Castrol EDGE EP 5W30 In Mixed Driving ?
by ChrisD46 - 09/22/19 05:23 AM
Battery Maintainer/Tender
by Char Baby - 09/22/19 05:03 AM
Czechmate
by Marco620 - 09/21/19 10:58 PM
2013 Accord M1 Annual Protection 5w/20
by Scout1 - 09/21/19 09:29 PM
New Valvoline oil line - Valvoline European Vehicle!
by BurntMusic - 09/21/19 09:13 PM
Cummins 5.9: 5W 40 vs 15W 40
by ThisBigRoadTrip - 09/21/19 09:07 PM
New Fleet and Farm opening this week
by RazorsEdge - 09/21/19 09:04 PM
Ford testing new vehicles
by 97prizm - 09/21/19 08:00 PM
Any stuffed pepper lovers here?
by 53' Stude - 09/21/19 06:55 PM
Shrinking Window Tint.
by George7941 - 09/21/19 05:30 PM
Drain and refill or Cooler line flush?
by jrvn - 09/21/19 05:25 PM
Federated Auto Parts 400 at Richmond Raceway
by bdcardinal - 09/21/19 04:40 PM
Stick with OEM or try aftermarket?
by Nav45 - 09/21/19 04:25 PM
Body Shop guys, what should I expect to pay?
by dwcopple - 09/21/19 03:59 PM
What Vehicle and Trailer to Tow Tractor?
by lancerplayer - 09/21/19 03:40 PM
Garage high humidity floor wet vehicle inside.
by littleant - 09/21/19 03:34 PM
[NEW] Carquest 95515 / Fits MB GLA/CLA
by SlavaB - 09/21/19 03:23 PM
KENDALL GT-1 HIGH PERFORMANCE SYN BLEND 5W-30
by OilReport99 - 09/21/19 03:02 PM
Dunkaroo, Ntony, jheffley, vinod, gary1
69360 Registered Users
43 registered members (bernardch, AnthemBassMan, Bailes1992, Azeem, bbhero, 5 invisible), 742 guests, and 21 spiders.
Topics294,886
Posts5,068,750
Members69,360
Most Online3,532
Jul 30th, 2019
Page 1 of 4 1 2 3 4
ATF drain and fill at 19K #4772765 05/30/18 09:14 PM
P
parshisa Offline OP
P
Iíll be changing engine oil tomorrow and have 4qts of Honda ATF. Iím a bit uncertain if I should swap tranny fluid as well since Iím already there. Car (Honda Pilot) is at 19K currently and havenít had ATF changed yet. Level, color, shifts are all good. Should i wait another 5k perhaps or change it tomorrow? What would yíall do if you were in my shoes?
Re: ATF drain and fill at 19K [Re: parshisa] #4772770 05/30/18 09:18 PM
rooflessVW Offline
I'd probably do it.
"Zed's dead baby, Zed's dead."
Re: ATF drain and fill at 19K [Re: parshisa] #4772771 05/30/18 09:19 PM
L
Linctex Offline
L
Factory trans fill = follow the owner's manual
If you like, you could change it 25%-30% earlier than suggested.
Re: ATF drain and fill at 19K [Re: parshisa] #4772773 05/30/18 09:19 PM
W
Warstud Offline
W
Since your still running the factory fill I would change it. And every 25k there after.
Re: ATF drain and fill at 19K [Re: parshisa] #4772774 05/30/18 09:22 PM
V
VeryNoisyPoet Offline
V
Do a drain and fill. The fluid itself may be in good shape, but there will be a fair amount of wear-in metals present, so flushing some of that out would be a good idea.
Consider catching some in a clean container to send off for analysis to see how things are doing and get a better idea of when to do the next drain and fill.
1998 V70 GLT / 202k miles [10w-30 Valvoline Syn w/ Maxlife Tech + Mann W917 filter]
"Use yah blinkah!"
