SKF grease with graphite
by PreludeDenarius. 05/24/19 03:42 AM
Quaker State Ultimate Durability 5W-30: $17.97 at WM
by The Critic. 05/24/19 01:31 AM
AT-205 Re-Seal for 1968 VW Bus?
by ZraHamilton. 05/24/19 01:22 AM
Can 5W-30 be Thicker than 10W-30?
by John344. 05/23/19 10:33 PM
Fastenal new policy-unhappy
by rekit. 05/23/19 10:23 PM
0w30 Showdown of European Oils
by Marco620. 05/23/19 10:12 PM
amazon basics 5-40 not as good
by benjy. 05/23/19 09:28 PM
Cost to Repair a Honda V6 Engine that Jumps Time
by The Critic. 05/23/19 09:18 PM
Youtube demonitisation of conspiracy sites ?
by Shannow. 05/23/19 09:15 PM
03 Subaru WRX Valvoline VR1 10/30 196K miles
by TurboJW. 05/23/19 08:43 PM
TT time
by benjy. 05/23/19 08:29 PM
Castrol Nexcel
by JunkdrawerDog. 05/23/19 08:25 PM
1st gen ford focus
by WhyMe. 05/23/19 08:21 PM
Coca-Cola 600
by kstanf150. 05/23/19 07:49 PM
New cell phones and company
by spk2000. 05/23/19 07:24 PM
Swivel Elbow for Garden hose reel
by JC1. 05/23/19 06:57 PM
Garage floor coating
by Eddie. 05/23/19 06:43 PM
Tina70, tongboy1, PersonaPriusDad, MetricMike, Harps
68195 Registered Users
20 registered members (2015_PSD, carviewsonic, D0nat, Bjornviken, 08z06, DaHen, 2 invisible), 594 guests, and 23 spiders.
Topics289,326
Posts4,967,015
Members68,195
Most Online2,967
Mar 10th, 2019
Page 1 of 6 1 2 6
Can Oil be changed too much? #4772212
05/30/18 11:24 AM
05/30/18 11:24 AM
England
Tikka Offline OP
Tikka  Offline OP
England
Hi
Further to my thread about my OM642 I have the following question please.
I travel about 6000 miles a year. A lot of that mileage is stop start and short journeys where the Engine barely gets up to operating temperature. I understand this type of driving to be hard on Oils.
Generally I change my Oil at 6 month intervals so it will have been in the Engine for around 3000 miles or so.
Can changing the Oil at these intervals do more harm than good? In other words can you change your Oil too much apart from damaging your Wallet paying for the changes?
Many thanks.
Tikka.
Re: Can Oil be changed too much? [Re: Tikka] #4772216
05/30/18 11:29 AM
05/30/18 11:29 AM
Texas
WyrTwister Offline
WyrTwister  Offline
Texas
Can not think of any way it will damage the engine .
Wyr
God bless
Re: Can Oil be changed too much? [Re: Tikka] #4772225
05/30/18 11:39 AM
05/30/18 11:39 AM
PimTac Offline
PimTac  Offline
It should be fine. The impact on your wallet would depend on the oil you use. For that kind of oci a conventional or a synthetic blend oil would be just fine. No need for higher priced synthetics imo.
Edit to add: With that kind of mileage you could change your filter just once a year. Something to ponder.
2017 Mazda CX5
Havoline Pro DS 0w20
Roki OEM filter.
Re: Can Oil be changed too much? [Re: Tikka] #4772233
05/30/18 11:51 AM
05/30/18 11:51 AM
Illinois
javacontour Offline
javacontour  Offline
Illinois
I thought there was a study / paper done by Ford that showed higher wear just after an oil change compared to after the oil has been in use for a while.
If I am remembering correctly, then it's possible that too frequent of oil changes can lead to higher wear due to the higher than typical wear for some period after the oil change.
However, I still believe the rest of the car will wear out long before the engine does in most cases.
network down, IP packets delivered via UPS -BOFH
Re: Can Oil be changed too much? [Re: Tikka] #4772272
05/30/18 12:25 PM
05/30/18 12:25 PM
Oshawa, Ontario Canada
JC1 Offline
JC1  Offline
What oil are you using Tikka?
That oil isn't being changed too much. My wife's civic is usually a short tripper most times. It is stored in a Garage so usually winter starts aren't that bad on it. I normally use Full synthetic in the car.
2015 Grand Caravan SXT Plus 5w-30 Valvoline White Bottle/Fram Ultra Filter
1997 Honda Civic CX 5w-30 Shell Conventional/Fram Ultra Filter
Re: Can Oil be changed too much? [Re: Tikka] #4772278
05/30/18 12:32 PM
05/30/18 12:32 PM
Oregon
1JZ_E46 Offline
1JZ_E46  Offline
Oregon
I read somewhere on here that a member changes the oil filter AFTER an oil change (say a hundred miles of so) because its better for wear. Any truth to that? Id be afraid of forgetting!
