Cut the cord, finally
by 14Accent. 05/21/19 10:29 PM
Av Gas 100LL in small engines and other things
by earthmover1980. 05/21/19 10:11 PM
Yamaha R1 on the Autobahn
by AZjeff. 05/21/19 09:11 PM
Sea Foam question
by vavavroom. 05/21/19 08:40 PM
Study on detergent additives and abrasiveness
by addyguy. 05/21/19 08:33 PM
ST9688 oil filter on motorcycle?
by AuthorEditor. 05/21/19 05:56 PM
Circle K frustrations
by Mark72. 05/21/19 05:44 PM
Milesyn SXR, 0w20, 5,100mi, 2018 Mazda3 2.5L
by RayCJ. 05/21/19 05:42 PM
What filter are the 2AZ-FE owners using?
by 53' Stude. 05/21/19 05:28 PM
NEW TOUGH GUARD 4386 CUT OPEN
by 53' Stude. 05/21/19 05:26 PM
300v 5w40 vs Redline racing 15w40
by junkyard_sal. 05/21/19 05:25 PM
Honda 1.5T Edge 0W40 8,800mi.
by dblshock. 05/21/19 05:17 PM
Cub Cadet LTX1050VT keeps shredding mower belts
by oilpsi2high. 05/21/19 04:27 PM
What’s the best price for a set
by ShutdownCorner. 05/21/19 04:01 PM
So who uses Exxon-Mobil EHC basestocks?
by csandste. 05/21/19 03:40 PM
Thoughts on this article?
by RyanY. 05/21/19 03:27 PM
BG products any good?
by Chris B.. 05/21/19 03:22 PM
Would you rather have three cars or two?
by brages. 05/21/19 02:01 PM
Fordpuppy, Geowebby, slugworks, tlogic, Danr42
68172 Registered Users
86 registered members (AC1DD, AFresca, 14Accent, 01rangerxl, 2015_PSD, andyd, 9 invisible), 1,608 guests, and 26 spiders.
Topics289,214
Posts4,964,721
Members68,172
Most Online2,967
Mar 10th, 2019
Page 1 of 3 1 2 3
Oil surface tension #4771041
05/29/18 10:14 AM
05/29/18 10:14 AM
Massachusetts, USA
cpetroff Offline OP
cpetroff  Offline OP
Massachusetts, USA
Looking for a low viscosity oil with a high surface tension. Does PAO 6 or mineral oil have a higher surface tension at room temperature? Any additives that could increase surface tension? Other types of oils that have higher surface tension? Any ideas on how to measure surface tension?
Re: Oil surface tension [Re: cpetroff] #4771055
05/29/18 10:37 AM
05/29/18 10:37 AM
Upper Midwest
kschachn Offline
kschachn  Offline
Upper Midwest
Absolutely, I used to do it all the time in college. You need a surface tensiometer.
1994 BMW 530i, 242K
1996 Honda Accord, 275K
1999 Toyota Sienna, 413K
2000 Toyota ECHO, 281K
Re: Oil surface tension [Re: cpetroff] #4771193
05/29/18 01:20 PM
05/29/18 01:20 PM
California
DGXR Offline
DGXR  Offline
California
When you say surface tension, do you mean oil film strength? This is what helps prevent metal-to-metal contact inside engines before oil pressure builds up.
I'm just not sure how the surface tension of an oil relates to its performance.
1995 Corvette coupe LT1 6-speed
2006 Tacoma 2.7 Base SR5 AC
1999 Yamaha YZ400FL
2003 Honda XR400R
Re: Oil surface tension [Re: cpetroff] #4771197
05/29/18 01:22 PM
05/29/18 01:22 PM
Upper Midwest
kschachn Offline
kschachn  Offline
Upper Midwest
And as far as I know it also isn’t related to the viscosity.
1994 BMW 530i, 242K
Re: Oil surface tension [Re: cpetroff] #4771330
05/29/18 03:42 PM
05/29/18 03:42 PM
NJ, USA
MotoTribologist Offline
NJ, USA
No difference that could be discerned outside of a surface tensiometer.
Tackifiers should increase the surface tension.
