Sync Update
by borgward - 02/26/20 03:30 PM
Kirkland 0w20 at local costco
by paulri - 02/26/20 03:12 PM
LG Red in a VW DSG trans?
by racin4ds - 02/26/20 02:31 PM
2013 Jaguar XF 3.0 AWD
by ET16 - 02/26/20 02:25 PM
Ford....in trouble??
by earthbound - 02/26/20 01:31 PM
Interesting read
by double vanos - 02/26/20 10:51 AM
2010 Honda Element 127K miles valvetrain picture
by SLO_Town - 02/26/20 10:01 AM
Anyone Used a Sea Sucker Bike Rack/Mount?
by jcartwright99 - 02/26/20 09:46 AM
8 passenger vehicle typically 5 for <=$15k
by madRiver - 02/26/20 09:27 AM
RON Octane Gasoline rating
by Building3 - 02/26/20 09:26 AM
Who makes Canadian Supertech?
by Patman - 02/26/20 09:08 AM
Benefits of a hard break-in discussion
by buster - 02/26/20 08:54 AM
2004 Cavalier 2.2L Oil Change Interval?
by Bob5150 - 02/26/20 08:44 AM
Amazon Redline 5w30 $41.99/gal
by SubieRubyRoo - 02/26/20 08:00 AM
Possible Clearance Score ?? Royal Purple 5W30
by GMguy84 - 02/26/20 04:34 AM
1994 Buick Century 63k miles pics
by MuzzleFlash40 - 02/26/20 04:10 AM
Oils for old engines
by puma4440 - 02/25/20 08:18 PM
JimNastic316, Jimbobert56, Ollie_B_2000, akarip, BJD2020
70804 Registered Users
109 registered members (97prizm, 762fermeandyou, Alfred_B, 1978elcamino, 2013ecof150, 9 invisible), 2,245 guests, and 20 spiders.
Topics301,953
Posts5,206,251
Members70,804
Page 1 of 4 1 2 3 4
ATF drain and fill at 19K #4772765 05/30/18 08:14 PM
P
parshisa Online Content OP
OP Online Content
P
Iíll be changing engine oil tomorrow and have 4qts of Honda ATF. Iím a bit uncertain if I should swap tranny fluid as well since Iím already there. Car (Honda Pilot) is at 19K currently and havenít had ATF changed yet. Level, color, shifts are all good. Should i wait another 5k perhaps or change it tomorrow? What would yíall do if you were in my shoes?
'17 Honda Civic 1.5T/ 6MT
'16 Honda Pilot 3.5NA/6AT
Re: ATF drain and fill at 19K [Re: parshisa] #4772770 05/30/18 08:18 PM
rooflessVW Offline
I'd probably do it.
"Zed's dead baby, Zed's dead."
Re: ATF drain and fill at 19K [Re: parshisa] #4772771 05/30/18 08:19 PM
L
Linctex Offline
L
Factory trans fill = follow the owner's manual
If you like, you could change it 25%-30% earlier than suggested.
Re: ATF drain and fill at 19K [Re: parshisa] #4772773 05/30/18 08:19 PM
W
Warstud Offline
W
Since your still running the factory fill I would change it. And every 25k there after.
Re: ATF drain and fill at 19K [Re: parshisa] #4772774 05/30/18 08:22 PM
V
VeryNoisyPoet Offline
V
Do a drain and fill. The fluid itself may be in good shape, but there will be a fair amount of wear-in metals present, so flushing some of that out would be a good idea.
Consider catching some in a clean container to send off for analysis to see how things are doing and get a better idea of when to do the next drain and fill.
1998 V70 GLT / 202k miles [10w-30 Valvoline Syn w/ Maxlife Tech + Mann W917 filter]
"Use yah blinkah!"
"Be nice. The alternative involves an air horn and 7000 lumens of high beam."
