20 10:15 AM
Yak trax
by John_Conrad - 01/27/20 10:00 AM
Castrol GTX 20w50
by VQLT - 01/27/20 09:33 AM
Mevotech Terrain Tought ttx?
by buck91 - 01/27/20 08:54 AM
House electric questions
by supton - 01/27/20 08:37 AM
How an automatic transmission works
by supton - 01/27/20 08:08 AM
AC Delco UPF48R and UPF64R $1.50 rebate at Rock Auto
by Snagglefoot - 01/27/20 07:15 AM
Netgear Nighthawk M1 and Router setup
by Tribe21 - 01/27/20 06:24 AM
Alignment questions: is camber/caster not usually touched?
by FordBroncoVWJeta - 01/26/20 10:47 PM
Pricing used tires
by PumpPusher - 01/26/20 10:21 PM
STP Motor Oil at HF
by kstanf150 - 01/26/20 10:07 PM
9 years for the 4 cylinder Eco-boost
by Snagglefoot - 01/26/20 09:39 PM
So I picked this up..
by Mad_Hatter - 01/26/20 08:49 PM
New here and question about oil.
by Sunstealth - 01/26/20 08:42 PM
Looking for a car for $4k or less
by SVTCobra - 01/26/20 08:09 PM
Burner718, masstrnsprtcmplx, tampasaint, rdmjone, BigGeo
70537 Registered Users
110 registered members (Alfred_B, 2015_PSD, 87sammy, 1978elcamino, 2strokeNorthstar, 5 invisible), 2,741 guests, and 18 spiders.
Topics300,628
Posts5,179,732
Members70,537
Opinions on diff fluid change with mityvac? #4777159 06/04/18 10:39 AM
M
monster1 Offline OP
M
Hey guys, I'm wanting to change my diff gear oil in my 04 2500 5.9l cummins 4x4. Should I completely pull the covers or will using a mityvac suck and swap be ok? Odometer is about 75k. First service.
Re: Opinions on diff fluid change with mityvac? [Re: monster1] #4777181 06/04/18 11:11 AM
N
nthach Offline
N
If you can get the Mityvac to pick up from the bottom of the diff, I think it should work but it could struggle with the thicker gear oil. I would try it with the diff oil warm.
Pulling the diff cover isn't a bad idea if not messy. I would go that way to avoid any drama. If you were planning on swapping diff covers to a Mag-Hytec or similar with a drain plug it's also a good time.
Re: Opinions on diff fluid change with mityvac? [Re: monster1] #4777225 06/04/18 11:43 AM
229 Offline
Slow but better than not refreshing. Pull the covers so you can wipe out the slime. Use Mopar gear RTV or compatible black gear oil RTV silicone.
Re: Opinions on diff fluid change with mityvac? [Re: monster1] #4777249 06/04/18 12:09 PM
M
monster1 Offline OP
M
I'll pull the covers. Thanks.
Re: Opinions on diff fluid change with mityvac? [Re: monster1] #4777397 06/04/18 03:06 PM
M
monster1 Offline OP
M
Pulled the cover to the rear. Gear oil was dark. But no shavings and everything was really clean. Put in 3 quarts of Lucas full synthetic 75w-90 and tightened everything back up. I think the front diff will wait for now since the rear was so clean. Too dang hot for me to be working in the sun.
Re: Opinions on diff fluid change with mityvac? [Re: monster1] #4777405 06/04/18 03:10 PM
J
JEL01 Offline
J
Good on you for taking care of it,
You are now ahead of 99% of other drivers, BITOGers excluded smile
Cars I maintain:
02 Mercedes CLK430
09 Honda Accord V6
13 Lexus RX350 AWD
02 Toyota Tundra 4x4
18 Lexus GX460
Re: Opinions on diff fluid change with mityvac? [Re: monster1] #4777424 06/04/18 03:27 PM
B
Billy_D Offline
B
I donít bother pulling the cover on my truck. I just use an oil extractor every 40k miles. The process is painfully slow.
Re: Opinions on diff fluid change with mityvac? [Re: monster1] #4777439 06/04/18 03:45 PM
demarpaint Offline
If you don't have a drain plug, that's what I'd do. thumbsup
God Bless Our Troops
Re: Opinions on diff fluid change with mityvac? [Re: monster1] #4778998 06/06/18 10:13 AM
M
monster1 Offline OP
M
I towed my 4k lb boat yesterday on a 50 mile round trip. I know this is nothing for a 3/4 ton truck but the lazer thermometer showed the differential running at 150 degrees in 100 degree heat. Looks like that Lucas synthetic gear oil does it's job. I was a bit concerned I made a wring choice if lubricants because it's not a very popular product as far as the internet is concerned.
Re: Opinions on diff fluid change with mityvac? [Re: monster1] #4779556 06/06/18 07:05 PM
Z
zeng Offline
Z
150F diff temperature towing is fantastic for Lucas 75W90 with a high [email protected]*C of 142 cSt.
