[Cut Open] Motorcraft FL500S - 5003 miles
by DuckRyder. 02/23/19 05:08 PM
Does Kia & Hundai use same motors?
by tc1446. 02/23/19 05:07 PM
Extreme fuel dilution
by BigShug681. 02/23/19 04:52 PM
Nine PH3600-size filters FS
by SubieRubyRoo. 02/23/19 04:45 PM
2003 Accord 2.4L Valve train pics
by WagonWheel. 02/23/19 04:24 PM
Leaky FL400s
by jongies3. 02/23/19 03:55 PM
Fram Ultra with Filter Mag pics
by ZZman. 02/23/19 03:39 PM
Which 0w20 meets VW 508.00?
by 53' Stude. 02/23/19 03:28 PM
RockAuto Injectors - Return / Weird
by StevieC. 02/23/19 02:23 PM
03 Nissan Maxima stalls uphill.
by LeakySeals. 02/23/19 01:47 PM
Delvac Rebate?
by 1JZ_E46. 02/23/19 01:23 PM
Oil recommendation for Audi turbo engine
by zorba02. 02/23/19 12:41 PM
Jeep Cherokee 2.4L oil consumption
by RedOak. 02/23/19 12:14 PM
2001 Grand Cherokee Rear Diff Lube
by Plimbob. 02/23/19 12:13 PM
2005 Forester Upper Radiator Hose
by HowAboutThis. 02/23/19 12:05 PM
2016 Civic 2.0. Strange driving habits. Which oil?
by DEEPfrom1. 02/23/19 12:03 PM
Mercedes OM617 3k Chevron Delo
by gonesurfing. 02/23/19 11:38 AM
snapy907, Barrett, Beez1204, vmasse, zorba02
67327 Registered Users
102 registered members (10WSmuckers, 2002 Maxima SE, 1WildPig, 2004tdigls, 240_Ed, 12 invisible), 1,974 guests, and 52 spiders.
Topics284,724
Posts4,875,829
Members67,327
Most Online2,548
Feb 16th, 2019
Dexos1 vs Dexos2 #4777369
06/04/18 02:44 PM
06/04/18 02:44 PM
Azerbaijan
NICAT Offline OP
NICAT  Offline OP
Azerbaijan
Hi.
The car is, Daewoo Nexia 1.5L, G15MF Engine, 2006. According to wikipedia, the engine was manufactured between 1996-2000.
I am offered 2 different versions of Motul 5w30. One with dexos1 and the other with dexos2 specification.
Can you please say the difference between dexos1 and dexos2 specification? And which one should i use ?
Regards.
Re: Dexos1 vs Dexos2 [Re: NICAT] #4777406
06/04/18 03:11 PM
06/04/18 03:11 PM
New York
pbm Offline
pbm  Offline
New York
I think dexos2 is for diesels.....dexos1 for gassers (aka: petrol)....dexos1 gen2 for GDI turbo gassers....I'd use the dexos1 in your case.
'Journalism is Dead'
Re: Dexos1 vs Dexos2 [Re: NICAT] #4777411
06/04/18 03:13 PM
06/04/18 03:13 PM
San Rafael, CA
dogememe Offline
dogememe  Offline
San Rafael, CA
Dexos1 is for gasoline engines, Dexos2 for diesel. Dexos1Gen2 is the latest version of Dexos1.
2010 Ford Escape 2.5 ~94K Miles: Royal Purple 5W-30
2008 Ford Crown Vic P71 4.6 ~167K Miles: AMSOIL SS 0W-30
1995 Chevy Silverado 5.7 ~277K Miles: Delo 10W-30
Re: Dexos1 vs Dexos2 [Re: pbm] #4777416
06/04/18 03:21 PM
06/04/18 03:21 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
Dexos 2 is spec for all gassers in some if not all parts of Europe. It has a higher HTHS and is superior to fuel efficient Dexos 1.
Use Dexos 2 in your area.