Re: ATF drain and fill at 19K [Re: parshisa] #4772781 05/30/18 08:32 PM
P
OP Online Content
P
Thanks for the feedback folks. Do you guys have anything against filling up through the dip stick hole? Fill plug location on the new pilots is totally retarded and requires several components to be removed before i can get a socket on it...donít feelnlike doing it all...especially with the left foot in the cast
Re: ATF drain and fill at 19K [Re: parshisa] #4772785 05/30/18 08:36 PM
L
Leo99 Offline
L
Many trannys don't have a fill hole. Down the tube is the only way.
Without data you're just another person with an opinion. W. E. Deming
2003 Corolla 250,000 miles (RIP)
2004 Corolla 125,000 miles
2004 Rav4 392,000 miles
2015 Camry 90,000 miles
Re: ATF drain and fill at 19K [Re: parshisa] #4772802 05/30/18 09:00 PM
CT8 Online Content
Online Content
Clean oil is happy oil.
2015 F150 2.7
2018 F350 6.2
Re: ATF drain and fill at 19K [Re: parshisa] #4772813 05/30/18 09:17 PM
G
gregk24 Offline
G
Do it, I do a drain and fill on my Honda every other oil change, and it always responds well.
2012 Honda Accord EX-L K24z3
60,xxx miles
PPPP 0w20 / Fram Ultra
2014 VW Jetta SE 1.8T ea888
54,xxx miles
Castrol Edge 0w40 / OEM filter
Re: ATF drain and fill at 19K [Re: parshisa] #4772816 05/30/18 09:20 PM
slacktide_bitog Online Content
Online Content
During the warranty period, I'd wait until the MM tells you to change it
Re: ATF drain and fill at 19K [Re: parshisa] #4772825 05/30/18 09:33 PM
dishdude Online Content
Online Content
19k and every other oil change just seems way too often. It's a sealed system so it's not picking up dirt, and I'm not convinced metal shavings are an issue and will drain out. Metal shavings are more likely to stick to the pan and case than anything but are more likely to be picked up by the filter.
2018 Challenger SRT 392 PUP 0w-40 Wix 57899XP
2018 GTI M1 Euro 0w-40 Wix WL10024
2019 Tiguan Castrol Edge Pro 0w-20
Re: ATF drain and fill at 19K [Re: dishdude] #4772836 05/30/18 09:50 PM
M
maxdustington Online Content
Online Content
M
If you run 10k OCIs then that's every 20k. That might be a little premature but If I had a brand new automatic trans I would try to keep the fluid as clean as I could.
The less ferrous debris that gets stuck to/inside the solenoids, the better.
99 Toyota Tercel CE 5EFE/C151
PUP 5W30/Ultra
Re: ATF drain and fill at 19K [Re: parshisa] #4772852 05/30/18 10:20 PM
K
KrisZ Offline
K
Get it out as soon as you can. Clutch and gear wear in material is what contaminates the factory fill. I would do 3 consecutive D&Fs to get most of it out, not just one.
2015 Grand Caravan 3.6L - 35k miles.
2006 Mazda 3 2.0L - 186k miles
Re: ATF drain and fill at 19K [Re: parshisa] #4772854 05/30/18 10:24 PM
K
KrisZ Offline
K
Here is a good post showing how each drain reduced the amount of contaminants cought by the magnet. Keep in mind that there are also non ferrous material from the clutch packs that the magnet will not pick up.
Odyssey drain and fill
Re: ATF drain and fill at 19K [Re: parshisa] #4772860 05/30/18 10:42 PM
H
Hammehead Offline
H
Too soon. Iīd wait more 19k. At that mileage, if it looks clean, it is clean.
ToYota Corolla XEI 2010 1zzfe
Kawasaki Ninja ZX9R B4
Taurus GL Vulcan
Citroen C5 phase I
I used to use syn, now whatever is on sale and never had problems. This noob knows stuff.
Page 1 of 4 1 2 3 4
