Cuts on tire sidewall
by mclasser - 11/17/19 03:19 PM
Hyundai Theta II Engine in Newer Years
by smc733 - 11/17/19 02:41 PM
Walmart deals
by Deere John - 11/17/19 02:33 PM
Grumpy Kid
by wings&wheels - 11/17/19 01:57 PM
h9/95R FLA Batteries
by TXCarGeek - 11/17/19 01:40 PM
Preventative parking brake service
by Donald - 11/17/19 01:26 PM
Should I run an AC Delco Ultraguard gold?
by JHZR2 - 11/17/19 01:13 PM
Ford Ecoboost 400 at Homestead Miami Speedway
by bdcardinal - 11/17/19 01:08 PM
Strut mount, Moog vs KYB?
by jbutch - 11/17/19 01:07 PM
Is bar and chain oil hard on rubber?
by jqgz - 11/17/19 12:53 PM
TSC - Mobil Delvac $10.99
by Greg L - 11/17/19 12:42 PM
Wifi Thermostats
by FA_WRX - 11/17/19 10:33 AM
Test drove a few trucks. Ram Pentstar V6?
by dja4260 - 11/17/19 10:15 AM
2010 Corolla LE Opinions
by maverickfhs - 11/17/19 10:06 AM
2019 Toyota Highlander LOTS of metal flakes
by Mathew_Boss - 11/17/19 09:46 AM
Blaster Sidekick
by buster - 11/17/19 09:27 AM
Microwave time when microwaving 2 things at once?
by atikovi - 11/17/19 07:28 AM
2018 Nissan Rogue CVT @ 30k
by jcwhidby - 11/17/19 06:44 AM
gnouhp, tiblow, Gruenmeister, ZieloElo, Eisen77
69893 Registered Users
105 registered members (ARCOgraphite, Alfred_B, 4WD, 2010Civic, askani79705, Alchemy1, 10 invisible), 2,579 guests, and 25 spiders.
Topics297,551
Posts5,117,840
Members69,893
Most Online3,589
Nov 2nd, 2019
Opinions on diff fluid change with mityvac? #4777159 06/04/18 10:39 AM
M
monster1 Offline OP
M
Hey guys, I'm wanting to change my diff gear oil in my 04 2500 5.9l cummins 4x4. Should I completely pull the covers or will using a mityvac suck and swap be ok? Odometer is about 75k. First service.
Re: Opinions on diff fluid change with mityvac? [Re: monster1] #4777181 06/04/18 11:11 AM
N
nthach Offline
N
If you can get the Mityvac to pick up from the bottom of the diff, I think it should work but it could struggle with the thicker gear oil. I would try it with the diff oil warm.
Pulling the diff cover isn't a bad idea if not messy. I would go that way to avoid any drama. If you were planning on swapping diff covers to a Mag-Hytec or similar with a drain plug it's also a good time.
Re: Opinions on diff fluid change with mityvac? [Re: monster1] #4777225 06/04/18 11:43 AM
229 Offline
Slow but better than not refreshing. Pull the covers so you can wipe out the slime. Use Mopar gear RTV or compatible black gear oil RTV silicone.
Re: Opinions on diff fluid change with mityvac? [Re: monster1] #4777249 06/04/18 12:09 PM
M
monster1 Offline OP
M
I'll pull the covers. Thanks.
Re: Opinions on diff fluid change with mityvac? [Re: monster1] #4777397 06/04/18 03:06 PM
M
monster1 Offline OP
M
Pulled the cover to the rear. Gear oil was dark. But no shavings and everything was really clean. Put in 3 quarts of Lucas full synthetic 75w-90 and tightened everything back up. I think the front diff will wait for now since the rear was so clean. Too dang hot for me to be working in the sun.
Re: Opinions on diff fluid change with mityvac? [Re: monster1] #4777405 06/04/18 03:10 PM
J
JEL01 Offline
J
Good on you for taking care of it,
You are now ahead of 99% of other drivers, BITOGers excluded smile
Cars I maintain:
02 Mercedes CLK430
09 Honda Accord V6
13 Lexus RX350 AWD
02 Toyota Tundra 4x4
18 Lexus GX460
Re: Opinions on diff fluid change with mityvac? [Re: monster1] #4777424 06/04/18 03:27 PM
B
Billy_D Offline
B
I donít bother pulling the cover on my truck. I just use an oil extractor every 40k miles. The process is painfully slow.
Re: Opinions on diff fluid change with mityvac? [Re: monster1] #4777439 06/04/18 03:45 PM
demarpaint Offline
If you don't have a drain plug, that's what I'd do. thumbsup
God Bless Our Troops
Re: Opinions on diff fluid change with mityvac? [Re: monster1] #4778998 06/06/18 10:13 AM
M
monster1 Offline OP
M
I towed my 4k lb boat yesterday on a 50 mile round trip. I know this is nothing for a 3/4 ton truck but the lazer thermometer showed the differential running at 150 degrees in 100 degree heat. Looks like that Lucas synthetic gear oil does it's job. I was a bit concerned I made a wring choice if lubricants because it's not a very popular product as far as the internet is concerned.
Re: Opinions on diff fluid change with mityvac? [Re: monster1] #4779556 06/06/18 07:05 PM
Z
zeng Offline
Z
150F diff temperature towing is fantastic for Lucas 75W90 with a high [email protected]*C of 142 cSt.
