SKF grease with graphite
by PreludeDenarius. 05/24/19 03:42 AM
Quaker State Ultimate Durability 5W-30: $17.97 at WM
by The Critic. 05/24/19 01:31 AM
AT-205 Re-Seal for 1968 VW Bus?
by ZraHamilton. 05/24/19 01:22 AM
Can 5W-30 be Thicker than 10W-30?
by John344. 05/23/19 10:33 PM
Fastenal new policy-unhappy
by rekit. 05/23/19 10:23 PM
0w30 Showdown of European Oils
by Marco620. 05/23/19 10:12 PM
amazon basics 5-40 not as good
by benjy. 05/23/19 09:28 PM
Cost to Repair a Honda V6 Engine that Jumps Time
by The Critic. 05/23/19 09:18 PM
Youtube demonitisation of conspiracy sites ?
by Shannow. 05/23/19 09:15 PM
03 Subaru WRX Valvoline VR1 10/30 196K miles
by TurboJW. 05/23/19 08:43 PM
TT time
by benjy. 05/23/19 08:29 PM
Castrol Nexcel
by JunkdrawerDog. 05/23/19 08:25 PM
1st gen ford focus
by WhyMe. 05/23/19 08:21 PM
Coca-Cola 600
by kstanf150. 05/23/19 07:49 PM
New cell phones and company
by spk2000. 05/23/19 07:24 PM
Swivel Elbow for Garden hose reel
by JC1. 05/23/19 06:57 PM
Garage floor coating
by Eddie. 05/23/19 06:43 PM
Tina70, tongboy1, PersonaPriusDad, MetricMike, Harps
68195 Registered Users
23 registered members (Bjornviken, 2015_PSD, berlyn, bigdavey, Donald1953, ctechbob, 2 invisible), 575 guests, and 23 spiders.
Topics289,326
Posts4,967,012
Members68,195
Most Online2,967
Mar 10th, 2019
Ford 600 tractor motor oil #4775822
06/02/18 09:07 PM
06/02/18 09:07 PM
Michigan
etc. Offline OP
etc.  Offline OP
Michigan
What is the go to motor oil for the Ford 600 tractor? I'm seeing a lot of recommendations for 15w40, but the manual calls for something entirely different:
SAE 30 above 90*f
SAE 20 90* to 32*
20w 32* to 10*
10w 10* to -10*
5w below -5*
The tractor in question has an unknown amount of hours and previous life, but runs excellent after a tune-up. My intentions are to use it fairly often from spring to fall and a couple times a month in the winter; mostly for snow removal.
Also, any objections to using a Ford FLA1?
Thanks in advance.
Re: Ford 600 tractor motor oil [Re: etc.] #4775837
06/02/18 09:26 PM
06/02/18 09:26 PM
California
VeryNoisyPoet Offline
California
That engine was made before multi-viscosity oils were widely available, and thus the huge range of viscosities specified.
This is where a 10w-30 (HDEO or PCMO) would probably make sense, as it would protect the engine at worst case hot temperatures, but still flow well enough at freezing temperatures.
1998 V70 GLT / 202k miles [10w-30 Valvoline Syn w/ Maxlife Tech + Mann W917 filter]
"Use yah blinkah!"
"Be nice. The alternative involves an air horn and 7000 lumens of high beam."
Re: Ford 600 tractor motor oil [Re: etc.] #4775852
06/02/18 09:56 PM
06/02/18 09:56 PM
Missouri
cb_13 Offline
cb_13  Offline
Missouri
I run an FL1a on my 600 tractor. The previous owner(my grandfather) used Pennzoil 10w30 exclusively for about 20 years. I have tried Valvoline Maxlife 1 time since Iíve had it but have used the Pennzoil every other time in the 12 years Iíve owned it.
Re: Ford 600 tractor motor oil [Re: etc.] #4776087
06/03/18 08:17 AM
06/03/18 08:17 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Originally Posted By: etc.
Also, any objections to using a Ford FL-1A?
15W-40 HDEO will be great in that engine.
Also, That FL-1A filter is just fine.
You could run a Napa one also - this one has been on for about 15 years or so. It's the same exact engine as yours.
https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/4770087/1
Re: Ford 600 tractor motor oil [Re: cb_13] #4777561
06/04/18 07:04 PM
06/04/18 07:04 PM
Michigan
etc. Offline OP
etc.  Offline OP
Michigan
Is there a reason why you didnt stick with Maxlife?
Re: Ford 600 tractor motor oil [Re: Linctex] #4777571
06/04/18 07:11 PM
06/04/18 07:11 PM
Michigan
etc. Offline OP
etc.  Offline OP
Michigan
What made you switch to a 15w40?
Re: Ford 600 tractor motor oil [Re: VeryNoisyPoet] #4777574
06/04/18 07:13 PM
06/04/18 07:13 PM
Michigan
etc. Offline OP
etc.  Offline OP
Michigan
A 10w30 would be nice since everything else I have uses it.
Re: Ford 600 tractor motor oil [Re: etc.] #4777588
06/04/18 07:35 PM
06/04/18 07:35 PM
Missouri
cb_13 Offline
cb_13  Offline
Missouri
No not really. Both performed just fine.
Re: Ford 600 tractor motor oil [Re: etc.] #4777644
06/04/18 08:17 PM
06/04/18 08:17 PM
California
California
That there is a mighty fine argument for 10w-30, instead of needing a separate stash just for the tractor.
"Use yah blinkah!"
Re: Ford 600 tractor motor oil [Re: etc.] #4780616
06/07/18 08:44 PM
06/07/18 08:44 PM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
Filter should be fine. No real multi-grade oils in the mid 1950's. Straight SAE 30 HD would have been normal down to the 30's (temp). Once it starts to cool off, SAE 20 would have been the norm. Lots of exposed surface area to bleed heat, so the sump temps would always remain low. Viscosity should be on the high'ish side no matter what oil you pick because of the cooling potential.
So I would be looking at the lowest temp you expect to have to start this machine? If always above freezing, I'd go with a 15W-XX or a 10W-XX. I'd prolly try to get Chevron Delo 400 15W-30 SD (severe duty) and leave it in for at least 100 operating hours.
But I realize this is a costly oil now days. Prices seem to have spiked something bad ...
So any good 10W-30 HDEO would be good. Mystic JT8 is very nice and it's available at Tractor Supply Co. Another choice would be John Deere Plus 50 oil. Both are stout oils and both are extremely well respected for off-road/AG applications smile
Re: Ford 600 tractor motor oil [Re: etc.] #4781016
06/08/18 08:25 AM
06/08/18 08:25 AM
Canyon County Idaho
CT8 Offline
CT8  Offline
Canyon County Idaho
15w-40 is the new straight 30.
2015 F150 2.7
2018 F350 6.2
Re: Ford 600 tractor motor oil [Re: etc.] #4790943
06/19/18 11:05 AM
06/19/18 11:05 AM
Indianapolis, Indiana
philipsearcy Offline
I have been using 5w-40 in my 1950 Ford 8N for the past 15+ years. Philip.
'03 Mercury Sable, '04 F250SD 5.4, '08 Honda Fit 1.5, '13 Honda Pilot, '50 Ford 8N tractor, '09 Kubota L3940 Tractor, '13 Kubota GR2120 Tractor
Moderated by  Lubrizol
