Future of Chevy Bolt
by Snagglefoot. 07/16/19 09:04 AM
ST6607 on Honda CR-V 2.4L
by MontePrix28. 07/16/19 08:50 AM
2006 4runner Oil Leak After Synthetic
by Lucas_Jones. 07/16/19 08:46 AM
Quiet Small Engine
by Bailes1992. 07/16/19 08:26 AM
2005 C55 AMG oil recommendation
by TinyVoices. 07/16/19 08:26 AM
Uniroyal Tiger Paw Ice and Snow 3 - Reviews?
by Miller88. 07/16/19 08:09 AM
Wix XP oil filter deal
by Randy_R. 07/16/19 06:54 AM
How accurate is the octane rating at the pump ?
by Mr Nice. 07/16/19 06:33 AM
NAPA Presents: A Concert Behind Prison Walls
by GumbyJarvis. 07/15/19 11:35 PM
2019 Dodge Ram Warlock
by buster. 07/15/19 11:04 PM
2014 VW Jetta - transmission service
by gregk24. 07/15/19 10:09 PM
I wish my Camaro was this color!
by clinebarger. 07/15/19 09:19 PM
2019 Crosstrek 2500 Mile Review
by Al. 07/15/19 09:00 PM
Panasonic Cockpit Radio
by dishdude. 07/15/19 08:36 PM
97 Honda Civic won't crank
by Merek. 07/15/19 08:22 PM
Lucas_Jones, cobb_cruiser, robinjeter, SpicySenpai, Weatherdriver77
68670 Registered Users
90 registered members (4WD, AdditiveOCD, 69GTX, 2010Civic, 1978elcamino, 1foxracing, 10 invisible), 1,905 guests, and 22 spiders.
Topics291,934
Posts5,013,602
Members68,670
Most Online2,967
Mar 10th, 2019
Replaced transfer case fluid today #4775910
06/02/18 10:53 PM
06/02/18 10:53 PM
West Michigan
buck91 Offline OP
buck91  Offline OP
West Michigan
As the title says, replaced the transfer case fluid on my 2011 F159 today. Factory spec is 100-150k miles, this is the first change at just short of 100k. Fluid didn’t seem grossly out of viscosity but was grossly contaminated with grey goop/particals and possibly some moisture. Ford specs a “transfer case fluid” now that mercon is no longer officially produced so I don’t know if they are using anything fancier than the old mercon but I am certainly not impressed. Put Amsoil multi vehicle atf in and plan to change every 30-50k from here out.
2011 F150 4x4 5.0L
1996 Mustang GT 5spd/ragtop
Re: Replaced transfer case fluid today [Re: buck91] #4775912
06/02/18 10:57 PM
06/02/18 10:57 PM
Texas
4WD Online confused
4WD  Online Confused
Texas
I’m going to stick with early … with Ford PTU’s out of my life … the GM’s seem so easy …
Re: Replaced transfer case fluid today [Re: 4WD] #4776000
06/03/18 04:05 AM
06/03/18 04:05 AM
NY
demarpaint Offline
demarpaint  Offline
NY
I'm sticking with early too in my Jeep. I did the Liberty at about 30K, my Rubicon will be getting it done within the month at just over 10K miles. I'll probably go to 50K intervals after that.
God Bless Our Troops
Re: Replaced transfer case fluid today [Re: buck91] #4776054
06/03/18 07:28 AM
06/03/18 07:28 AM
Northeastern Vermont
littleant Offline
littleant  Offline
IMHO Ford Spec are way to long at 100-150,000 miles on Trans and Transfer case. I do question the rational for there maintenance schedule. I use the severe service. There is a specific transfer case fluid. Motorcraft xl-12 Transfer case fluid
I can't prevent getting old but I REFUSE to grow up.
2010 Mountaineer 4.0
2002 Jeep Wrangler TJ 4.0
Re: Replaced transfer case fluid today [Re: buck91] #4776074
06/03/18 08:06 AM
06/03/18 08:06 AM
A Warm place to live in
berniedd Offline
berniedd  Offline
It is a good idea to replace earlier than what the manual says. Their recommendation is to get past the warranty with minimum of cost, not in the owner's best interest for long equipment life. I changed my Ford SUV rear diff oil at about 22,000 miles and it came out greyish in color (suggesting water or water vapor contamination). It had always been driven only on the street, never off road or in flood. Manual also says change the ATF at 150,000 miles. I am definitely changing earlier than that.
Re: Replaced transfer case fluid today [Re: berniedd] #4776105
06/03/18 08:39 AM
06/03/18 08:39 AM
West Michigan
buck91 Offline OP
buck91  Offline OP
West Michigan
I agree; did ATF and coolant at 80k with planned bi-yearly drain and fills after that. After doing a lot of reading I decided to to the front dif and t-case at 100k (50k early). After this t-case drain I'm sure the front dif fluid will look terrible when I finally crack it open. Rear dif was done a couple years back when I installed my posi.
