Moving mobility scooters
by supton. 01/17/19 08:59 AM
Car stumbling in idle
by dan765. 01/17/19 08:58 AM
Fiat 9.55535-GS1 Certification - Ravenol
by RamFan. 01/17/19 08:35 AM
EV Future
by Danno. 01/17/19 08:11 AM
Sayings that people told you...
by Char Baby. 01/17/19 08:04 AM
Certified oils
by waltywalt. 01/17/19 07:55 AM
Favorite Movie Lines And Scenes
by billt460. 01/17/19 07:14 AM
Suzuki Jimny
by ridgerunner. 01/17/19 06:52 AM
Amsoil SSO 5w50
by Vspec. 01/17/19 06:36 AM
Dodge truck question - gear shift
by gfh77665. 01/17/19 06:22 AM
GAC may be coming to America?
by Char Baby. 01/17/19 06:03 AM
Another favorite video
by Char Baby. 01/17/19 04:59 AM
Detail a 2012 Kia Soul
by jerseyguy123. 01/17/19 02:23 AM
Can top end cleaners damage engine?
by avacado11. 01/17/19 01:40 AM
Where are Fram Oil and Air filters made ?
by rubberchicken. 01/17/19 12:42 AM
Based on these specs, which oil is better?
by SlavaB. 01/17/19 12:42 AM
Fram FPS9688 from ebay (Ultra XG9688)
by SlavaB. 01/16/19 11:12 PM
Pick my filter—
by lukejo. 01/16/19 10:41 PM
2007 Camry V6 feedback......
by kenwin30. 01/16/19 10:41 PM
Pioneer SW-8MK2 Subwoofer
by webfors. 01/16/19 10:39 PM
neiltt, Drspel, wwalrus, fedorqwe, Terand_1
66957 Registered Users
108 registered members (Ag76, beanoil, 97f150, AandPDan, andyd, Alfred_B, 8 invisible), 1,883 guests, and 51 spiders.
Topics296,712
Posts4,957,393
Members66,957
Most Online2,577
Jan 14th, 2019
kobalt tire inflators? Lowes #4769451
05/27/18 11:57 AM
05/27/18 11:57 AM
Coastal South Carolina
edwardh1 Offline OP
edwardh1  Offline OP
they are 12 and 120 volt combo
has anyone used them?
I can not find a report, or even what the warranty is.
the Lowes salesman in between telling me stories about where he used to work, did not know if it was a "good product" and did not know the warranty
These products are all new every year?? They are a revolution!!! Razor blades, mens shirts, TVs, wiper blades, gutter guards, hearing aids... according to the ads. But also all new last year
Re: kobalt tire inflators? Lowes [Re: edwardh1] #4769454
05/27/18 12:03 PM
05/27/18 12:03 PM
USA
NHGUY Offline
NHGUY  Offline
USA
I like the M12 Milwaukee inflator.You punch in the desired target psi and it stops when it meets it.Not 120V though...
Re: kobalt tire inflators? Lowes [Re: edwardh1] #4769457
05/27/18 12:07 PM
05/27/18 12:07 PM
Outer Banks, NC
NormanBuntz Offline
NormanBuntz  Offline
Outer Banks, NC
I have two of the Kobalt tire inflators. They work fine on average size tires, but they struggle if you have to air up truck tires or large SUV tires. That's when the motors get hot and the inflation rate slows down. I say it's plenty good for homeowner use.
2017 Honda Odyssey SE, 17K
2013 Honda Accord LX, 58K
2007 Honda Ridgeline RTS, 89K
2007 Infiniti M35, 107K
Re: kobalt tire inflators? Lowes [Re: edwardh1] #4769472
05/27/18 12:38 PM
05/27/18 12:38 PM
New York
NoNameJoe Offline
NoNameJoe  Offline
New York
I have that tire inflator in their previous design (before they turned it into the X shape): https://www.lowes.com/pd/Kobalt-12-Volt-Car-Air-Inflator/3522750
I've had it for years and use it often to do multiple tires on multiple cars. Never had an issue and still going strong to this day. I specifically chose it because it supported both 12V and 120V. It is still one of the best purchases I have ever made. I've used it both hooked up to 120V by heavy gauge extension cord and through 12V at the accessory socket. Also used it to fill up spare tires annually up to 65-70PSI.
Compared against my other pressure gauges (both digital and dial) the onboard gauge on the compressor is also accurate at least for the one I got, which is important because that's what it uses to stop automatically when it reaches target PSI.
You hook it up, it shows you the current PSI, use the arrows to go up to your target and then hit the play button and it fills up until it reaches target and stops.
If it ever does end up failing I'm going to buy another one. Assuming the guts are the same and they only changed the shell, I would highly recommend it. You just have to read the manual and not be stupid with it. For example it says somewhere in there, not to have it running nonstop for more than five minutes. Someone out there is going to do that, break it and then complain about how it sucks.
Yup this one also works that way.
2015 Civic LX Coupe
Re: kobalt tire inflators? Lowes [Re: edwardh1] #4769752
05/27/18 06:35 PM
05/27/18 06:35 PM
edwardh1 Offline OP
edwardh1  Offline OP
amazon says it has a high "poor" rating.
whats the warranty
Re: kobalt tire inflators? Lowes [Re: edwardh1] #4769854
05/27/18 08:40 PM
05/27/18 08:40 PM
Texas
JBinTX30 Offline
JBinTX30  Offline
Texas
The new X shaped one is much better than the older square one. It has a one year warranty.
I use it to fill up my SUV tires all the time. They seemed to have fixed the issues the older one had. (stronger and quieter compressor) and it doesnt have to be shut off every 10 mins of constant use to cool down. It also does auto detect as to what power source you plug in, so you don't have to pick it manually.
05 GMC Yukon XL SLT 5.3 CE 5w30 51042
06 Chevy Trailblazer LS 4.2 PP 5w30 XG9837
Re: kobalt tire inflators? Lowes [Re: edwardh1] #4769970
05/28/18 04:28 AM
05/28/18 04:28 AM
Atlanta
DuckRyder Offline
DuckRyder  Offline
Atlanta
Why would they make it X shaped? Seems like an in efficient use of space.
The Lowes website says “1-Year Limited” under warranty (specifications)
Unless you really need the 120V capability perhaps look at something like Viair.
Robert
  • 2007 Toyota Prius Touring
  • 2005 Honda Civic Sedan
  • 1972 Ford F100
Re: kobalt tire inflators? Lowes [Re: edwardh1] #4771200
05/29/18 12:25 PM
05/29/18 12:25 PM
Iowa
gizzsdad Offline
gizzsdad  Offline
Iowa
I have the older version, and it works great for me. I admit to only using the 120V option.
If the newer one is an improvement, I'd be all over it.
Re: kobalt tire inflators? Lowes [Re: edwardh1] #4776907
06/04/18 06:00 AM
06/04/18 06:00 AM
NJ
JLawrence08648 Online content
JLawrence08648  Online Content
NJ
What about the Ryobi 18v the inflator?
Re: kobalt tire inflators? Lowes [Re: JLawrence08648] #4780642
06/07/18 08:07 PM
06/07/18 08:07 PM
Texas
JBinTX30 Offline
JBinTX30  Offline
Texas
I assume you mean the bigger one. And it is pretty decent. Wont inflate as fast as a 120V one but still not too bad.