Re: Dexos1 vs Dexos2 [Re: dogememe] #4777467
06/04/18 04:08 PM
06/04/18 04:08 PM
In the shop
53' Stude Offline
53' Stude  Offline
In the shop
Correct, Trav is incorrect for.U.S.A. stuff smile
Re: Dexos1 vs Dexos2 [Re: NICAT] #4777493
06/04/18 04:53 PM
06/04/18 04:53 PM
WA
Brigadier Offline
Brigadier  Offline
WA
Seems to me dexos2 would be better in a gasser than d1G2 based on this
I have often pondered this question myself.
2017 Hyundai Santa Fe SE, 3.3L, AWD, QSUD 5w30, OEM filter, Hy-per Lube ZRA
https://www.pure-gas.org/ << Wake up your engine!!
Where the stars and stripes and the eagle fly
Re: Dexos1 vs Dexos2 [Re: 53' Stude] #4777537
06/04/18 05:44 PM
06/04/18 05:44 PM
Trav Offline
Trav  Offline
Since when did Azerbaijan where the OP is become part of the USA? BTW it is for gasoline engines with the API SN rating.
https://www.amazon.com/ACDelco-88865157-Dexos2-5W-30-Motor/dp/B008BZS7CE
Re: Dexos1 vs Dexos2 [Re: Brigadier] #4777541
06/04/18 05:46 PM
06/04/18 05:46 PM
Trav Offline
Trav  Offline
I will take lower piston deposits than a minuscule MPG increase any day.
Re: Dexos1 vs Dexos2 [Re: NICAT] #4777801
06/04/18 10:52 PM
06/04/18 10:52 PM
downhureSW
nike360baller Offline
downhureSW
I've been seeing all these thread from the evil empire themselves, Exxon Mobil, that their oils were meeting Dexos spec as far back as 2010, you know what, I'm calling bologna.
The 0w-20 weight and viscosity oils DO NOT BURN A DROP! How shear stable is this oil and better than the 30 weights.
Re: Dexos1 vs Dexos2 [Re: nike360baller] #4777808
06/04/18 11:09 PM
06/04/18 11:09 PM
Trav Offline
Trav  Offline
Don't do that, the telephone rates to Italy will kill you. What do the Italians know about Mobil 1 anyway.
Re: Dexos1 vs Dexos2 [Re: NICAT] #4777889
06/05/18 05:51 AM
06/05/18 05:51 AM
Oakville, Ontario
Patman Offline
Patman  Offline
Oakville, Ontario
I prefer the higher HTHS and lower sulphated ash of a dexos2 rated oil for my Corvette
2018 Corvette, 9k, M1 ESP Formula 5w30 & NAPA Gold
2006 Civic EX Coupe, 148k, PUP 5w20 & Fram Ultra
2010 BMW 328i X-Drive,111k, GC 0w40 & Fram Ultra
Re: Dexos1 vs Dexos2 [Re: Trav] #4778560
06/05/18 07:46 PM
06/05/18 07:46 PM
Regina, Saskatchewan, Canada
Garak Offline
Garak  Offline
I'd agree with Trav, unless the gasoline is very poor there. If it's ULSG, dexos2 will work fine. If there is no ULSG, dexos1 would work, but A3/B4 might be a better option.
Plain, simple Garak.
Re: Dexos1 vs Dexos2 [Re: Garak] #4779148
06/06/18 12:46 PM
06/06/18 12:46 PM
Trav Offline
Trav  Offline
I thought Albania joined the EU with the 10ppm sulfur limit but if not definitely an A3/B4 oil would be great and preferable to Dexos 1.
Re: Dexos1 vs Dexos2 [Re: Trav] #4779372
06/06/18 04:11 PM
06/06/18 04:11 PM
Garak Offline
Garak  Offline
I would think so, too, that they'd be on ULSG, but I thought it might be an issue worthy of consideration, just in case.
Re: Dexos1 vs Dexos2 [Re: NICAT] #4779623
06/06/18 07:58 PM
06/06/18 07:58 PM
Monroe, WA
KevinP Offline
KevinP  Offline
Monroe, WA
I love those spider web graphs.
Moderated by  ekpolk
