The last Oil Report showed copper @ 4 ppm. It was 2 on the last report. This oil change was at 6,551 miles. 34,383 total miles on 2013 Fiesta hatchback. Not too worried. Where could the copper be coming from? I changed oil at 6,551 miles instead of the recommended 8000 miles as I was going on a 5000 mile road trip. Also because it was almost a year since the last oil change. I read that it is not good to use oil that has been stored in the cold. We had a long cold winter here in Central TX. Many nights in the 20's and a few in the low teens. The car was not driven for several days at a time in those conditions. How does that compare with oil stored at low temperatures? The dipstick shows 1/2 quart low after those 5000 miles. I have never seen it go low between oil changes at all before. I did a lot of 75, 85, 95 mph driving. Also crossed many mountain ranges and the continental divide several times at elevations up to 11,000 feet. Lots of running the engine at 5000 rpm in lower gears getting over the mountains. I figure that's where the oil went. 5 speed manual.
