Barkeepers Friend
by jerseyguy123. 01/22/19 02:23 AM
Bag-in-a-box motor oils
by jtr990. 01/22/19 02:10 AM
Inventions of the 1950's - 1970's
by StevieC. 01/21/19 10:26 PM
Fireplace cleaners and price
by 97prizm. 01/21/19 10:23 PM
M1 0w40 extended oci??
by Pinoak. 01/21/19 09:46 PM
Best propane fireplace insert?
by SOHCman. 01/21/19 08:51 PM
Save 1/4 on gas!! Guaranteed!!
by Linctex. 01/21/19 08:50 PM
Funny names
by Chris142. 01/21/19 08:45 PM
Kendall vs Total Qaurtz
by zeke1985. 01/21/19 08:32 PM
Got a weird one - Helping a friend
by StevieC. 01/21/19 08:32 PM
Thanks 14Accent
by clinebarger. 01/21/19 08:07 PM
Mobil 1 5W30 C7 Z06
by PLRX. 01/21/19 07:40 PM
How cold is it? (Humor)
by StevieC. 01/21/19 07:13 PM
Slight performance decrease
by A_User55555. 01/21/19 06:54 PM
how to keep your vehicle battery...
by Char Baby. 01/21/19 06:31 PM
2012 to 2016 ford focus
by WhyMe. 01/21/19 06:30 PM
LHM anyone?
by mistersooty. 01/21/19 06:30 PM
Walmart Oil Changes.
by Bill7. 01/21/19 06:10 PM
Coolbreez1973, jmcast1127, DF8005, FT86dude11, RTSAllison
67008 Registered Users
33 registered members (Char Baby, berniedd, alcyon, billt460, BlakeB, citationxeleven, 5 invisible), 868 guests, and 37 spiders.
Topics296,961
Posts4,962,404
Members67,008
Most Online2,821
Jan 21st, 2019
Is there a slight bump up in MPG as oil shears? #4771001
05/29/18 08:34 AM
05/29/18 08:34 AM
Mississippi
Speak2Mountain Offline OP
Mississippi
or are there other factors in play?
Re: Is there a slight bump up in MPG as oil shears? [Re: Speak2Mountain] #4771007
05/29/18 08:40 AM
05/29/18 08:40 AM
Upper Midwest
kschachn Offline
kschachn  Offline
Upper Midwest
When does oil shear?
1994 BMW 530i, 241K
1996 Honda Accord, 267K
1999 Toyota Sienna, 409K
2000 Toyota ECHO, 280K
Re: Is there a slight bump up in MPG as oil shears? [Re: Speak2Mountain] #4771021
05/29/18 08:58 AM
05/29/18 08:58 AM
Indiana
dlundblad Offline
dlundblad  Offline
Indiana
Theoretically yes.
Is it measurable though?
03 Jeep WJ 4.0 202k Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 186k M1 0w40 Mahle OX149D
97 Chevy Blazer 4.3 153k Synpower 5w30 Supertech ST3980 (Ecore)
Re: Is there a slight bump up in MPG as oil shears? [Re: kschachn] #4771022
05/29/18 08:59 AM
05/29/18 08:59 AM
Indiana
dlundblad Offline
dlundblad  Offline
Indiana
Check out UOA's from EB engines. They'll shear oil from a 5w30 to a 5w20. It's the whole reason Ford back spec'd most of them to 5w30.
Re: Is there a slight bump up in MPG as oil shears? [Re: kschachn] #4771024
05/29/18 09:00 AM
05/29/18 09:00 AM
Canyon County Idaho
CT8 Offline
CT8  Offline
Canyon County Idaho
Oil [mulit visc oils] shears between the moving parts as the engine is running
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: Is there a slight bump up in MPG as oil shears? [Re: Speak2Mountain] #4771029
05/29/18 09:02 AM
05/29/18 09:02 AM
Where the wind comes sweepin'
Reddy45 Offline
Reddy45  Offline
This came up during a recent discussion.
Oil can shear slightly with use, but as the more volatile components of oil evaporate with use, it has a thickening effect.
So the net effect is more or less 0.
Re: Is there a slight bump up in MPG as oil shears? [Re: Reddy45] #4771035
05/29/18 09:09 AM
05/29/18 09:09 AM
Indiana
dlundblad Offline
dlundblad  Offline
Indiana
I didnt think of thickening.
Re: Is there a slight bump up in MPG as oil shears? [Re: Speak2Mountain] #4771159
05/29/18 11:27 AM
05/29/18 11:27 AM
pa
benjy Offline
benjy  Offline
pa
another reason to use better oils + real synthetic groups IV + V are the BEST. less shear + less viscosity improvers that get used up + thicken oils!!
Re: Is there a slight bump up in MPG as oil shears? [Re: benjy] #4771170
05/29/18 11:44 AM
05/29/18 11:44 AM
Upper Midwest
kschachn Offline
kschachn  Offline
Upper Midwest
An often made statement, but as far as I've seen without merit. SonofJoe has repeatedly stated that modern viscosity improvers are very stable and are highly resistant to shear degradation. Also, how would you even know if the typical Blackstone analysis that shows viscosity loss is due to shear or fuel dilution?
1994 BMW 530i, 241K
Re: Is there a slight bump up in MPG as oil shears? [Re: Reddy45] #4771370
05/29/18 03:27 PM
05/29/18 03:27 PM
SACRAMENTO, CA
rrounds Offline
rrounds  Offline
SACRAMENTO, CA
There are 100's of UOA's on here alone that show oil sheared out of grade(little or no fuel in oil) and on the motorcycle section you will find most bikes with a shared transmission get oil thats sheared out of grade in 4000 miles or less. Sometimes a lot less miles, my old R6 would only get 2500 miles on its oil before it would shear and make shifting real notchy.
ROD
'06 S2000
'00 SSEi sold at 252k miles
'08 Ford F53 V10
'13 Jeep Sahara 2 door
Re: Is there a slight bump up in MPG as oil shears? [Re: Speak2Mountain] #4771439
05/29/18 04:49 PM
05/29/18 04:49 PM
PNW
ZeeOSix Offline
ZeeOSix  Offline
PNW
I keep track of my oil level carefully, and always see the consumption starts low, then starts to increase after about 300~400 miles are put on the oil. All I can think is that oil is shearing down some which increases the oil consumption enough to see it.
As oil shears w/miles; shouldn't MPG bump up #4781165
06/08/18 09:52 AM
06/08/18 09:52 AM
Mississippi
Mississippi
slightly bc of it being thinner
Re: As oil shears w/miles; shouldn't MPG bump up [Re: Speak2Mountain] #4781170
06/08/18 09:58 AM
06/08/18 09:58 AM
Upper Midwest
kschachn Offline
kschachn  Offline
Upper Midwest
Didn't get the answer you wanted the last time or??
https://www.bobistheoilguy.com/forums/ub...n_M#Post4771001
1994 BMW 530i, 241K
Re: As oil shears w/miles; shouldn't MPG bump up [Re: Speak2Mountain] #4781172
06/08/18 09:59 AM
06/08/18 09:59 AM
PimTac Offline
PimTac  Offline
I thought this had been asked before, didn’t know it was the same poster.
Cannot see signatures any longer so it doesn’t matter.
Re: As oil shears w/miles; shouldn't MPG bump up [Re: PimTac] #4781178
06/08/18 10:05 AM
06/08/18 10:05 AM
Upper Midwest
kschachn Offline
kschachn  Offline
Upper Midwest
And only a little over a week ago.
1994 BMW 530i, 241K
