Shell Spirax 85W-140
by kstanf150 - 09/20/19 03:03 PM
Happy B-Day, BCardinal
by pandus13 - 09/20/19 02:51 PM
Oil temps: Summer vs Winter
by Snagglefoot - 09/20/19 12:42 PM
2008 Hyundai Sonata 2.4 - poor heat
by Number_35 - 09/20/19 11:40 AM
Odd situation. What would you do?
by skaughtz - 09/20/19 11:35 AM
Honda CVT and 6AT fluid replacement
by Schmoe - 09/20/19 11:05 AM
Oil pump problem???
by Speak2Mountain - 09/20/19 10:55 AM
Installing a New Transmission Gasket Question
by Kira - 09/20/19 10:48 AM
2010 Honda Accord P/S pump talking a bit
by Kira - 09/20/19 10:45 AM
What size Jack Stands do you use?
by JC1 - 09/20/19 10:24 AM
Engine oil & CAFE program and MPG ratings
by littleant - 09/20/19 10:06 AM
SMOG Test - OBDII Monitors Not Ready
by JeffKeryk - 09/20/19 09:57 AM
CI-4 Plus at Tractor Supply
by bbslider001 - 09/20/19 08:29 AM
2017 Chrysler Pacifica Oil
by Mathew_Boss - 09/20/19 08:08 AM
Flood cars from Houston
by Snagglefoot - 09/20/19 07:44 AM
Deep Sumps
by RC_Kendall - 09/20/19 07:24 AM
SpencerCreek, Debe, Rengrox, Jenel7, Jeojevero
69341 Registered Users
92 registered members (4WD, 02vito, 330indy, Aichiguy, ammolab, alchargo, 7 invisible), 2,184 guests, and 27 spiders.
Topics294,826
Posts5,067,447
Members69,341
Most Online3,532
Jul 30th, 2019
Exhaust stud oil leak repair attempt #4771605 05/29/18 08:07 PM
V
VeryNoisyPoet Offline OP
V
A few thousand miles ago, I began to get occasional whiffs of a "hot smell" in the cabin. At first I thought a raw exhaust leak, but it didn't happen with a cold engine. It somewhat smelled like burning rubber, but there weren't any rubber parts getting that hot either. The smell would go away if I put the cabin heater on recirc. I also noticed oil consumption had increased slightly. Next time I had it up in the air, I looked around and saw part of the exhaust manifold damp with oil.
This leak is NOT from the cam cover gasket, as it is completely dry up above the manifold. It also is not coming from a valve stem seal. In order for that much oil to appear outside the manifold, it would need to be puking enough oil into the exhaust to fumigate the whole neighborhood. The oil is definitely coming from around one stud, then running down the manifold until it burns off and makes a bad smell.
The nut is seized solid to the stud, so both came out when I tried to unscrew it. Stud was damp with fresh oil. Here's a pic with the stud removed showing the oil dampness:
I can't get a very good angle on it and the focus is terrible, but I got my inspection camera up there to see the far end of the stud hole damp with oil, suggesting a tiny crack or defect in the head allowing oil to seep out.
At first I tried using oil resistant RTV to seal the stud, but it would largely get squeegeed off as the stud screwed in, and the leak would return in a few weeks. I cleaned the threads very thoroughly with throttle body spray and a pipe cleaner each time, but the RTV was just not meant for what I was asking of it.
I just put it back together with Permatex High-Temp Thread Sealant, so I'm hoping that provides the fix I've been looking for. Sealant is meant for threaded fuel, hydraulic, coolant, and oil fittings and withstands 400F / 204C.
This is less a question thread and more of a chronicle of my attempts to repair this problem plus follow ups. Feel free to add any tips you may have. "Do it right - replace the entire head" and "old car - let it leak" are not acceptable in this case. LOL
1998 V70 GLT / 202k miles [10w-30 Valvoline Syn w/ Maxlife Tech + Mann W917 filter]
"Use yah blinkah!"
"Be nice. The alternative involves an air horn and 7000 lumens of high beam."
Re: Exhaust stud oil leak repair attempt [Re: VeryNoisyPoet] #4771617 05/29/18 08:16 PM
A
AVB Offline
A
It appears that the stud has been screwed in too deep. It looks like it has been bottomed out leaving a clean, galled mark at the bottom.
