SKF grease with graphite
by PreludeDenarius. 05/24/19 03:42 AM
Quaker State Ultimate Durability 5W-30: $17.97 at WM
by The Critic. 05/24/19 01:31 AM
AT-205 Re-Seal for 1968 VW Bus?
by ZraHamilton. 05/24/19 01:22 AM
Can 5W-30 be Thicker than 10W-30?
by John344. 05/23/19 10:33 PM
Fastenal new policy-unhappy
by rekit. 05/23/19 10:23 PM
0w30 Showdown of European Oils
by Marco620. 05/23/19 10:12 PM
amazon basics 5-40 not as good
by benjy. 05/23/19 09:28 PM
Cost to Repair a Honda V6 Engine that Jumps Time
by The Critic. 05/23/19 09:18 PM
Youtube demonitisation of conspiracy sites ?
by Shannow. 05/23/19 09:15 PM
03 Subaru WRX Valvoline VR1 10/30 196K miles
by TurboJW. 05/23/19 08:43 PM
TT time
by benjy. 05/23/19 08:29 PM
Castrol Nexcel
by JunkdrawerDog. 05/23/19 08:25 PM
1st gen ford focus
by WhyMe. 05/23/19 08:21 PM
Coca-Cola 600
by kstanf150. 05/23/19 07:49 PM
New cell phones and company
by spk2000. 05/23/19 07:24 PM
Swivel Elbow for Garden hose reel
by JC1. 05/23/19 06:57 PM
Garage floor coating
by Eddie. 05/23/19 06:43 PM
Tina70, tongboy1, PersonaPriusDad, MetricMike, Harps
68195 Registered Users
31 registered members (4WD, 2015_PSD, Char Baby, ctechbob, CB900F2, carviewsonic, 4 invisible), 628 guests, and 25 spiders.
Topics289,326
Posts4,967,019
Members68,195
Most Online2,967
Mar 10th, 2019
Tire sealants, recommendations? #4772784
05/30/18 09:36 PM
05/30/18 09:36 PM
NJ
JLawrence08648 Offline OP
NJ
I want to buy some tire sealant to put in mower and snowblower tires. I want to remove the valve core and pour it in there.
Any recommendations? How's Slime?
Re: Tire sealants, recommendations? [Re: JLawrence08648] #4772794
05/30/18 09:50 PM
05/30/18 09:50 PM
Georgia
AVB Offline
AVB  Offline
Georgia
Why are the tires leaking? Mine rot and crack, I had to install tubes.
Re: Tire sealants, recommendations? [Re: JLawrence08648] #4772815
05/30/18 10:18 PM
05/30/18 10:18 PM
USA
slacktide_bitog Offline
USA
Slime is probably the best if you want to remove the valve core. I don't think Fix-a-flat lets you do that
Re: Tire sealants, recommendations? [Re: JLawrence08648] #4772830
05/30/18 10:41 PM
05/30/18 10:41 PM
Reno, Nevada
Langanobob Offline
Langanobob  Offline
Reno, Nevada
Iíve had very good success with Berrymanís tire sealant.
Re: Tire sealants, recommendations? [Re: JLawrence08648] #4772832
05/30/18 10:41 PM
05/30/18 10:41 PM
Port Aransas, TX
Stevie Offline
Stevie  Offline
Port Aransas, TX
Go to an ATV dealership. They have special drums, quarts and gallons of special tire goop that go in ATV and Ranger tires that protect from mesquite thorns, and other tire hazards.
https://www.amazon.com/QuadBoss-Tire-Sea...EP62CBSSQMMZ3XZ
https://www.amazon.com/High-Lifter-Hlp-Tire-Sealant/dp/B00QV4U0V8
Re: Tire sealants, recommendations? [Re: JLawrence08648] #4772929
05/31/18 04:48 AM
05/31/18 04:48 AM
USA
NHGUY Offline
NHGUY  Offline
USA
Liquitube.
Re: Tire sealants, recommendations? [Re: JLawrence08648] #4773012
05/31/18 07:35 AM
05/31/18 07:35 AM
Somewhere
itguy08 Offline
itguy08  Offline
Somewhere
I had leaky snowblower tires - would be flat in a week or 2. Tried Slime and they are holding good going on 2 months now.