Bar and chain oil would have a pretty stout surface tension
As mentioned above, surface tensiometer
Re: Oil surface tension [Re: MotoTribologist] #4771355
05/29/18 04:07 PM
05/29/18 04:07 PM
Upper Midwest
kschachn Offline
kschachn  Offline
Upper Midwest
Tackifiers make the oil cling but is that a direct correlation to surface tension?
1994 BMW 530i, 242K
Re: Oil surface tension [Re: cpetroff] #4771374
05/29/18 04:36 PM
05/29/18 04:36 PM
San Antonio, TX
Nyogtha Offline
Nyogtha  Offline
San Antonio, TX
Probably not on basics of surface tension is a function of cohesion while maintaining contact with a different surface is a function of adhesion, but perhaps someone like SOJ can chime in on the specific properties of tackifiers.
"No matter how paranoid you are you're not paranoid enough. Tell the truth. Reach as many people as you can with it. That's your weapon." - Susanne Modeski, aka "Holly" to The Lone Gunmen
Re: Oil surface tension [Re: kschachn] #4771377
05/29/18 04:40 PM
05/29/18 04:40 PM
San Antonio, TX
Nyogtha Offline
Nyogtha  Offline
San Antonio, TX
I think degree of curvature of a meniscus indicates something on a relative qualitative basis for surface tension without specific quantification IIRC.
Re: Oil surface tension [Re: MotoTribologist] #4771397
05/29/18 05:06 PM
05/29/18 05:06 PM
Upper Midwest
kschachn Offline
kschachn  Offline
Upper Midwest
If that is the case then it would bead up and become less prone to adhesion.
1994 BMW 530i, 242K
Re: Oil surface tension [Re: Nyogtha] #4771399
05/29/18 05:07 PM
05/29/18 05:07 PM
Upper Midwest
kschachn Offline
kschachn  Offline
Upper Midwest
https://www.scientificamerican.com/article/measure-surface-tension-with-a-penny/
1994 BMW 530i, 242K
Re: Oil surface tension [Re: kschachn] #4771402
05/29/18 05:10 PM
05/29/18 05:10 PM
NJ, USA
NJ, USA
It depends on the type of tackifier. Those that improve cohesive properties will increase surface tension. Those that improve adhesive properties, should either have no effect or decrease the surface tension.
I suppose "polymer" would have been better than "tackifier" since tackifiers are typically referred to as adhesion-increasing additives.
Re: Oil surface tension [Re: cpetroff] #4771725
05/29/18 09:46 PM
05/29/18 09:46 PM
Hammehead Offline
Hammehead  Offline
You can compare surface tension between oils, by droppin it in water at 25C and see the one that beads up faster and remains most floating is the winner.
ToYota Corolla XEI 2010 1zzfe
Kawasaki Ninja ZX9R B4
Taurus GL Vulcan
Citroen C5 phase I
I used to use syn, now whatever is on sale and never had problems. This noob knows stuff.
Re: Oil surface tension [Re: kschachn] #4771924
05/30/18 06:36 AM
05/30/18 06:36 AM
San Antonio, TX
Nyogtha Offline
Nyogtha  Offline
San Antonio, TX
https://en.m.wikipedia.org/wiki/Meniscus_(liquid)
Re: Oil surface tension [Re: Hammehead] #4771948
05/30/18 07:21 AM
05/30/18 07:21 AM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
Yeh, right.
And you'll be quoting "bead-up-speed" and "floatingness" to how many decimal places of what?
I've seen behaviour of an oil droplet suggested as a measure of oil degradation, and tried to read up on it quite a while ago. IIRC the idea is that polar compounds are formed during degredation which lower the surface tension via their greater affinity with water. IIRC again
(a) It doesn't work very well with modernish oils because they can contain polar molecules when fresh.
(b) Quantifying it by measuring surface tension is the mother of all metric nightmares.
(c) Surface tension measurements form the basis of no operational industrial oil quality tests, at all.
But maybe I missed something, or there's been a breakthrough.
Re: Oil surface tension [Re: cpetroff] #4772264
05/30/18 12:13 PM
05/30/18 12:13 PM
Massachusetts, USA
cpetroff Offline OP
cpetroff  Offline OP
Massachusetts, USA
Appreciate all the help.
Page 1 of 3 1 2 3
