How much refrigerant is in a can?
NY
So i am in the process of buying refrigerant to fill my vehicle. It seems like an easy enough question but i couldnt find any info online. Lets say i have a can of r134a and it says net weight 12oz. Does that mean the can contains 12oz of refrigerant or does the can and refrigerant weight 12oz? Im just trying to figure out how many cans of r134a i need.
http://www.businessdictionary.com/definition/net-weight.html
You have to read the can. Some will have a small amount of oil in them as well.
I have a 12 ounce can in the garage, which is labelled as containing 11.3 ounces of R-134a, and .7 ounces of refrigerant oil.
"net weight" is the weight of just the contents inside the can
"tare weight" is the weight of the container itself, and "gross weight" is the "net"and "tare" weights
Originally Posted By: rollinpete
Usually under the hood some where, it will tell you how much you need, for your system.
Got to go from there.
I need 1lb 14oz. Im just trying to figure out how many cans i need to buy is all
Thanks i understand now
Thanks
Looks like ill get 3 cans and put 2.5 cans in.
It seems to me that the old r12 system worked well even when undercharged or overcharged a bit. It seems to me that with the r134a systems , there is a fine line between undercharged and overcharged.
Originally Posted By: tomcat27
Is your system totally empty and do you have a vacuum pump?
Yes the system is totally empty. I have a gauge set and a vacuum pump. Anyway the a/c is all repaired now. thanks
Depends on the system as well, new AC systems are very sensitive to oil and refrigerant charge. That old GM accumulator and orifice tube system can tolerate some overcharge.
If you charged in with all 3 cans, I don't think an extra 5 oz of R-134a will hurt anything. You lost some while changing out cans, purging the charging hose and gauges.