Re: Tire sealants, recommendations? [Re: JLawrence08648] #4773105
05/31/18 09:13 AM
05/31/18 09:13 AM
Texas
WyrTwister Offline
WyrTwister  Offline
Texas
Wyr
God bless
Re: Tire sealants, recommendations? [Re: JLawrence08648] #4773115
05/31/18 09:25 AM
05/31/18 09:25 AM
Minnesota
2010Civic Offline
2010Civic  Offline
Minnesota
I used Slime in a old car tire that had a lot of weather cracking, etc and it worked perfect. Still holding pressure several years later. The tire isn't used on the road btw. Way too cracked up.
2010 Honda Civic LX
Valvoline SynPower 5w-20 - Napa Gold oil filter
59,992 miles
Re: Tire sealants, recommendations? [Re: JLawrence08648] #4773151
05/31/18 09:55 AM
05/31/18 09:55 AM
Florida, Cape Coral
Eddie Offline
Eddie  Offline
Florida, Cape Coral
+1 for SLIME. A profession mower told me he puts SLIME in all tires on every new mower he gets because he can't afford down-time. ED
2014 CX5 Touring 2.5L :-)
Re: Tire sealants, recommendations? [Re: JLawrence08648] #4773173
05/31/18 10:10 AM
05/31/18 10:10 AM
NJ
NJ
I have tires that tend to leak around the bead. I've done the tube route and it's great but don't want to spend the money.
Re: Tire sealants, recommendations? [Re: JLawrence08648] #4773216
05/31/18 10:51 AM
05/31/18 10:51 AM
Missouri
David2431 Offline
David2431  Offline
Missouri
Back in the day when I worked in a service station (ever hear of those?) we would use this on rim leaks for good measure.
It's amazing how many problems trace back to rim leaks.
Wire brush or buff the rust/imperfections on both beads of the rim and coat the tire bead with this or similar.
Most times it fixed the problem.
And.... BTW---before I'm flamed...if you're breaking down the tire using a machine in the future the sealant causes no problems.
https://mt-rsr.com/products/copy-of-patc...ASABEgJI5PD_BwE
Re: Tire sealants, recommendations? [Re: JLawrence08648] #4776493
06/03/18 05:02 PM
06/03/18 05:02 PM
Bucks County, PA
Hot_Ajax Offline
Hot_Ajax  Offline
Bucks County, PA
Slime is great stuff. I just used it on a wheelbarrow that is over 30 years old and it sealed it up fine. Good product, fair price. Not sure how it would do if you used slime and then later tried to put a new tire back on the slime-soaked rim. Cheap and readily available.
Re: Tire sealants, recommendations? [Re: JLawrence08648] #4780752
06/07/18 10:38 PM
06/07/18 10:38 PM
Washington St.
Ken2 Offline
Ken2  Offline
Washington St.
Motorcycle riders have reported good results with Ride-On sealant. They find that it works well, and is easier to clean out than Slime when the tire needs to be replaced. My Prius Prime plug-in hybrid car doesn't have a spare tire, and I put Ride-On car formula sealant in the tires just in case. Ride-On makes various formulations for different uses. The ATV might be most suited to mowers & snow blowers.
http://www.ride-on.com/atv-and-utvs.html
Re: Tire sealants, recommendations? [Re: Ken2] #4781175
06/08/18 11:01 AM
06/08/18 11:01 AM
Chicago, IL
EdwardC Offline
EdwardC  Offline
Chicago, IL
I use Ride-On in my bike, found a screw stuck in it, pulled it out and it did end up completely sealing up the hole (after a couple days of slow leaks).
I use Ride-On because of the purported qualities over over sealants. My dad has used Slime on several tires in the past with good results too, those were mostly slow leaks that weren't due to a puncture. Ride-On is a little pricier than most other options though. If it were me, for a mower/blower type application, I'd buy whatever was cheaper and more available. Looking at Amazon, you can get a gallon of Slime for $20, that sounds like a steal compared to 32 oz of ATV Ride-On I paid over $20 for.
For either product, I don't think you need to remove the valve stem, just the valve core. Since a mower and blower doesn't move too fast, I would squeeze in a higher than average volume of sealant so that it can better coat the inside slowly.
