Noisy AC compressor
by Silver. 06/20/19 02:49 PM
Can't find a sewer clean out plug
by ls973800. 06/20/19 02:41 PM
Old style Champion COS3593A from RockAuto
by wemay. 06/20/19 02:37 PM
2.7 Ecoboost Reliable in F150?
by LoneRanger. 06/20/19 08:14 AM
Extension cords.
by Chris142. 06/20/19 08:01 AM
Bridge Loan - Mortgage Loan Need Advice
by Dwight_Frye. 06/20/19 07:36 AM
15 Tacoma 4.0L 1GR-FE 7.5k OCI 5w-30
by Danimal1q2w3. 06/20/19 07:35 AM
Powerstop drilled/slotted + Wagner OEx
by DriveHard. 06/20/19 06:51 AM
Oil flow and Vehicle start with oil cap off.
by BMWTurboDzl. 06/20/19 06:49 AM
2012 chevy equinox with 121,xxxx
by Robw. 06/20/19 06:31 AM
F1 - 2019 French Grand Prix
by gofast182. 06/20/19 06:17 AM
Yard rollers
by dlundblad. 06/20/19 05:20 AM
EP Auto?
by HowAboutThis. 06/19/19 11:13 PM
Rear Wheel Bearing Replacement?
by Gebo. 06/19/19 10:37 PM
Coolant in Oil?
by Score294. 06/19/19 10:34 PM
Colion, PT_Bimmer, Yankyslayer, tlane3533, HiqhWoltage
68445 Registered Users
104 registered members (ad244, 53' Stude, aircooled, AandPDan, 55hambone, 104Guy, 8 invisible), 2,305 guests, and 39 spiders.
Topics290,703
Posts4,991,353
Members68,445
Most Online2,967
Mar 10th, 2019
Page 1 of 4 1 2 3 4
ATF drain and fill at 19K #4772765
05/30/18 09:14 PM
05/30/18 09:14 PM
TX
parshisa Online content OP
parshisa  Online Content OP
TX
Iíll be changing engine oil tomorrow and have 4qts of Honda ATF. Iím a bit uncertain if I should swap tranny fluid as well since Iím already there. Car (Honda Pilot) is at 19K currently and havenít had ATF changed yet. Level, color, shifts are all good. Should i wait another 5k perhaps or change it tomorrow? What would yíall do if you were in my shoes?
Re: ATF drain and fill at 19K [Re: parshisa] #4772770
05/30/18 09:18 PM
05/30/18 09:18 PM
North Carolina
rooflessVW Offline
rooflessVW  Offline
North Carolina
I'd probably do it.
"Zed's dead baby, Zed's dead."
Re: ATF drain and fill at 19K [Re: parshisa] #4772771
05/30/18 09:19 PM
05/30/18 09:19 PM
Waco, TX
Linctex Online content
Linctex  Online Content
Waco, TX
Factory trans fill = follow the owner's manual
If you like, you could change it 25%-30% earlier than suggested.
Re: ATF drain and fill at 19K [Re: parshisa] #4772773
05/30/18 09:19 PM
05/30/18 09:19 PM
MIchigan
Warstud Offline
Warstud  Offline
MIchigan
Since your still running the factory fill I would change it. And every 25k there after.
Re: ATF drain and fill at 19K [Re: parshisa] #4772774
05/30/18 09:22 PM
05/30/18 09:22 PM
California
VeryNoisyPoet Offline
California
Do a drain and fill. The fluid itself may be in good shape, but there will be a fair amount of wear-in metals present, so flushing some of that out would be a good idea.
Consider catching some in a clean container to send off for analysis to see how things are doing and get a better idea of when to do the next drain and fill.
1998 V70 GLT / 202k miles [10w-30 Valvoline Syn w/ Maxlife Tech + Mann W917 filter]
"Use yah blinkah!"
"Be nice. The alternative involves an air horn and 7000 lumens of high beam."
