Pennzoil GF-6 & Low Viscosity Q&A
Click here to participate in the Pennzoil Q&A
VOA - HCF-2, Eneos Import CVT Model H, Eneos ECO CVT
by Stucker21trt. 06/26/19 06:48 PM
2012 Mazda3 iTouring
by Kira. 06/26/19 06:46 PM
Blazer Chalet
by dishdude. 06/26/19 06:27 PM
So confused about Hemi oil
by TN Tracker. 06/26/19 06:20 PM
Gabby Chaves’ mobile oil change business
by Pat in Speedway. 06/26/19 06:03 PM
PUP 5w-30 - 2016 GS F - 5,051 miles
by Tiir. 06/26/19 05:41 PM
I-CAR Gold Class Car Wash...
by Vern_in_IL. 06/26/19 05:36 PM
Kia manual allows 5w20 and 5w30 but not 0w20?
by Whammo. 06/26/19 05:31 PM
Buy A Car...Get Freebies
by GrtArtiste. 06/26/19 05:09 PM
by Stucker21trt. 06/26/19 04:31 PM
Radar Dimax AS-8 Diamond in rough
by spiderbypass. 06/26/19 04:06 PM
icy hot additive for oils
by 1978elcamino. 06/26/19 03:33 PM
Why does diesel stink so much less than gas?
by atikovi. 06/26/19 02:29 PM
Mackay radiator hoses?
by atikovi. 06/26/19 02:21 PM
1962 Cub Cadet Original
by Phishin. 06/26/19 01:27 PM
2008 Yamaha VX 1100 oil filter choice
by ledslinger. 06/26/19 01:09 PM
GM's HD Truck Line $100k
by earthbound. 06/26/19 12:17 PM
Huge shark York Beach Maine
by LeakySeals. 06/26/19 12:05 PM
Soflonole27, Bungalowbill, jefferylhenry, dead_bird, mikem350
68501 Registered Users
116 registered members (928, 53' Stude, ad244, Aero540T, ammolab, 9050lx, 7 invisible), 2,085 guests, and 26 spiders.
Topics291,012
Posts4,996,967
Members68,501
Most Online2,967
Mar 10th, 2019
Page 1 of 4 1 2 3 4
ATF drain and fill at 19K #4772765
05/30/18 09:14 PM
05/30/18 09:14 PM
TX
parshisa Offline OP
parshisa  Offline OP
TX
Iíll be changing engine oil tomorrow and have 4qts of Honda ATF. Iím a bit uncertain if I should swap tranny fluid as well since Iím already there. Car (Honda Pilot) is at 19K currently and havenít had ATF changed yet. Level, color, shifts are all good. Should i wait another 5k perhaps or change it tomorrow? What would yíall do if you were in my shoes?
Re: ATF drain and fill at 19K [Re: parshisa] #4772770
05/30/18 09:18 PM
05/30/18 09:18 PM
North Carolina
rooflessVW Online content
rooflessVW  Online Content
North Carolina
I'd probably do it.
"Zed's dead baby, Zed's dead."
Re: ATF drain and fill at 19K [Re: parshisa] #4772771
05/30/18 09:19 PM
05/30/18 09:19 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Factory trans fill = follow the owner's manual
If you like, you could change it 25%-30% earlier than suggested.
Re: ATF drain and fill at 19K [Re: parshisa] #4772773
05/30/18 09:19 PM
05/30/18 09:19 PM
MIchigan
Warstud Offline
Warstud  Offline
MIchigan
Since your still running the factory fill I would change it. And every 25k there after.
Re: ATF drain and fill at 19K [Re: parshisa] #4772774
05/30/18 09:22 PM
05/30/18 09:22 PM
California
VeryNoisyPoet Offline
California
Do a drain and fill. The fluid itself may be in good shape, but there will be a fair amount of wear-in metals present, so flushing some of that out would be a good idea.
Consider catching some in a clean container to send off for analysis to see how things are doing and get a better idea of when to do the next drain and fill.
1998 V70 GLT / 202k miles [10w-30 Valvoline Syn w/ Maxlife Tech + Mann W917 filter]
"Use yah blinkah!"
"Be nice. The alternative involves an air horn and 7000 lumens of high beam."
