101 registered members (379KITTY, 2015_PSD, 2oldtommy, 01rangerxl, 10WSmuckers, 13 invisible),
1,876
guests, and 53
spiders. |
Key:
Admin,
Global Mod,
Mod
Topics284,726
Posts4,875,851
Members67,327
Most Online2,548 Feb 16th, 2019
rock solid picatinny QD mount?
#4774919
06/01/18 08:13 PM
06/01/18 08:13 PM
Posts: 2,748 West Michigan
buck91
OP
OP
West Michigan
Any suggestions for a QD picatinny mount? Have a 3x prism optic I'm considering mounting up to replace my A2 carry handle but want to be able to jetison for BUIS "if necessary." Looks like the QD mounts are a dime a dozen online but I'd like recommendations on a decent quality unit that won't shift POA/POI. This would be a low profile picatinny qd riser.
2011 F150 4x4 5.0L 1996 Mustang GT 5spd/ragtop
Re: rock solid picatinny QD mount?
[Re: buck91]
#4775050
06/01/18 10:51 PM
06/01/18 10:51 PM
Posts: 11,804 Santa Barbara, CA
bdcardinal
Santa Barbara, CA
I have a GG&G quick disconnect mount for the AimPoint on one of my ARs and could not be happier. Plus the red dot aligns perfectly with the GG&G BUIS.
2014 Ford Mustang GT Track Pack 1995 Ford Mustang GT
Ford/Mazda Parts Counter NRA Benefactor Member Opinions expressed are my own.
[Re: buck91]
#4775162
06/02/18 06:23 AM
06/02/18 06:23 AM
Posts: 7,761 Waco, TX
Linctex
Waco, TX
Aren't they ALL coming from the same extrusion machine in China?
"The evidence demands a verdict". (Re:VOA)"it's nearly impossible to actually know the particular additives that are in there at what concentrations."
[Re: buck91]
#4775467
06/02/18 12:18 PM
06/02/18 12:18 PM
bdcardinal
Santa Barbara, CA
GG&G, at least mine, was made in the USA.
[Re: buck91]
#4777106
06/04/18 09:39 AM
06/04/18 09:39 AM
Posts: 359 Lousiana
Ws6
Lousiana
Any suggestions for a QD picatinny mount? Have a 3x prism optic I'm considering mounting up to replace my A2 carry handle but want to be able to jetison for BUIS "if necessary." Looks like the QD mounts are a dime a dozen online but I'd like recommendations on a decent quality unit that won't shift POA/POI. This would be a low profile picatinny qd riser. I've dumped QD and gone to torque to spec and just bought quality optics. Nothing QD out there really impressed me as durable as the optic itself.
[Re: Ws6]
#4777142
06/04/18 10:22 AM
06/04/18 10:22 AM
Posts: 533 West Michigan
Balrog006
West Michigan
LaRue Tactical GG&G Bobro American Defense Mounts
All solid brands. Wouldn't trust too many other brands. Any suggestions for a QD picatinny mount? Have a 3x prism optic I'm considering mounting up to replace my A2 carry handle but want to be able to jetison for BUIS "if necessary." Looks like the QD mounts are a dime a dozen online but I'd like recommendations on a decent quality unit that won't shift POA/POI. This would be a low profile picatinny qd riser. I've dumped QD and gone to torque to spec and just bought quality optics. Nothing QD out there really impressed me as durable as the optic itself. LaRue QD mounts have been shown to repeat zero after being removed and reinstalled on precision Long range rigs in courses like Magpul Dynamics Long range rifle-if they return to zero for 1000yd work they’ll work for your application.
19 Ridgeline RTL-E >1K factory fill, A01 08 CRV 275K+ VSyn w/ML, A01 04 JD L130 740H, Mobil S 5w30 13 JD 2032r 325H, JD Plus 50 ii 15w40 M1Delvac 5w40 in OPE
[Re: Balrog006]
#4777152
06/04/18 10:32 AM
06/04/18 10:32 AM
Posts: 359 Lousiana
Ws6
Lousiana
All solid brands. Wouldn't trust too many other brands. Any suggestions for a QD picatinny mount? Have a 3x prism optic I'm considering mounting up to replace my A2 carry handle but want to be able to jetison for BUIS "if necessary." Looks like the QD mounts are a dime a dozen online but I'd like recommendations on a decent quality unit that won't shift POA/POI. This would be a low profile picatinny qd riser. I've dumped QD and gone to torque to spec and just bought quality optics. Nothing QD out there really impressed me as durable as the optic itself. LaRue QD mounts have been shown to repeat zero after being removed and reinstalled on precision Long range rigs in courses like Magpul Dynamics Long range rifle-if they return to zero for 1000yd work they’ll work for your application. LaRue was a good alternative to ARMS. That's where my praise stops.
[Re: buck91]
#4778316
06/05/18 02:47 PM
06/05/18 02:47 PM
Posts: 481 Ohio
jjjxlr8
Ohio
A.R.M.S. makes very nice products. A bit on the pricey side, maybe, but you buy them once and they last a lifetime and work as they should.
1993 Toyota MR2 Turbo 2008 Mazdaspeed3 2014 Toyota Highlander XLE
[Re: jjjxlr8]
#4778760
06/06/18 03:52 AM
06/06/18 03:52 AM
Posts: 359 Lousiana
Ws6
Lousiana
A.R.M.S. makes very nice products. A bit on the pricey side, maybe, but you buy them once and they last a lifetime and work as they should. I have heard that the new adjustable gen II levers from ARMS are indeed good kit, but the damage to their reputation done by their initial Gen 1 mounts, as well as the "war" between Dick Swan and Mark LaRue in LaRue's early years has forever relegated them to Tier 2 in the minds of the vast majority. The fact that the Elcan still ships with Gen 1 levers as far as I know is just a nail in the coffin. Noone is buying ARMS mounts when better alternatives exist except for a vastly outnumbered minority building clone-correct weapons or the like.
[Re: Ws6]
#4780222
06/07/18 01:40 PM
06/07/18 01:40 PM
Posts: 481 Ohio
jjjxlr8
Ohio
I wasn't aware of any drama or issues with ARMS products. I use the ARMS #18 mount and #22 throw lever rings on my M1A and they work perfectly. I installed the mount once and have never had to mess with it in 10 years, not even to tighten screws. The ARMS #22 throw lever rings are a bit tight fitting, but they always return to zero and I remove them after every range trip. The parts work as they should and have been 100% reliable.
My friend has a throw lever LaRue mount and he has also had no issues. Lot's of great choices on the market!