Re: ATF drain and fill at 19K [Re: parshisa] #4772781
05/30/18 09:32 PM
05/30/18 09:32 PM
TX
TX
Thanks for the feedback folks. Do you guys have anything against filling up through the dip stick hole? Fill plug location on the new pilots is totally retarded and requires several components to be removed before i can get a socket on it...donít feelnlike doing it all...especially with the left foot in the cast
Re: ATF drain and fill at 19K [Re: parshisa] #4772785
05/30/18 09:36 PM
05/30/18 09:36 PM
NJ
Leo99 Offline
Leo99  Offline
NJ
Many trannys don't have a fill hole. Down the tube is the only way.
Without data you're just another person with an opinion. W. E. Deming
2003 Corolla 250,000 miles (RIP)
2004 Corolla 125,000 miles
2004 Rav4 370,000 miles
2015 Camry 70,000 miles
Re: ATF drain and fill at 19K [Re: parshisa] #4772802
05/30/18 10:00 PM
05/30/18 10:00 PM
Canyon County Idaho
CT8 Offline
CT8  Offline
Canyon County Idaho
Clean oil is happy oil.
2015 F150 2.7
2018 F350 6.2
Re: ATF drain and fill at 19K [Re: parshisa] #4772813
05/30/18 10:17 PM
05/30/18 10:17 PM
FL, USA
gregk24 Offline
gregk24  Offline
FL, USA
Do it, I do a drain and fill on my Honda every other oil change, and it always responds well.
2012 Honda Accord EX-L K24z3
56,xxx miles
PPPP 0w20 / Fram Ultra
2014 VW Jetta SE 1.8T ea888
44,xxx miles
Castrol Edge 0w40 / OEM filter
Re: ATF drain and fill at 19K [Re: parshisa] #4772816
05/30/18 10:20 PM
05/30/18 10:20 PM
USA
slacktide_bitog Offline
USA
During the warranty period, I'd wait until the MM tells you to change it
Re: ATF drain and fill at 19K [Re: parshisa] #4772825
05/30/18 10:33 PM
05/30/18 10:33 PM
Phoenix
dishdude Offline
dishdude  Offline
Phoenix
19k and every other oil change just seems way too often. It's a sealed system so it's not picking up dirt, and I'm not convinced metal shavings are an issue and will drain out. Metal shavings are more likely to stick to the pan and case than anything but are more likely to be picked up by the filter.
2018 Challenger SRT 392 PUP 0w-40 Wix 57899XP
2018 GTI
Re: ATF drain and fill at 19K [Re: dishdude] #4772836
05/30/18 10:50 PM
05/30/18 10:50 PM
VW Fanboy Island
maxdustington Online content
maxdustington  Online Content
VW Fanboy Island
If you run 10k OCIs then that's every 20k. That might be a little premature but If I had a brand new automatic trans I would try to keep the fluid as clean as I could.
The less ferrous debris that gets stuck to/inside the solenoids, the better.
03 Jetta AWP/09A 210k kms
Edge 0W40 + Mann 719/30
Re: ATF drain and fill at 19K [Re: parshisa] #4772852
05/30/18 11:20 PM
05/30/18 11:20 PM
Canuck living in California
KrisZ Offline
KrisZ  Offline
Get it out as soon as you can. Clutch and gear wear in material is what contaminates the factory fill. I would do 3 consecutive D&Fs to get most of it out, not just one.
2015 Grand Caravan 3.6L - 31k miles.
2006 Mazda 3 2.0L - 171k miles
Re: ATF drain and fill at 19K [Re: parshisa] #4772854
05/30/18 11:24 PM
05/30/18 11:24 PM
KrisZ Offline
KrisZ  Offline
Here is a good post showing how each drain reduced the amount of contaminants cought by the magnet. Keep in mind that there are also non ferrous material from the clutch packs that the magnet will not pick up.
Odyssey drain and fill
Re: ATF drain and fill at 19K [Re: parshisa] #4772860
05/30/18 11:42 PM
05/30/18 11:42 PM
Hammehead Offline
Hammehead  Offline
Too soon. Iīd wait more 19k. At that mileage, if it looks clean, it is clean.
ToYota Corolla XEI 2010 1zzfe
Kawasaki Ninja ZX9R B4
Taurus GL Vulcan
Citroen C5 phase I
I used to use syn, now whatever is on sale and never had problems. This noob knows stuff.
Page 1 of 4 1 2 3 4
