Oil recommendation for 2014 2.5l Suburu Forester
by tomartomau - 08/23/19 11:32 PM
Castrol 5W50
by Snagglefoot - 08/23/19 11:29 PM
Camry Broke Down
by Nick1994 - 08/23/19 10:51 PM
Pumpkin Beer
by Capt - 08/23/19 09:26 PM
Possible bad Iridium plug
by Eric Smith - 08/23/19 08:57 PM
Is the 5.7gm engine still made brand new?
by motor_oil_madman - 08/23/19 08:19 PM
Motomaster OEPlus MOPH/MOCH Filters
by gamefoo21 - 08/23/19 07:29 PM
Man's best friend!
by Mad_Hatter - 08/23/19 06:53 PM
2007 Ford Fusion Cam Pics
by tig1 - 08/23/19 05:31 PM
Cloning a Lexus key
by Nayov - 08/23/19 04:23 PM
2011 GMC Acadia Shock/Strut Replacement
by panthermike - 08/23/19 03:49 PM
Confusion on oil to use on BMW 328i 2010
by goldenjava - 08/23/19 03:21 PM
ProSelect 27356 cut open
by Sayjac - 08/23/19 03:04 PM
Electrolux - Dryer reliability warning.
by pezzy669 - 08/23/19 02:37 PM
Microfiber Towels for different applications?
by Quattro Pete - 08/23/19 01:53 PM
Coated vs. painted rotors
by atikovi - 08/23/19 01:13 PM
New spark plugs, occasional misfire
by avacado11 - 08/23/19 12:34 PM
goldenjava, Spuzzum, ta249, bobsauto62, Ramz
69044 Registered Users
28 registered members (bdcardinal, ArrestMeRedZ, 4WD, 14Accent, 2002 Maxima SE, 4 invisible), 704 guests, and 20 spiders.
Topics293,713
Posts5,045,449
Members69,044
Most Online3,532
Jul 30th, 2019
How much refrigerant is in a can? #4771400 05/29/18 05:07 PM
J
joegreen Offline OP
J
So i am in the process of buying refrigerant to fill my vehicle. It seems like an easy enough question but i couldnt find any info online. Lets say i have a can of r134a and it says net weight 12oz. Does that mean the can contains 12oz of refrigerant or does the can and refrigerant weight 12oz? Im just trying to figure out how many cans of r134a i need.
1978 Chevrolet k20
Engine: Delo 10w30xle
Transmission: Castrol transmax dex/merc
1984 Mercedes-Benz 300 turbo diesel
Engine: Delo 400 15w40le
Re: How much refrigerant is in a can? [Re: joegreen] #4771401 05/29/18 05:09 PM
K
kschachn Offline
K
http://www.businessdictionary.com/definition/net-weight.html
1994 BMW 530i, 246K
1996 Honda Accord, 280K
1999 Toyota Sienna, 420K
2000 Toyota ECHO, 281K
Re: How much refrigerant is in a can? [Re: joegreen] #4771414 05/29/18 05:22 PM
M
mrsilv04 Offline
M
You have to read the can. Some will have a small amount of oil in them as well.
I have a 12 ounce can in the garage, which is labelled as containing 11.3 ounces of R-134a, and .7 ounces of refrigerant oil.
2004 Silverado - on its 3rd Jasper engine in less than one year.
Re: How much refrigerant is in a can? [Re: joegreen] #4771415 05/29/18 05:23 PM
rollinpete Offline
Usually under the hood some where, it will tell you how much you need, for your system.
Got to go from there.
Pete.
97 Ford Expl.Sport 4.0 ohv 4wd 5spd 188k miles
03 Saturn Ion 2.2 L4 5spd 239k miles
PP, PPHM 50/50 5w30
Currently under the influence of oil shocked2
Re: How much refrigerant is in a can? [Re: joegreen] #4771428 05/29/18 05:42 PM
slacktide_bitog Offline
"net weight" is the weight of just the contents inside the can smile
"tare weight" is the weight of the container itself, and "gross weight" is the "net"and "tare" weights
Re: How much refrigerant is in a can? [Re: rollinpete] #4771589 05/29/18 08:00 PM
J
joegreen Offline OP
J
I need 1lb 14oz. Im just trying to figure out how many cans i need to buy is all
1978 Chevrolet k20
Re: How much refrigerant is in a can? [Re: kschachn] #4771591 05/29/18 08:02 PM
J
joegreen Offline OP
J
Thanks i understand now
1978 Chevrolet k20
Re: How much refrigerant is in a can? [Re: slacktide_bitog] #4771593 05/29/18 08:02 PM
J
joegreen Offline OP
J
Thanks
1978 Chevrolet k20
Re: How much refrigerant is in a can? [Re: joegreen] #4771594 05/29/18 08:02 PM
J
joegreen Offline OP
J
Looks like ill get 3 cans and put 2.5 cans in.
1978 Chevrolet k20
Re: How much refrigerant is in a can? [Re: joegreen] #4771650 05/29/18 08:39 PM
T
tomcat27 Offline
T
Is your system totally empty and do you have a vacuum pump?
2019 Cherokee, 2018 Jetta, 2014 Sentra, 2001 Camry, 1995 Escort, 1970 Cougar, 2013 XT250, 2010 Vstar, 2014 CTX1300
Re: How much refrigerant is in a can? [Re: joegreen] #4771752 05/29/18 10:09 PM
L
Linctex Offline
L
There's usually enough reserve in the accumulator to handle that last 1/2 a can
Re: How much refrigerant is in a can? [Re: joegreen] #4771754 05/29/18 10:12 PM
spasm3 Offline
It seems to me that the old r12 system worked well even when undercharged or overcharged a bit. It seems to me that with the r134a systems , there is a fine line between undercharged and overcharged.
13 elantra 78k 5w30 synpwr
17 mazda cx-5 12300 miles m1 0w30
Re: How much refrigerant is in a can? [Re: tomcat27] #4778394 06/05/18 05:28 PM
J
joegreen Offline OP
J
Yes the system is totally empty. I have a gauge set and a vacuum pump. Anyway the a/c is all repaired now. thanks
1978 Chevrolet k20
Re: How much refrigerant is in a can? [Re: spasm3] #4778446 06/05/18 06:29 PM
N
nthach Offline
N
Depends on the system as well, new AC systems are very sensitive to oil and refrigerant charge. That old GM accumulator and orifice tube system can tolerate some overcharge.
If you charged in with all 3 cans, I don't think an extra 5 oz of R-134a will hurt anything. You lost some while changing out cans, purging the charging hose and gauges.
