Moving mobility scooters
by supton. 01/17/19 08:59 AM
Car stumbling in idle
by dan765. 01/17/19 08:58 AM
Fiat 9.55535-GS1 Certification - Ravenol
by RamFan. 01/17/19 08:35 AM
EV Future
by Danno. 01/17/19 08:11 AM
Sayings that people told you...
by Char Baby. 01/17/19 08:04 AM
Certified oils
by waltywalt. 01/17/19 07:55 AM
Favorite Movie Lines And Scenes
by billt460. 01/17/19 07:14 AM
Suzuki Jimny
by ridgerunner. 01/17/19 06:52 AM
Amsoil SSO 5w50
by Vspec. 01/17/19 06:36 AM
Dodge truck question - gear shift
by gfh77665. 01/17/19 06:22 AM
GAC may be coming to America?
by Char Baby. 01/17/19 06:03 AM
Another favorite video
by Char Baby. 01/17/19 04:59 AM
Detail a 2012 Kia Soul
by jerseyguy123. 01/17/19 02:23 AM
Can top end cleaners damage engine?
by avacado11. 01/17/19 01:40 AM
Where are Fram Oil and Air filters made ?
by rubberchicken. 01/17/19 12:42 AM
Based on these specs, which oil is better?
by SlavaB. 01/17/19 12:42 AM
Fram FPS9688 from ebay (Ultra XG9688)
by SlavaB. 01/16/19 11:12 PM
Pick my filter—
by lukejo. 01/16/19 10:41 PM
2007 Camry V6 feedback......
by kenwin30. 01/16/19 10:41 PM
Pioneer SW-8MK2 Subwoofer
by webfors. 01/16/19 10:39 PM
neiltt, Drspel, wwalrus, fedorqwe, Terand_1
66957 Registered Users
98 registered members (Bailes1992, beanoil, badtlc, Benzadmiral, bbslider001, Asterix, 10 invisible), 1,972 guests, and 48 spiders.
Topics296,712
Posts4,957,440
Members66,957
Most Online2,577
Jan 14th, 2019
air fuel ratio #4768338
05/25/18 09:11 PM
05/25/18 09:11 PM
KS
red7404 Offline OP
red7404  Offline OP
KS
What characteristic of a liquid fuel sets the A / F ratio?
Re: air fuel ratio [Re: red7404] #4768402
05/25/18 11:15 PM
05/25/18 11:15 PM
Western S.C.
CR94 Offline
CR94  Offline
Western S.C.
Air/fuel ratio is not a characteristic of the fuel. It's the ratio air mass to fuel mass in the fuel-air mixture. Stochiometric ratio for air:gasoline is about 15:1.
2011 Toyota Prius now at 95K
Re: air fuel ratio [Re: red7404] #4768561
05/26/18 07:58 AM
05/26/18 07:58 AM
Hammehead Offline
Hammehead  Offline
Stochiometric ratio is a result of the calorific power of the fuel. The higher the cp, less fuel is used in the stoichiometry of its mix.
ToYota Corolla XEI 2010 1zzfe
Kawasaki Ninja ZX9R B4
Taurus GL Vulcan
Citroen C5 phase I
I used to use syn, now whatever is on sale and never had problems. This noob knows stuff.
Re: air fuel ratio [Re: red7404] #4768573
05/26/18 08:22 AM
05/26/18 08:22 AM
NH
supton Online content
supton  Online Content
NH
Not a chemist but what the heck, I'll play one for now.
Most fuels are composed of hydrogen and carbon. In order to fully release all the energy stored in the fuel, there is an ideal amount of oxygen required for the chemical reaction. Too little air and it doesn't fully react. Too much, seems hard to occur but it certainly does inside of an internal combustion engine (due to the small window of time for it to do "useful" work and the need for the flame to go from combustible molecule to another one). Ultimately you get carbon dioxide and water--and heat which is what is usually we are after--and to do that there is a proper amount of oxygen (from the ambient air) required.
Now I realize fuels can be other than hydrogen and carbon based, and often there is stuff in the fuel which also requires combusting (which may or may not help with releasing heat) but most stuff that we like to burn is largely hydrogen&carbon (oil, gas, wood, coal).
