Please explain beta ratios. I'm lost.
by tony1679 - 10/16/19 12:45 AM
Is sump pumps necessary?
by joy786 - 10/16/19 12:18 AM
Sensen Struts - Any Good?
by Nick1994 - 10/15/19 11:54 PM
Quiet Oil--Cause?
by jimbrewer - 10/15/19 11:05 PM
IFJF (Chinese Magnefine)
by mcwilly - 10/15/19 10:40 PM
Let the truck warm up?
by Dragon44 - 10/15/19 10:14 PM
6.4L Powerstroke under the knife
by clinebarger - 10/15/19 10:01 PM
Alternatives to SAE 90 gear oil?
by qwerty11 - 10/15/19 09:34 PM
2010 Infiniti G37x Feedback?
by maverickfhs - 10/15/19 09:30 PM
M1 0W20 High Mil 40C visc
by Silver - 10/15/19 09:14 PM
Havoline 6 Qt Box $11.99 / Free Shipping
by Mr_Luke - 10/15/19 09:02 PM
Oil Recommendation for LS7 Z06 Street & Track Usage
by randomhero439 - 10/15/19 08:46 PM
QSUD 0W20 in 5qt jugs
by faltic - 10/15/19 08:41 PM
Mission Impossible: The Giraffe
by MONKEYMAN - 10/15/19 08:20 PM
Alternative to 10w-40 in Rotella?
by qwerty11 - 10/15/19 08:18 PM
Oil Changes and Ramps
by perfect_oil - 10/15/19 07:50 PM
Where to use T4 15W-40 in a 10W-30 World?
by Astro_Guy - 10/15/19 07:37 PM
How Does Toyota Do It?
by lovcom - 10/15/19 07:29 PM
Tar, cast71, bamadog1, jrogahn, DeathByNissan55
69571 Registered Users
37 registered members (4WD, amng04, aleneros, Antimatter, billt460, 2 invisible), 878 guests, and 20 spiders.
Topics296,028
Posts5,089,552
Members69,571
Most Online3,532
Jul 30th, 2019
Opinions on diff fluid change with mityvac? #4777159 06/04/18 11:39 AM
M
monster1 Offline OP
M
Hey guys, I'm wanting to change my diff gear oil in my 04 2500 5.9l cummins 4x4. Should I completely pull the covers or will using a mityvac suck and swap be ok? Odometer is about 75k. First service.
Re: Opinions on diff fluid change with mityvac? [Re: monster1] #4777181 06/04/18 12:11 PM
N
nthach Offline
N
If you can get the Mityvac to pick up from the bottom of the diff, I think it should work but it could struggle with the thicker gear oil. I would try it with the diff oil warm.
Pulling the diff cover isn't a bad idea if not messy. I would go that way to avoid any drama. If you were planning on swapping diff covers to a Mag-Hytec or similar with a drain plug it's also a good time.
Re: Opinions on diff fluid change with mityvac? [Re: monster1] #4777225 06/04/18 12:43 PM
229 Offline
Slow but better than not refreshing. Pull the covers so you can wipe out the slime. Use Mopar gear RTV or compatible black gear oil RTV silicone.
Re: Opinions on diff fluid change with mityvac? [Re: monster1] #4777249 06/04/18 01:09 PM
M
monster1 Offline OP
M
I'll pull the covers. Thanks.
Re: Opinions on diff fluid change with mityvac? [Re: monster1] #4777397 06/04/18 04:06 PM
M
monster1 Offline OP
M
Pulled the cover to the rear. Gear oil was dark. But no shavings and everything was really clean. Put in 3 quarts of Lucas full synthetic 75w-90 and tightened everything back up. I think the front diff will wait for now since the rear was so clean. Too dang hot for me to be working in the sun.
Re: Opinions on diff fluid change with mityvac? [Re: monster1] #4777405 06/04/18 04:10 PM
J
JEL01 Offline
J
Good on you for taking care of it,
You are now ahead of 99% of other drivers, BITOGers excluded smile
Cars I maintain:
02 Mercedes CLK430-Edge 0w40
05 Honda Accord V6-Maxlife 5w30
13 Lexus RX350 AWD-M1 AFE 0w20
02 Toyota Tundra 4x4 M1 5w30
Re: Opinions on diff fluid change with mityvac? [Re: monster1] #4777424 06/04/18 04:27 PM
B
Billy_D Offline
B
I donít bother pulling the cover on my truck. I just use an oil extractor every 40k miles. The process is painfully slow.
Re: Opinions on diff fluid change with mityvac? [Re: monster1] #4777439 06/04/18 04:45 PM
demarpaint Offline
If you don't have a drain plug, that's what I'd do. thumbsup
God Bless Our Troops
Re: Opinions on diff fluid change with mityvac? [Re: monster1] #4778998 06/06/18 11:13 AM
M
monster1 Offline OP
M
I towed my 4k lb boat yesterday on a 50 mile round trip. I know this is nothing for a 3/4 ton truck but the lazer thermometer showed the differential running at 150 degrees in 100 degree heat. Looks like that Lucas synthetic gear oil does it's job. I was a bit concerned I made a wring choice if lubricants because it's not a very popular product as far as the internet is concerned.
Re: Opinions on diff fluid change with mityvac? [Re: monster1] #4779556 06/06/18 08:05 PM
Z
zeng Offline
Z
150F diff temperature towing is fantastic for Lucas 75W90 with a high [email protected]*C of 142 cSt.
