Cost was covered in the other linked thread, but in quantity about $8.00 each, the larger filter is slightly less.
Originally Posted By: DuckRyder
Originally Posted By: goodtimes
There is pleat gap on the ends, filled with glue?
More investigation is warranted, I think there is more going on there than immediately meets the eye.
On cursory inspection the ends appear open but they are in fact closed, they cannot be penetrated past a line that roughly coincides with the adhesive line visible at the ends of the media, I can only assume the adhesive is sealing the pleats. Adhesive is also visible at the partial endcaps between the pleats though I cannot get a picture to show it.
Originally Posted By: PimTac
I wonder if this same plant is making the value line filters for Mazda? I’m guessing yes.
Are those filters marked Roki or Filtech?
There is a thread here on those:
https://bobistheoilguy.com/forums/ubbthreads.php/topics/4352002/Mazda_PE01-14-302A-MV_used_cut
Doesn’t look like this at all.