2011 F150 4x4 5.0L
Re: Replaced transfer case fluid today [Re: buck91] #4776114
06/03/18 08:49 AM
06/03/18 08:49 AM
The Motor City
Kestas Offline
Global Moderator
Kestas  Offline
Global Moderator
The Motor City
I urge people not to wait 100K to change out the fluid in their transfer case units. Manufacturers are pushing this fill-for-life concept in their new designs and the bearings are suffering short lives from debris denting. The problem is so bad that bearing manufacturers are asked to come up with debris dent resistant raceways, which is expensive, difficult, and a backwards way to manage the problem. The fluid should really be changed out early after break-in. 20K is a good suggestion. I only see the bearing problems. It's a good bet the gear teeth have a similar problem.
Ditto for transmissions and differentials.
Re: Replaced transfer case fluid today [Re: buck91] #4776115
06/03/18 08:52 AM
06/03/18 08:52 AM
Danville, Indiana
IndyFan Offline
IndyFan  Offline
Danville, Indiana
I usually go ever 36k or thereabouts. 123k on my JK now. The last change was at 96k, so it is due soon. I think the longest I ran that unit was 50k. The fluid came out looking brand new. Still, I like peace of mind. It is as cheap as a couple of bottles of ATF.
18 Jeep JLUR Wrangler 3.6 20k
15 Ford Transit 125k, Reman 3.5 @85k
08 Jeep Wrangler 3.8 132k
01 Ford F150 Crew 5.4 85k
99 Mercedes E430 Sport 92k
Re: Replaced transfer case fluid today [Re: littleant] #4776127
06/03/18 09:08 AM
06/03/18 09:08 AM
Texas
4WD Online confused
4WD  Online Confused
Texas
On our 2015 Explorer Sport… the shocker to me was the OM stated 150k … but then you flip around several pages back … and severe service is 30k ! Why not have that on the same page.
And BTW, when you have only 18 ounces of fluid to manage ecoboost torque … and being cooked by dual exhaust 3” below PTU … you’d reach “severe” PDQ …
Re: Replaced transfer case fluid today [Re: Kestas] #4776132
06/03/18 09:17 AM
06/03/18 09:17 AM
Malaysia
zeng Offline
zeng  Offline
Malaysia
These problems are caused by too low an operating viscosity (i.e too low a [email protected]*C) or too long an OCI ? .....
wait aren't they of superior base oils AND add pack ?
Application blunders simply could not be resolved by non-application remedies, I suppose.
Re: Replaced transfer case fluid today [Re: buck91] #4776145
06/03/18 09:27 AM
06/03/18 09:27 AM
NE,Ohio
Rand Offline
Rand  Offline
NE,Ohio
I agree on the short interval.. its esp. important on the first change.
I changed the gear oil on the 2013 outback at 15000miles the front
which shares with the 6speed transmission was very silty.
The rear looked very bad as well..
Subsequently
I went to 30k-40k mile intervals and both look nowhere remotely as bad as the first short 15000 interval.
Re: Replaced transfer case fluid today [Re: zeng] #4776183
06/03/18 10:28 AM
06/03/18 10:28 AM
The Motor City
Kestas Offline
Global Moderator
Kestas  Offline
Global Moderator
The Motor City
The problem is not the oil, per se. It is the break-in debris that floats around with the oil. Manufacturers have now asked suppliers to guarantee a limit on how much debris is present on the parts used for assembly. They are making design and manufacture of components very difficult in the name of chasing the almighty fill-for-life concept.
Again I repeat, change the fluid early after break-in. You'll see all the crud come out. The first change looks like metallic paint. The next change, whenever it is done, will come out considerably cleaner.
The lubes specified are fine.
Re: Replaced transfer case fluid today [Re: Kestas] #4776234
06/03/18 11:35 AM
06/03/18 11:35 AM
NY
demarpaint Offline
demarpaint  Offline
NY
Spot on! It's the break in [censored] you want out early. The fluid unfortunately has to go too.
Re: Replaced transfer case fluid today [Re: Kestas] #4776303
06/03/18 01:43 PM
06/03/18 01:43 PM
littleant Offline
littleant  Offline
How many ways can I agree with the above. 1000% should do it.
Re: Replaced transfer case fluid today [Re: buck91] #4776689
06/03/18 09:10 PM
06/03/18 09:10 PM
Indy
69Torino Offline
69Torino  Offline
Indy
Agree with everything stated here. I do all my driveline components (drain and fill) more often than recommended. Diff’s, transfer cases, transmissions. At least every 30k, and absolutely as soon as I buy a used car. Every fluid. It’s expensive once, but I now know what the gears and bearings are swimming around in. New cars I can barely keep from dumping and filling the driveline components before the 10k mark, and every single one I’ve done has had stripper dust in it.
1969 Ford Torino GT 390 Auto
2003 Mercury Marauder
1992 Mercury Capri Convertible
2005 Ford Freestyle
2008 Hyundai Santa Fe
1947 Ford 2N
1978 Honda XL75
Plus Other Stuff...