2007 X5 4.8i: M1 HM 10W-30
2016 Countryman S: Castrol 0W-40
Re: Can Oil be changed too much? [Re: Tikka] #4772281
05/30/18 12:38 PM
05/30/18 12:38 PM
Connecticut
69GTX Offline
69GTX  Offline
Connecticut
3000 miles every 6 month OCI for a short tripper in cooler weather is not too often. Some of those oil studies suggest that that some of the protective chemical barriers are stripped down to a degree in the first 1,000 miles or so following an oil change. The real question is 'how much' and if such an amount leads to any significant wear increase over the life of the vehicle (ie 150K-300K miles).
With that kind of very low annual mileage, maybe too often is slightly more detrimental. But would you see the difference by 100,000 miles? 200K miles? Then again most oil companies and car manufacturers would probably recommend changing oil at least every year regardless of how low the miles are.
I think the notion of letting some old oil via the filter stay in the system after an OCI is part of this same 'logic' to enable the protective chemical layers better resist the attack of the new oil. As far as the accuracy of such...no clue. But the topic has been discussed many times before.
2001 Lincoln Cont 4.6L DOHC/ 39K mi / QS HM 5w30 / FUG XG2
1969 Ply GTX/RRs
Re: Can Oil be changed too much? [Re: Tikka] #4772286
05/30/18 12:45 PM
05/30/18 12:45 PM
North Carolina
rooflessVW Offline
rooflessVW  Offline
North Carolina
Jeez I hope not.
If so, I'm screwed!
"Zed's dead baby, Zed's dead."
Re: Can Oil be changed too much? [Re: Tikka] #4772291
05/30/18 12:50 PM
05/30/18 12:50 PM
OH
SatinSilver Offline
SatinSilver  Offline
OH
Yes it sure can be changed too often. Some of the additives that are quickly burned off after new oil is put in the engine can be harmful to the catalytic converter. Which isn't cheap to replace. Change when the manufacturer says to.
Re: Can Oil be changed too much? [Re: Tikka] #4772297
05/30/18 12:53 PM
05/30/18 12:53 PM
Balearic Islands , Spain
FordCapriDriver Offline
Well, it's proven that for example oil filters work best once they have been on the engine for a while, it's also known that engine wear is highest right after an oil change and steadily goes down after that ( given reasonable intervals ofcourse )
This was found out by carrying out a study on large fleets of cars where the oil was changed at a few different intervals and wear results were compared.
So in a way, yes
1975 Ford Capri II Ghia 3000 V6, - Shell Helix HX3 20W-50 w/ 20% Rimula R4X 15W-40 HDEO.
1988 Ford Escort XR3i Cabrio, - Shell Rimula R4X 15W-40
G40 Si-OAT coolant in both
Re: Can Oil be changed too much? [Re: Tikka] #4772298
05/30/18 12:54 PM
05/30/18 12:54 PM
Texas (south)
FermeLaPorte Offline
Texas (south)
Never. It's better to change it every time is needed than to be a cheapsteak weirdo who lets the oil go thru more than 5,000 miles.
Always Mobil 1
2014 1.6L Nissan Versa Sedan, 5 spd, 5k OCI.
2011 3.5L Chevrolet Impala, Automatic, 5k OCI.
Re: Can Oil be changed too much? [Re: FermeLaPorte] #4772300
05/30/18 12:57 PM
05/30/18 12:57 PM
I let conventional go 6000 miles, *gasp*.
Oh and have never experienced engine wear issues.
Re: Can Oil be changed too much? [Re: Tikka] #4772302
05/30/18 12:58 PM
05/30/18 12:58 PM
Occupied Virginia
Bottom_Feeder Offline
Occupied Virginia
'cheapsteak'? lol
Re: Can Oil be changed too much? [Re: rooflessVW] #4772323
05/30/18 01:19 PM
05/30/18 01:19 PM
Virginia
bbhero Offline
bbhero  Offline
Virginia
Response of the day winner goes to:
rooflessVW smile
Well done.
Nissan Altima 3.5 Coupe
Havoline high mileage 5w30 Microgard 57356
"Treat your family like your friends and treat your friends like your family."
Re: Can Oil be changed too much? [Re: Tikka] #4772324
05/30/18 01:19 PM
05/30/18 01:19 PM
Columbus,Nebraska
Yah-Tah-Hey Offline
Yah-Tah-Hey  Offline
Columbus,Nebraska
I change oil and filter every six months even though we only drive less than five thousand miles a year. Don't worry about it. It is what some consider wasteful but that isn't a mortal sin.
Page 1 of 6 1 2 6