Re: ATF drain and fill at 19K [Re: parshisa] #4772781
05/30/18 09:32 PM
05/30/18 09:32 PM
TX
parshisa Offline OP
parshisa  Offline OP
TX
Thanks for the feedback folks. Do you guys have anything against filling up through the dip stick hole? Fill plug location on the new pilots is totally retarded and requires several components to be removed before i can get a socket on it...donít feelnlike doing it all...especially with the left foot in the cast
Re: ATF drain and fill at 19K [Re: parshisa] #4772785
05/30/18 09:36 PM
05/30/18 09:36 PM
NJ
Leo99 Offline
Leo99  Offline
NJ
Many trannys don't have a fill hole. Down the tube is the only way.
Without data you're just another person with an opinion. W. E. Deming
2003 Corolla 250,000 miles (RIP)
2004 Corolla 125,000 miles
2004 Rav4 370,000 miles
2015 Camry 70,000 miles
Re: ATF drain and fill at 19K [Re: parshisa] #4772802
05/30/18 10:00 PM
05/30/18 10:00 PM
Canyon County Idaho
CT8 Offline
CT8  Offline
Canyon County Idaho
Clean oil is happy oil.
2015 F150 2.7
2018 F350 6.2
Re: ATF drain and fill at 19K [Re: parshisa] #4772813
05/30/18 10:17 PM
05/30/18 10:17 PM
FL, USA
gregk24 Offline
gregk24  Offline
FL, USA
Do it, I do a drain and fill on my Honda every other oil change, and it always responds well.
2012 Honda Accord EX-L K24z3
56,xxx miles
PPPP 0w20 / Fram Ultra
2014 VW Jetta SE 1.8T ea888
44,xxx miles
Castrol Edge 0w40 / OEM filter
Re: ATF drain and fill at 19K [Re: parshisa] #4772816
05/30/18 10:20 PM
05/30/18 10:20 PM
USA
slacktide_bitog Offline
USA
During the warranty period, I'd wait until the MM tells you to change it
Re: ATF drain and fill at 19K [Re: parshisa] #4772825
05/30/18 10:33 PM
05/30/18 10:33 PM
Phoenix
dishdude Online content
dishdude  Online Content
Phoenix
19k and every other oil change just seems way too often. It's a sealed system so it's not picking up dirt, and I'm not convinced metal shavings are an issue and will drain out. Metal shavings are more likely to stick to the pan and case than anything but are more likely to be picked up by the filter.
2018 Challenger SRT 392 PUP 0w-40 Wix 57899XP
2018 GTI
Re: ATF drain and fill at 19K [Re: dishdude] #4772836
05/30/18 10:50 PM
05/30/18 10:50 PM
VW Fanboy Island
maxdustington Online content
maxdustington  Online Content
VW Fanboy Island
If you run 10k OCIs then that's every 20k. That might be a little premature but If I had a brand new automatic trans I would try to keep the fluid as clean as I could.
The less ferrous debris that gets stuck to/inside the solenoids, the better.
03 Jetta AWP/09A 210k kms
Edge 0W40 + Mann 719/30
Re: ATF drain and fill at 19K [Re: parshisa] #4772852
05/30/18 11:20 PM
05/30/18 11:20 PM
Canuck living in California
KrisZ Offline
KrisZ  Offline
Get it out as soon as you can. Clutch and gear wear in material is what contaminates the factory fill. I would do 3 consecutive D&Fs to get most of it out, not just one.
2015 Grand Caravan 3.6L - 31k miles.
2006 Mazda 3 2.0L - 171k miles
Re: ATF drain and fill at 19K [Re: parshisa] #4772854
05/30/18 11:24 PM
05/30/18 11:24 PM
KrisZ Offline
KrisZ  Offline
Here is a good post showing how each drain reduced the amount of contaminants cought by the magnet. Keep in mind that there are also non ferrous material from the clutch packs that the magnet will not pick up.
Odyssey drain and fill
Re: ATF drain and fill at 19K [Re: parshisa] #4772860
05/30/18 11:42 PM
05/30/18 11:42 PM
Hammehead Offline
Hammehead  Offline
Too soon. Iīd wait more 19k. At that mileage, if it looks clean, it is clean.
ToYota Corolla XEI 2010 1zzfe
Kawasaki Ninja ZX9R B4
Taurus GL Vulcan
Citroen C5 phase I
I used to use syn, now whatever is on sale and never had problems. This noob knows stuff.
Page 1 of 4 1 2 3 4
