Miscellaneous Ford 6.7L Powerstroke Parts
by 2015_PSD. 02/23/19 05:44 PM
Just bought 07 Accord VP
by maverickfhs. 02/23/19 05:44 PM
[Cut Open] Motorcraft FL500S - 5003 miles
by DuckRyder. 02/23/19 05:08 PM
Does Kia & Hundai use same motors?
by tc1446. 02/23/19 05:07 PM
Extreme fuel dilution
by BigShug681. 02/23/19 04:52 PM
Nine PH3600-size filters FS
by SubieRubyRoo. 02/23/19 04:45 PM
2003 Accord 2.4L Valve train pics
by WagonWheel. 02/23/19 04:24 PM
Leaky FL400s
by jongies3. 02/23/19 03:55 PM
Fram Ultra with Filter Mag pics
by ZZman. 02/23/19 03:39 PM
Which 0w20 meets VW 508.00?
by 53' Stude. 02/23/19 03:28 PM
RockAuto Injectors - Return / Weird
by StevieC. 02/23/19 02:23 PM
03 Nissan Maxima stalls uphill.
by LeakySeals. 02/23/19 01:47 PM
Delvac Rebate?
by 1JZ_E46. 02/23/19 01:23 PM
Oil recommendation for Audi turbo engine
by zorba02. 02/23/19 12:41 PM
Jeep Cherokee 2.4L oil consumption
by RedOak. 02/23/19 12:14 PM
2001 Grand Cherokee Rear Diff Lube
by Plimbob. 02/23/19 12:13 PM
2005 Forester Upper Radiator Hose
by HowAboutThis. 02/23/19 12:05 PM
snapy907, Barrett, Beez1204, vmasse, zorba02
67327 Registered Users
102 registered members (2strokeNorthstar, 379KITTY, 2015_PSD, 69GTX, AandPDan, 2oldtommy, 11 invisible), 1,877 guests, and 51 spiders.
Topics284,728
Posts4,875,867
Members67,327
Most Online2,548
Feb 16th, 2019
Page 1 of 4 1 2 3 4
Should I look into replacing the AC unit? #4771984
05/30/18 06:53 AM
05/30/18 06:53 AM
Cleveland
xBa380 Offline OP
xBa380  Offline OP
Cleveland
The AC unit on the house is original, 28 years old. Reliable, blows cold and keeps the house comfortable without problem to any temp it's set at. Does not require any maintenance/repair. Had a tech out once years ago and he commented the unit was in great shape and it's blowing very cold and did not recommend replacement.
But when itís hot, the unit just seems to run almost constantly (or at least cycles very often). Either itís just because Iím paying attention more, itís been very hot/humid lately or the unit is slowly getting more inefficient and working harder. If itís 90 outside, the unit can get the house down to 72 no problem. It seems to work really well. I keep the unit at 72 at night, 77 during day when at work and 75 at normal times in the evening.
But I canít help but thinkÖ Would it be worth it in the fall to consider a new unit to something more ďenergy efficientĒ or do I risk having a unit that performs worse and doesnít save that much money on cooling bills? Would the payback for a more energy efficient unit be something like 4-5 years or something like 10-15 that won't really matter?
Just wanted to get some thoughts from those who are more experienced with this stuff. Seems like the unit has done itís job well for the past 28 years or so, but wondering if itís time to replace or just let it go until it breaks and then replace it. We do need to replace the upstairs windows as they are shot, so that doesn't help, but will be coming soon enough before next summer for sure. Other windows have been replaced already on the mid and lower level of the house.
Thoughts/suggestions?
Re: Should I look into replacing the AC unit? [Re: xBa380] #4771992
05/30/18 06:59 AM
05/30/18 06:59 AM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
The more efficient one may be made offshore. It won't last like your currant one has.
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: Should I look into replacing the AC unit? [Re: xBa380] #4772005
05/30/18 07:11 AM
05/30/18 07:11 AM
VW Fanboy Island
maxdustington Offline
VW Fanboy Island
It sounds like the argument for a new, fuel efficient car over and older, less fuel efficient car. Only makes sense when you want a new car to drive.