2011 Toyota Camry, base, 2.5L/6MT, 176k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 144k, ours
1999 Toyota Camry LE, 2.2L/4AT, 198k, his
Re: air fuel ratio [Re: red7404] #4768580
05/26/18 08:26 AM
05/26/18 08:26 AM
NJ
Leo99 Offline
Leo99  Offline
NJ
When we talk about the stoichiometric ratio, that the is the ratio of air to fuel for a "perfect" burn. For gasoline it's 14.7:1. If other fuels can burn with less oxygen, the A/F goes down. If they need more oxygen, the A/F goes us.
Without data you're just another person with an opinion. W. E. Deming
2003 Corolla 250,000 miles (RIP)
2004 Corolla 125,000 miles
2004 Rav4 370,000 miles
2015 Camry 70,000 miles
Re: air fuel ratio [Re: red7404] #4768665
05/26/18 10:20 AM
05/26/18 10:20 AM
Illinois
SHOZ Offline
SHOZ  Offline
Illinois
My A/F gauge can be programmed for whatever stoichiometric ratio you want. I use E10 all the time so I set it at 14.2. Lambda is much better to use.
2008 Hyundai Accent 1.6L 5 sp manual hatchback
2010 Hyundai Genesis Coupe Track 2L Turbo 6sp manual
Re: air fuel ratio [Re: Hammehead] #4768727
05/26/18 11:30 AM
05/26/18 11:30 AM
ME
eljefino Offline
eljefino  Offline
ME
This is a good answer.
Another is that if you examine the exhaust gases, neither oxygen nor fuel particles remain as everything was used up and converted.
If one introduces nitrous oxide, they have to run much richer fuel. But they make more power as the oxygen content of the "air" inside is higher than 21%. Some NOS systems are "wet" and include the needed fuel; others require ECM mods and bigger injectors.
The Space shuttle had to carry liquid oxygen so it could have a stoichometric burn in outer space where there was otherwise no other oxidizer available.
Ethanol for all its issues splits apart and leaves a little extra oxygen in the combustion chamber, so if you're tuned for it, even 10%, you can make more power than with pure gasoline alone.
Re: air fuel ratio [Re: red7404] #4768732
05/26/18 11:39 AM
05/26/18 11:39 AM
Texas & Global
talest Offline
talest  Offline
Texas & Global
As mentioned, for pump gas it is 14.7 to 1, or 14.7:1
This would be the ideal mix for the best, and most complete, burn in combustion per stroke.
Re: air fuel ratio [Re: talest] #4768757
05/26/18 12:14 PM
05/26/18 12:14 PM
Illinois
SHOZ Offline
SHOZ  Offline
Illinois
And the highest exhaust temps.
Re: air fuel ratio [Re: red7404] #4769057
05/26/18 08:10 PM
05/26/18 08:10 PM
Hammehead Offline
Hammehead  Offline
Yes with ethanol, the 14.7:1 doesn´t apply for ages. Only for the scarce E0. E15 may use 13.9:1 or even a tad less, hence the higher fuel consumption of these oxigenated gasolines, since you´re adding a lesser cp to the final fuel.
And thank you Eljefino
Taurus GL Vulcan
Citroen C5 phase I
Re: air fuel ratio [Re: red7404] #4773551
05/31/18 02:57 PM
05/31/18 02:57 PM
California
DGXR Offline
DGXR  Offline
California
Shell fuels provide the best air-fuel ratio :P
1995 Corvette coupe LT1 6-speed
2006 Tacoma 2.7 2wd access cab
1999 Yamaha YZ400FL
2003 Honda XR400R
Re: air fuel ratio [Re: DGXR] #4776956
06/04/18 07:19 AM
06/04/18 07:19 AM
Ocala, Florida
racin4ds Offline
racin4ds  Offline
Ocala, Florida
Let me fix that for you-
The vehicle's ECM or tune provides the best air-fuel ratio wink
Just say NO to thin oils and M1!
05 F350 Powerstroke
05 Hyundai Tucson
08 Legacy GT
Re: air fuel ratio [Re: racin4ds] #4779274
06/06/18 02:21 PM
06/06/18 02:21 PM
California
DGXR Offline
DGXR  Offline
California
Clearly. We really need to develop a sarcasm font. I thought my tongue out thingy would indicate a comment in jest.
1999 Yamaha YZ400FL
2003 Honda XR400R
