Well, the couple cups of coolant per month leak turned into a puddle the last couple of days. Took it in for mechanic to check out after I looked under and saw coolant leaking near timing belt cover. They figure water pump, which was my initial thought. They replaced it 3 years and 40k miles ago. One of those NAPA service shops. Since when do water pumps die after 40k miles? My old Honda had 200k+ on original pump. Same with a Pathfinder I owned before that. I'm assuming those NAPA shops use NAPA parts. They warranty for 3 years 36k at this shop. [censored] parts. This is why I tend to go OEM when I can. This isn't my car but a friends and after the next warranty she probably won't have it because it'll have over 200k.