If it is really humid, it is going to run all the time. I would put money into windows as they will help during the winter too. Nice windows are nice, makes you look like you actually care about the condition of your house.
03 Jetta AWP/09A 205k kms
Edge 0W40 + Mann 719/30
Re: Should I look into replacing the AC unit? [Re: xBa380] #4772006
05/30/18 07:12 AM
05/30/18 07:12 AM
Texas
WyrTwister Offline
WyrTwister  Offline
Texas
Dollars and cents , compare you electric bill to what it would be with a high efficiency unit .
Also , you will fine parts for a high efficiency unit are likely to be $$$ !
It is normal for the A/C to run longer , the hotter it gets . A perfect design would run continually at the max temperature day . Running longer , I am told , also works better to remove humidity .
One big selling point is the very high price of R-22 refrigerant , if it develops a leak . Personally , I think many contractors over sell that point .
For better or worse , I do my own HVAC work .
Wyr
God bless
Re: Should I look into replacing the AC unit? [Re: xBa380] #4772016
05/30/18 07:21 AM
05/30/18 07:21 AM
The Midwest
skyactiv Offline
skyactiv  Offline
The Midwest
Me: 13' VW GTI 3 door 6 speed manual
Wanted: 2019 Ford Ranger
Re: Should I look into replacing the AC unit? [Re: xBa380] #4772038
05/30/18 07:38 AM
05/30/18 07:38 AM
N.H, U.S.A.
ARCOgraphite Offline
N.H, U.S.A.
I had to replace a unit in my mothers condo in FL and a large RUUD was 6700 incl labour which is a ripoff as the unit was only 3700 and the (2) guys were there only 3 hours AND IT DIDNT WORK ANY BETTER THAN THE OLD UNIT. - but my compressor was screaming and it had to be done. Also the air handler/evaporator in the closet was rusting out and the drip traty was leaking into the garage ceiling below. Sold the house 2 months later.
I would RESEARCH units and installers but wait till she gives up the ghost.
You may want to revisit that 72deg F setting at night to save some money; Seems too low for the summer.
Sleep naked with a VERY think light cotton sheet - or just a small towel.
Then NO AC will be best smile.
2019 VW Jetta S,6M OCI#0 1136mi-Castrol Edge Prof? VW508+OE Filter; '17 Subaru Crosstrek CVT OC#6 43467mi-Valvoline Adv 0w20 + SOA Filter
Re: Should I look into replacing the AC unit? [Re: xBa380] #4772039
05/30/18 07:39 AM
05/30/18 07:39 AM
Glendale, Arizona
billt460 Offline
billt460  Offline
Glendale, Arizona
If it's running good, don't mess with it. As was mentioned, the biggest downside is the cost of refrigerant of the older models. But if yours doesn't leak, don't get caught up worrying about what you don't have to buy. My cheap builder grade unit that came with the house lasted 15 years out here in Phoenix. That is almost unheard of out here, because we put more wear and tear on a A/C unit in a year than the Midwest does in 5. Once the daytime temperatures get above 110F, the units run pretty much continually day and night.
When I finally replaced it, with what was supposed to be a "state of the art" modern, efficient unit, I ended up going through 3 complete refills of R-410 refrigerant in 3 years. Before they found the condenser was leaking. The part was covered under warranty. But the labor ended up costing me over $1,500.00. New doesn't always mean better. My cheap, inefficient builder grade unit never leaked a drop, or ever required a service call.
Re: Should I look into replacing the AC unit? [Re: xBa380] #4772041
05/30/18 07:39 AM
05/30/18 07:39 AM
Lakeside, CA
Blkstanger Offline
Blkstanger  Offline
Lakeside, CA
"New" isn't always better. I'd keep it clean and use it till it fails.
