No more Meijer batteries!!
by bullwinkle. 02/22/19 06:24 PM
Valvoline premium blue tsc
by Dudemanmaximus. 02/22/19 05:38 PM
Echo won’t run on high speed
by artbuc. 02/22/19 05:36 PM
Roadside Assistance memberships
by paulri. 02/22/19 05:35 PM
Remembering Steve Irwin
by 2015_PSD. 02/22/19 05:27 PM
Transmission Cooler
by rcbob. 02/22/19 04:59 PM
Amazon: PP Euro 5W-40 $38 for pack of 6 quarts
by 1JZ_E46. 02/22/19 04:56 PM
89 Wrangler oil recommendations
by Chris142. 02/22/19 04:55 PM
New batteries failing on the shelf
by Chris142. 02/22/19 04:53 PM
Schaeffer’s 5w30 LT1
by s2krunner. 02/22/19 04:48 PM
Lexus LS430 P0756
by Kibitoshin. 02/22/19 04:41 PM
PUP is now SN + ??? Formulation change??
by Lazydan. 02/22/19 04:17 PM
Got a new wireless printer/MFC
by y_p_w. 02/22/19 02:48 PM
NM
by y_p_w. 02/22/19 02:47 PM
Names of brand names quality non-pro multi-meter
by JLawrence08648. 02/22/19 02:16 PM
Lady Luck
by CourierDriver. 02/22/19 02:06 PM
Ford MPG
by Zee09. 02/22/19 02:03 PM
Canucks in need of licensed ATF+4
by StevieC. 02/22/19 12:42 PM
jcthorne, duckthis1, Roughneck777, KDW, avantika31
67313 Registered Users
120 registered members (10WSmuckers, 928, AandPDan, AdditiveOCD, 69Torino, 10 invisible), 1,786 guests, and 50 spiders.
Topics284,678
Posts4,874,943
Members67,313
Most Online2,548
Feb 16th, 2019
Page 1 of 3 1 2 3
Bad shifting with Rotella T4 15w-40.. hotter temps #4777178
06/04/18 11:04 AM
06/04/18 11:04 AM
USA
ThunderOne Offline OP
USA
I jumped on the Rotella bandwagon and put some of it in my 2006 GSXR 600, but ever since then I have had a lot of trouble getting from 1st to 2nd (stuck in neutral... rev up, look like a noob), and a lot of issues with upshifting and finding that the gear did not change (shift, get on throttle only to realize that it's still in the same gear). I also notice that my engine runs a lot hotter (10-20 degrees consistently). I have found that I need to go much faster to get the temp gauge to go below 200, when before I could get to 190 by just getting a little airflow in there. I am disappointed in this oil and will be switching back to something more motorcycle specific. That being said, I did buy the oil on Scamazon, so maybe I got something counterfeit.
Either way, I was looking at probably going back to Valvoline dino motorcycle oil, or maybe trying Castrol Actevo semi-synthetic next. I was certainly surprised by the lackluster performance of the Rotella. I also used an OEM oil filter, same as the previous oil, which was Valvoline motorcycle oil.
Re: Bad shifting with Rotella T4 15w-40.. hotter temps [Re: ThunderOne] #4777193
06/04/18 11:19 AM
06/04/18 11:19 AM
N.H, U.S.A.
ARCOgraphite Offline
N.H, U.S.A.
Is T4 MA or just T5?
I still say no need for that gooey an oil in a water cooled bike. No siree Bob
2019 VW Jetta S,6M OCI#0 1136mi-Castrol Edge Prof? VW508+OE Filter; '17 Subaru Crosstrek CVT OC#6 43467mi-Valvoline Adv 0w20 + SOA Filter
Re: Bad shifting with Rotella T4 15w-40.. hotter temps [Re: ThunderOne] #4777196
06/04/18 11:20 AM
06/04/18 11:20 AM
Tn.
CourierDriver Offline
Tn.
Just buy factory oil..................
Look into Forks Over Knives Official Plant-Based Group if you want to change your way of eating.
Re: Bad shifting with Rotella T4 15w-40.. hotter temps [Re: ARCOgraphite] #4777205
06/04/18 11:30 AM
06/04/18 11:30 AM
USA
USA
T4 is JASO MA... I think maybe even MA2... supposedly. Though real world experience is telling me that this just isn't going to work for my bike. Back to the moto-specific stuff I guess.
I don't really want to try T6 because it doesn't seem as shear stable in the UOAs
Re: Bad shifting with Rotella T4 15w-40.. hotter temps [Re: ThunderOne] #4777227
06/04/18 11:50 AM
06/04/18 11:50 AM
Missouri (MO)
SlipperyPete Offline
Missouri (MO)
Same results I've experienced with every bike in which I've tried Rotella. I suspect a lot of people overlook poor performance to save a little money. FWIW, Shell says it meets JASO, but JASO doesn't seem to know anything about it.