"Be nice. The alternative involves an air horn and 7000 lumens of high beam."
Re: ATF drain and fill at 19K [Re: parshisa] #4772781 05/30/18 09:32 PM
P
parshisa Offline OP
P
Thanks for the feedback folks. Do you guys have anything against filling up through the dip stick hole? Fill plug location on the new pilots is totally retarded and requires several components to be removed before i can get a socket on it...donít feelnlike doing it all...especially with the left foot in the cast
Re: ATF drain and fill at 19K [Re: parshisa] #4772785 05/30/18 09:36 PM
L
Leo99 Offline
L
Many trannys don't have a fill hole. Down the tube is the only way.
Without data you're just another person with an opinion. W. E. Deming
2003 Corolla 250,000 miles (RIP)
2004 Corolla 125,000 miles
2004 Rav4 392,000 miles
2015 Camry 90,000 miles
Re: ATF drain and fill at 19K [Re: parshisa] #4772802 05/30/18 10:00 PM
CT8 Offline
Clean oil is happy oil.
2015 F150 2.7
2018 F350 6.2
Re: ATF drain and fill at 19K [Re: parshisa] #4772813 05/30/18 10:17 PM
G
gregk24 Offline
G
Do it, I do a drain and fill on my Honda every other oil change, and it always responds well.
2012 Honda Accord EX-L K24z3
58,xxx miles
PPPP 0w20 / Fram Ultra
2014 VW Jetta SE 1.8T ea888
50,xxx miles
Castrol Edge 0w40 / OEM filter
Re: ATF drain and fill at 19K [Re: parshisa] #4772816 05/30/18 10:20 PM
slacktide_bitog Offline
During the warranty period, I'd wait until the MM tells you to change it
Re: ATF drain and fill at 19K [Re: parshisa] #4772825 05/30/18 10:33 PM
dishdude Offline
19k and every other oil change just seems way too often. It's a sealed system so it's not picking up dirt, and I'm not convinced metal shavings are an issue and will drain out. Metal shavings are more likely to stick to the pan and case than anything but are more likely to be picked up by the filter.
2018 Challenger SRT 392 PUP 0w-40 Wix 57899XP
2018 GTI M1 Euro 0w-40 Wix WL10024
2019 Tiguan
Re: ATF drain and fill at 19K [Re: dishdude] #4772836 05/30/18 10:50 PM
M
maxdustington Offline
M
If you run 10k OCIs then that's every 20k. That might be a little premature but If I had a brand new automatic trans I would try to keep the fluid as clean as I could.
The less ferrous debris that gets stuck to/inside the solenoids, the better.
03 Jetta AWP/09A 210k kms
Edge 0W40 + Mann 719/30
Re: ATF drain and fill at 19K [Re: parshisa] #4772852 05/30/18 11:20 PM
K
KrisZ Offline
K
Get it out as soon as you can. Clutch and gear wear in material is what contaminates the factory fill. I would do 3 consecutive D&Fs to get most of it out, not just one.
2015 Grand Caravan 3.6L - 31k miles.
2006 Mazda 3 2.0L - 171k miles
Re: ATF drain and fill at 19K [Re: parshisa] #4772854 05/30/18 11:24 PM
K
KrisZ Offline
K
Here is a good post showing how each drain reduced the amount of contaminants cought by the magnet. Keep in mind that there are also non ferrous material from the clutch packs that the magnet will not pick up.
Odyssey drain and fill
Re: ATF drain and fill at 19K [Re: parshisa] #4772860 05/30/18 11:42 PM
H
Hammehead Offline
H
Too soon. Iīd wait more 19k. At that mileage, if it looks clean, it is clean.
ToYota Corolla XEI 2010 1zzfe
Kawasaki Ninja ZX9R B4
Taurus GL Vulcan
Citroen C5 phase I
I used to use syn, now whatever is on sale and never had problems. This noob knows stuff.
Page 1 of 4 1 2 3 4
