Seeking Battery Charger Advice
by lancerplayer - 11/13/19 12:46 PM
2019 Consumer Reports Tire Tests
by SubLGT - 11/13/19 11:07 AM
2020 Camaro LT1 V8, Wow.
by dareo - 11/13/19 11:01 AM
NEW Mobil EV
by buster - 11/13/19 11:00 AM
Recommend A Good Light Duty Snow Boot
by Dwight_Frye - 11/13/19 10:31 AM
Oil difference between cruiser and Superbike
by devarshi84 - 11/13/19 10:31 AM
Stink in cabinets under kitchen sink!
by Blue_Goose - 11/13/19 10:11 AM
Front Suspension Work: The Death of a Vehicle?
by CrackyWainwright - 11/13/19 10:00 AM
Will a CV half shaft make noise in 2WD on a 4WD?
by dlundblad - 11/13/19 09:41 AM
Are the new CR-V's really that terrible?
by cwilliamsws6 - 11/13/19 09:34 AM
Proper oil to use in vintage motorcycles
by Crampfan - 11/13/19 09:30 AM
Do You Fly the BITOG Flag?
by ARCOgraphite - 11/13/19 08:42 AM
Boat question, but not lubrication related
by OVERKILL - 11/13/19 07:42 AM
Gifted a 2007 Impala
by 14Accent - 11/12/19 11:02 PM
Premium vs. Budget Snow tires
by edyvw - 11/12/19 10:11 PM
Range Rover 5.0 oil & BG MOA?
by xmreeves - 11/12/19 09:34 PM
Stalling and difficult restart problem
by RDMgr - 11/12/19 09:26 PM
Shying Away From Havoline 5w30
by Mr_Luke - 11/12/19 08:00 PM
New Way To Wash A Car
by buster - 11/12/19 07:52 PM
smokinhiro, iamrobertkrogh, Hombre909, DeLong, Scuder
69842 Registered Users
106 registered members (10ecfarmer, 53' Stude, Andrei, Aero540T, Aichiguy, 11 invisible), 2,346 guests, and 22 spiders.
Topics297,353
Posts5,113,874
Members69,842
Most Online3,589
Nov 2nd, 2019
Opinions on diff fluid change with mityvac? #4777159 06/04/18 10:39 AM
M
monster1 Offline OP
M
Hey guys, I'm wanting to change my diff gear oil in my 04 2500 5.9l cummins 4x4. Should I completely pull the covers or will using a mityvac suck and swap be ok? Odometer is about 75k. First service.
Re: Opinions on diff fluid change with mityvac? [Re: monster1] #4777181 06/04/18 11:11 AM
N
nthach Online Content
Online Content
N
If you can get the Mityvac to pick up from the bottom of the diff, I think it should work but it could struggle with the thicker gear oil. I would try it with the diff oil warm.
Pulling the diff cover isn't a bad idea if not messy. I would go that way to avoid any drama. If you were planning on swapping diff covers to a Mag-Hytec or similar with a drain plug it's also a good time.
Re: Opinions on diff fluid change with mityvac? [Re: monster1] #4777225 06/04/18 11:43 AM
229 Offline
Slow but better than not refreshing. Pull the covers so you can wipe out the slime. Use Mopar gear RTV or compatible black gear oil RTV silicone.
Re: Opinions on diff fluid change with mityvac? [Re: monster1] #4777249 06/04/18 12:09 PM
M
monster1 Offline OP
M
I'll pull the covers. Thanks.
Re: Opinions on diff fluid change with mityvac? [Re: monster1] #4777397 06/04/18 03:06 PM
M
monster1 Offline OP
M
Pulled the cover to the rear. Gear oil was dark. But no shavings and everything was really clean. Put in 3 quarts of Lucas full synthetic 75w-90 and tightened everything back up. I think the front diff will wait for now since the rear was so clean. Too dang hot for me to be working in the sun.
Re: Opinions on diff fluid change with mityvac? [Re: monster1] #4777405 06/04/18 03:10 PM
J
JEL01 Offline
J
Good on you for taking care of it,
You are now ahead of 99% of other drivers, BITOGers excluded smile
Cars I maintain:
02 Mercedes CLK430
09 Honda Accord V6
13 Lexus RX350 AWD
02 Toyota Tundra 4x4
18 Lexus GX460
Re: Opinions on diff fluid change with mityvac? [Re: monster1] #4777424 06/04/18 03:27 PM
B
Billy_D Offline
B
I donít bother pulling the cover on my truck. I just use an oil extractor every 40k miles. The process is painfully slow.
Re: Opinions on diff fluid change with mityvac? [Re: monster1] #4777439 06/04/18 03:45 PM
demarpaint Offline
If you don't have a drain plug, that's what I'd do. thumbsup
God Bless Our Troops
Re: Opinions on diff fluid change with mityvac? [Re: monster1] #4778998 06/06/18 10:13 AM
M
monster1 Offline OP
M
I towed my 4k lb boat yesterday on a 50 mile round trip. I know this is nothing for a 3/4 ton truck but the lazer thermometer showed the differential running at 150 degrees in 100 degree heat. Looks like that Lucas synthetic gear oil does it's job. I was a bit concerned I made a wring choice if lubricants because it's not a very popular product as far as the internet is concerned.
Re: Opinions on diff fluid change with mityvac? [Re: monster1] #4779556 06/06/18 07:05 PM
Z
zeng Offline
Z
150F diff temperature towing is fantastic for Lucas 75W90 with a high [email protected]*C of 142 cSt.
