A few weeks ago our Fusion sprung a P0130 code, accompanied by a CEL. I cleared the code using Forscan, but the code came back the next day. Oddly, it then cleared itself and hasn't come back, but fuel mileage has been [censored] ever since. I finally got around to using Forscan to take some live readings of both o2 sensors... once warmed up fully, the upstream o2 sensor stays stuck at 0.09 to 0.10v. If I shut the car off it shows 5.0V. If I restart the car, the readings start at about 1.0v and drop quickly to the 0.1v number. Doesn't matter what I do with the loud pedal, it's stuck. The data shows that the heater circuit is working. The downstream sensor hovers around 0.08v once warmed up, and with light throttle it stays there too; but a quick throttle blip will bring it down very close to 0.0 (lean), and then it goes back up to around 0.08. All seems well for the downstream.
Oddly, I'm not getting a CEL currently, but the code IS stored in the PCM when I scan the vehicle. Sounds like a bad upstream sensor, as the P0130 indicates?
