Clock hours - 31 total, 7 idle. Had to go on several long drives to reach 1,000 miles, which Ford said not to tow before. Was curious about fuel dilution with the new dual injection system (DI and MPFI). I can live with 3% but still worried it will increase since most mileage now is short-tripping (less than 2 miles per trip) or towing a ~6,500# boat. Typically will not go over 5,000 miles per year. Anyway, at 7.2 cSt it was not far from being out of grade. Looks like it probably started life in the low 8.x cSt range. At least Ford walked the walk by putting a SAE 20 grade in as factory fill. My change was a mixture which should have a starting cSt of 9.1 so I consider it good to go. Probably sample after boating season to see how it looks.
