First time ever didnt do my own oil change
by dbias. 02/22/19 07:12 PM
Toyota 3.4L 5VZ-FE Crank Sprocket
by The Critic. 02/22/19 07:08 PM
Weird Noise After Shutdown - 2018 Giulia
by RamFan. 02/22/19 07:01 PM
2019 Honda Passport
by mailman74. 02/22/19 06:56 PM
Who is censoring me? public wifi
by Vern_in_IL. 02/22/19 06:53 PM
Serpentine Belt Tool
by Gebo. 02/22/19 06:49 PM
SUNOCO GLOBAL FULL SYNTHETIC ATF
by Ursatdx. 02/22/19 06:46 PM
No more Meijer batteries!!
by bullwinkle. 02/22/19 06:24 PM
Valvoline premium blue tsc
by Dudemanmaximus. 02/22/19 05:38 PM
Echo won’t run on high speed
by artbuc. 02/22/19 05:36 PM
Roadside Assistance memberships
by paulri. 02/22/19 05:35 PM
Remembering Steve Irwin
by 2015_PSD. 02/22/19 05:27 PM
Transmission Cooler
by rcbob. 02/22/19 04:59 PM
Amazon: PP Euro 5W-40 $38 for pack of 6 quarts
by 1JZ_E46. 02/22/19 04:56 PM
89 Wrangler oil recommendations
by Chris142. 02/22/19 04:55 PM
New batteries failing on the shelf
by Chris142. 02/22/19 04:53 PM
Schaeffer’s 5w30 LT1
by s2krunner. 02/22/19 04:48 PM
Lexus LS430 P0756
by Kibitoshin. 02/22/19 04:41 PM
PUP is now SN + ??? Formulation change??
by Lazydan. 02/22/19 04:17 PM
Got a new wireless printer/MFC
by y_p_w. 02/22/19 02:48 PM
HwyFlierKev, McGruder, SirDave, DieselJoel, jcthorne
67317 Registered Users
104 registered members (69Torino, 53' Stude, 2009Edge, 2015_PSD, 13 invisible), 1,613 guests, and 53 spiders.
Topics284,685
Posts4,875,007
Members67,317
Most Online2,548
Feb 16th, 2019
Incorrect size: Fram 10295xg filter gasket #4774630
06/01/18 03:25 PM
06/01/18 03:25 PM
Washington
Dylan1303 Offline OP
Washington
Fram 10295 xg filter gaskets are to large for the canister on tundras. We have had 3 at work come back with the gasket pinched. First i thought it was the techs mistake. But i confirmed for myself the gasket has alot of play on the canister lid. We have been using a tg gasket instead of the xg gasket when tundras come in. Its the 5.7 tundra. Maybe its the batch at my wm. but its been a on going problem for a few months now.
12 cruze rs 1.4t 6spd pp 5w30 tuned on 22psi
13 equinox 2.4 awd pp 5w30
Re: Incorrect size: Fram 10295xg filter gasket [Re: Dylan1303] #4774633
06/01/18 03:29 PM
06/01/18 03:29 PM
USA
slacktide_bitog Offline
USA
Email Motorking about it
Re: Incorrect size: Fram 10295xg filter gasket [Re: Dylan1303] #4774643
06/01/18 03:40 PM
06/01/18 03:40 PM
Washington
Washington
Re: Incorrect size: Fram 10295xg filter gasket [Re: Dylan1303] #4774646
06/01/18 03:41 PM
06/01/18 03:41 PM
Washington
Washington
The tg gasket is tight against my fingers and the xg one has some play left
Re: Incorrect size: Fram 10295xg filter gasket [Re: Dylan1303] #4774653
06/01/18 03:51 PM
06/01/18 03:51 PM
PNW
ZeeOSix Offline
ZeeOSix  Offline
PNW
You can contact Fram on their website, and they seem to be very responsive about issues seen by customers.
Re: Incorrect size: Fram 10295xg filter gasket [Re: Dylan1303] #4774654
06/01/18 03:52 PM
06/01/18 03:52 PM
PA
Patrick0525 Offline
Patrick0525  Offline
PA
Do u have a pic of the gasket installed on the toyota oil filter canister? I wanna to see the amount of play. I have toyota v6 that used the FU XG9972 and you normally need a screw driver inserted into available slot to pry off the tight gasket.