99 Jeep WJ 4.7 197,000 Maxlife 10w30, Fram Ultra.
Re: Should I look into replacing the AC unit? [Re: xBa380] #4772042
05/30/18 07:40 AM
05/30/18 07:40 AM
Pennsylvania
bugeye Offline
bugeye  Offline
Pennsylvania
Our 1971 central air conditioning unit lasted 32 years. I cleaned the indoor and outdoor coils every year. When the compressor finally gave up, everything was replaced. Coil, tubing, electrical, compressor/condenser unit all highest efficiency. Our summer electric bill dropped about $100 per month. And, the house is more comfortable with better dehumidification. Worth the $ to me.
Re: Should I look into replacing the AC unit? [Re: xBa380] #4772044
05/30/18 07:41 AM
05/30/18 07:41 AM
Houston, Texas
motor_oil_madman Online content
motor_oil_madman  Online Content
Houston, Texas
If it still works keep it. What brand is it? You do realize that a.c. systems nowadays only last 10-15 years max right? Plus they break down, need a capacitor every couple years. Every 6 months if your repair guy uses cheap capacitors.
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
Re: Should I look into replacing the AC unit? [Re: xBa380] #4772056
05/30/18 07:52 AM
05/30/18 07:52 AM
Oklahoma
Schmoe Offline
Schmoe  Offline
Oklahoma
If it ain't broke, don't fix it and in the mean time, start putting away some money so that when you do replace it, it won't break your bank.
01 Supercrew Lariat 4X4
06 Accord EX-L V6
14 CRV EX-L (RIP) 2018 CRV EX-L
Re: Should I look into replacing the AC unit? [Re: xBa380] #4772061
05/30/18 07:55 AM
05/30/18 07:55 AM
Oshawa, Ontario Canada
JC1 Offline
JC1  Offline
Have the coils been cleaned inside (near the furnace unit) and how often to you spray the fins on the external unit?
Also how is the insulation in your attic and how well does it breath to get rid of the hot air? I added extra insulation in our attic, put in baffles for the soffits and added ridge vents to the front half of my house to keep the attic cooler in the summer months.
That makes a big difference as well to keep the house cooler.
If it's not killing your hydro bills, I would keep the old unit.
2015 Grand Caravan SXT Plus 5w-20 Valvoline SynPower/Fram Ultra Filter
1997 Honda Civic CX 5w-30 PPPP/Fram Ultra Filter
Re: Should I look into replacing the AC unit? [Re: xBa380] #4772071
05/30/18 08:00 AM
05/30/18 08:00 AM
New England
madRiver Offline
madRiver  Offline
New England
not an HVAC expert however if it runs constantly in extremes and cools/heats fine it means that is sized appropriately.
You may get better energy bills with modern system however the recovery cost you have to figure out.
Re: Should I look into replacing the AC unit? [Re: billt460] #4772074
05/30/18 08:00 AM
05/30/18 08:00 AM
Texas
WyrTwister Offline
WyrTwister  Offline
Texas
A lot depends on the skill level of the installer & how much he / she cares . Especially when it comes to leaks . Of course , if you have a leaky piece of hardware , no amount of skill or dedication is going to offset it .
Seems like every time they change designs to cut cost , they have problems / growing pains . The old designs / materials worked OK . Then the bean counters get involved ! :-(
Consider mini split ductless units . They can be had with very high SEER ratings . Either straight A/C or heat pumps . We installed 2 with the help of family members .
Wyr
God bless
Re: Should I look into replacing the AC unit? [Re: xBa380] #4772076
05/30/18 08:01 AM
05/30/18 08:01 AM
California
VeryNoisyPoet Offline
California
Clean coils and fans inside and out and replace the filter regularly. A new unit probably won't pay for itself anytime soon, so replace the old one when it suffers a major failure equivalent to a good chunk of the cost of a new unit.
The unit running almost flat out on the hottest days of the year and still keeping the house comfortable means that it is properly sized for the house and climate and running most efficiently. As others have said, look into improving the sealing at windows and doors, which makes a big difference in how much humid outside air infiltrates the house.
1998 V70 GLT / 202k miles [10w-30 Valvoline Syn w/ Maxlife Tech + Mann W917 filter]
"Use yah blinkah!"
"Be nice. The alternative involves an air horn and 7000 lumens of high beam."
Page 1 of 4 1 2 3 4
Moderated by  ekpolk