Re: Bad shifting with Rotella T4 15w-40.. hotter temps [Re: ThunderOne] #4777241
06/04/18 12:01 PM
06/04/18 12:01 PM
MURICA
maverickfhs Offline
maverickfhs  Offline
MURICA
I am using it in my R1 and pleased with it, but I ride like a grand pa too. YMMV.
2006 Civic EX 205K/AT
2006 Acura TSX 187K/AT
Re: Bad shifting with Rotella T4 15w-40.. hotter temps [Re: ThunderOne] #4777312
06/04/18 01:48 PM
06/04/18 01:48 PM
Houston, Texas
motor_oil_madman Offline
Houston, Texas
These fancy motorcycles and y'all use $3/qt oil?
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
Re: Bad shifting with Rotella T4 15w-40.. hotter temps [Re: motor_oil_madman] #4777318
06/04/18 01:55 PM
06/04/18 01:55 PM
Katy, Republic of Texas
blupupher Offline
blupupher  Offline
Fancy or not, if I can use something that cost $3 that works just as well as something that cost $7, why spend extra?
2018 Hyundai Santa Fe: Delo XLE 10w-30, OEM filter, 3k
2012 Scion xB: QSUD 0w-20, CQ Blue, 5k
2002 Ford F150: Magnatec 5w-20, Bosch D+, 1yr
1994 Honda VT1100: Peak 15w-40, PSL, 1yr
Re: Bad shifting with Rotella T4 15w-40.. hotter temps [Re: SlipperyPete] #4777377
06/04/18 02:54 PM
06/04/18 02:54 PM
The Canyons
02SE Offline
02SE  Offline
The Canyons
Originally Posted By: SlipperyPete
Same results I've experienced with every bike in which I've tried Rotella. I suspect a lot of people overlook poor performance to save a little money....
Same for me. The shifting quickly deteriorates. As I've said many times on this subject, I've tried lots of different oils in my shared-sump bikes. Motul 300V 4T is still my favorite based solely on how the bikes run. Sure it's not cheap, but then neither are my bikes that I expect to run their best.
Re: Bad shifting with Rotella T4 15w-40.. hotter temps [Re: ThunderOne] #4777410
06/04/18 03:13 PM
06/04/18 03:13 PM
Chattanooga, TN
GermanAutohaus Offline
Chattanooga, TN
I'd give the T6 5W40 a shot. I don't have any UOA's for motorcycles, but the ones I do have for regular gas and diesel engines the shear stability has been satisfactory. Apples to apples, i've seen better stability and less wear with the T6, but then again I don't exactly have a load of data on the T5 (or T4) stuff since the T6 is my go-to.
Re: Bad shifting with Rotella T4 15w-40.. hotter temps [Re: 02SE] #4777415
06/04/18 03:20 PM
06/04/18 03:20 PM
Missouri (MO)
Missouri (MO)
I'm going to try 300V in my Speed Triple when the warranty runs out, since it doesn't have an API rating. I've been very pleased with their 7100 in the mean time.
Re: Bad shifting with Rotella T4 15w-40.. hotter temps [Re: blupupher] #4777427
06/04/18 03:30 PM
06/04/18 03:30 PM
Missouri (MO)
Missouri (MO)
How much are you really saving by using an oil you have to change at 2500 miles?
Re: Bad shifting with Rotella T4 15w-40.. hotter temps [Re: GermanAutohaus] #4777429
06/04/18 03:32 PM
06/04/18 03:32 PM
The Canyons
02SE Offline
02SE  Offline
The Canyons
For me with the T6 5w40 in the sump, shifting degraded even quicker than with the 15w40 Rotella. As always, YMMV.
Re: Bad shifting with Rotella T4 15w-40.. hotter temps [Re: SlipperyPete] #4777445
06/04/18 03:52 PM
06/04/18 03:52 PM
Canada
Lolvoguy Offline
Lolvoguy  Offline
Canada
Depends on many factors.
For instance, I don't ride more than 2,000kms per year, so it's great for my application.
06 Lexus IS350- Wife
88 BMW 325is- Mistress
Say "no" to Turbo!
Re: Bad shifting with Rotella T4 15w-40.. hotter temps [Re: SlipperyPete] #4777573
06/04/18 06:12 PM
06/04/18 06:12 PM
blupupher Offline
blupupher  Offline
Well, since my current stash of 8 gallons of oil cost me less than $20, cost really is not a concern.
I actually am planning on extending my interval to an annual oil change, which at my current driving, should be around 4000 miles.
Page 1 of 3 1 2 3
Moderated by  ekpolk