Re: Exhaust stud oil leak repair attempt [Re: AVB] #4771621 05/29/18 08:19 PM
V
V
Aha - that might be the issue. Interesting how it only started leaking just this past year with over 180k on the clock instead of right away as a factory defect. The exhaust manifold is original and has never been off the car as far as I know.
"Use yah blinkah!"
Re: Exhaust stud oil leak repair attempt [Re: VeryNoisyPoet] #4771624 05/29/18 08:22 PM
A
AVB Offline
A
If it is bottomed out there should be a similar swirl mark on the end of the stud. It also could be from when the hole was threaded, but I wouldn't expect it to be that clean and fresh looking.
Re: Exhaust stud oil leak repair attempt [Re: AVB] #4771636 05/29/18 08:32 PM
V
V
End of stud looks normal and not swirled. No reason why it wouldn't be clean though, since it is largely shielded and sealed from the elements.
"Use yah blinkah!"
Re: Exhaust stud oil leak repair attempt [Re: VeryNoisyPoet] #4771662 05/29/18 08:51 PM
A
AVB Offline
A
It just looks a little too freshly machined compared to the oil stained perimeter.
Re: Exhaust stud oil leak repair attempt [Re: AVB] #4771671 05/29/18 09:01 PM
V
V
I get what you're saying, though that could also be clean metal that just has fresh oil seeping at the perimeter. Hopefully the thread sealant works to plug up the leak. I'll keep this thread up to date on what I find.
"Use yah blinkah!"
Re: Exhaust stud oil leak repair attempt [Re: VeryNoisyPoet] #4771687 05/29/18 09:15 PM
A
AVB Offline
A
It can be tough to seal straight threads, proper thread sealant will probably take care of it though.
Re: Exhaust stud oil leak repair attempt [Re: VeryNoisyPoet] #4771734 05/29/18 09:53 PM
A
andyd Online Content
Online Content
A
Start with a new stud. Any stud that came out without a struggle is bound to be half stripped. Normally exhaust studs rust tight. Please keep thread updated. TIA
Thick oil is better grin2
Re: Exhaust stud oil leak repair attempt [Re: andyd] #4771741 05/29/18 09:57 PM
V
V
The stud was quite stiff the first time I backed it out but there was some junk on the threads from all the crusty oil. Threads look pretty good to me. Here's a pic of the stud after I cleaned it up that I forgot to add in the first post:
"Use yah blinkah!"
Re: Exhaust stud oil leak repair attempt [Re: VeryNoisyPoet] #4771791 05/29/18 10:59 PM
A
Online Content
A
Feel the edges of the threads, they look sharp. New threads would be blunter and more rounded an run in tighter. More than once I have replaced a worn stud or a nut and had it hold sufficient torque. YMMV
Re: Exhaust stud oil leak repair attempt [Re: andyd] #4771798 05/29/18 11:03 PM
V
V
If it leaks again I'll pull it out and check. New ones are cheap enough. Here's the image on FCP of what a new stud looks like:
"Use yah blinkah!"
Re: Exhaust stud oil leak repair attempt [Re: VeryNoisyPoet] #4784304 06/11/18 08:38 PM
V
V
UPDATE: Looks like I fixed the leak. (Knock on wood)
Next day after I applied the thread sealant, the burning smell reduced from heavy to intermittent, showing up only when I stopped after driving a while, but not when sitting in traffic. After I fixed the turbo bypass valve, the smell has completely stopped. There might have been some oil mist getting out past the failed valve diaphragm and spraying the turbo exhaust housing.
I've put on about 200 miles including sitting in slow traffic and WOT pulls testing the turbo, with no sign of returning smells.
"Use yah blinkah!"
Re: Exhaust stud oil leak repair attempt [Re: VeryNoisyPoet] #4784397 06/11/18 10:14 PM
M
maxdustington Offline
M
You drive a smelly 20 year old car!
03 Jetta AWP/09A 210k kms
Edge 0W40 + Mann 719/30
Re: Exhaust stud oil leak repair attempt [Re: maxdustington] #4784399 06/11/18 10:17 PM
V
V
Surprisingly, besides the burning oil, it doesn't stink. Catalytic converter works just fine so exhaust just smells like steam, and the interior is well used but clean. Perhaps that's why the oil smell is so annoying when it does show up, because I'm not used to my car smelling like it's on fire! LOL
"Use yah blinkah!"