'14 Toyota Venza 3.5L 80K mi
TGMO 0W-20
PP 0W-20/Fram Ultra filter(spring/summer)
Re: Incorrect size: Fram 10295xg filter gasket [Re: Dylan1303] #4774680
06/01/18 04:15 PM
06/01/18 04:15 PM
Washington
Washington
Ive sent a email that they provided our store. Im thinking it is a bad batch? We dont really go through those filters maybe 20 a month. Then it depends if the cust will upgrade to a ultra.
Re: Incorrect size: Fram 10295xg filter gasket [Re: Dylan1303] #4774692
06/01/18 04:25 PM
06/01/18 04:25 PM
North Carolina
rooflessVW Online content
rooflessVW  Online Content
North Carolina
Hey another cartridge gasket problem.
Spend a couple bucks and get a few factory o-rings. Replace them when they need replaced.
Problem solved.
"Zed's dead baby, Zed's dead."
Re: Incorrect size: Fram 10295xg filter gasket [Re: Dylan1303] #4774993
06/01/18 09:22 PM
06/01/18 09:22 PM
SD
zrxkawboy Offline
zrxkawboy  Offline
SD
Shouldn't a person be a able to use the o-ring with the filter, instead of making an extra trip to the dealer for the o-ring?
"Think of all the Ford owners who will someday want an automobile." John Dodge
Re: Incorrect size: Fram 10295xg filter gasket [Re: zrxkawboy] #4775085
06/02/18 01:13 AM
06/02/18 01:13 AM
Regina, Saskatchewan, Canada
Garak Offline
Garak  Offline
I can't speak for the Japanese makes, but with some of the German things I've seen, I've been able to get the filters, the o-rings, or both together in a kit, which is obviously the preferable way to do so.
Plain, simple Garak.
Re: Incorrect size: Fram 10295xg filter gasket [Re: Dylan1303] #4775105
06/02/18 04:06 AM
06/02/18 04:06 AM
NY
demarpaint Offline
demarpaint  Offline
NY
Maybe it is limited to that specific filter. I just used an Ultra on my Rubicon and the O-Ring fit perfectly. I wonder if they'll correct it with the next batch and let the filters with the wrong O-Ring stay in circulation until they're used up and hope for the best. Or recall them, or send out new O-Rings to people that bought one, or bury their heads like Purolator did with the torn media issue. wink Time will tell. Either way it will be interesting.
God Bless Our Troops
Re: Incorrect size: Fram 10295xg filter gasket [Re: Garak] #4775138
06/02/18 05:49 AM
06/02/18 05:49 AM
South Central PA (Fulton Co)
Delta Offline
Delta  Offline
The cartridge filter I got for our Camry had the filter, both o-rings, and the drain tool all in the box. Around $8 all together at the dealer, not a bad price if you ask me. My VW's have been the same, filter and o-ring.
'17 VW GTI 2.0T - 6MT - 13K - PPE 5w40
'15 Camry SE - 2.5 - 21K - PP 0w20
'99 S10 - 2.2 5MT - 157K - PP 10w30
Re: Incorrect size: Fram 10295xg filter gasket [Re: Delta] #4775179
06/02/18 06:47 AM
06/02/18 06:47 AM
Champlain/Hudson Valley
Kira Offline
Kira  Offline
If it's been an ongoing problem as the OP states, then it's OK to bash Fram products.
So many filter sizes. I wonder how many "O" ring sizes there are in element oil filter applications worldwide.
Re: Incorrect size: Fram 10295xg filter gasket [Re: Dylan1303] #4775217
06/02/18 07:43 AM
06/02/18 07:43 AM
Tennessee
goodtimes Offline
goodtimes  Offline
Tennessee
Bad reverse "engineering." Fram copied wrong the cartridge center hole sizes too on some. As far as I am concerned they swept the Ultra rattle problem under the rug. No real answer was given. They didn't try hard enough to find out their mistake, but as usual are quick to blame something else. First time it was glazed oil on a defect. It's OK to say this as already Purolator has been brought up in a Fram thread. Fram isn't that great on QC. I gave them a try, no more for me.
Re: Incorrect size: Fram 10295xg filter gasket [Re: Dylan1303] #4775297
06/02/18 09:00 AM
06/02/18 09:00 AM
New Jersey
JHZR2 Offline
JHZR2  Offline
New Jersey
Thread reopened: if it reverts to typical drama, people will get time off.
Moderated by  ekpolk
