Originally Posted By: EdwardC
I think in some ways, a wired system with power over Ethernet is simpler. It depends on how many cameras and what type of cameras they want to install. If just one or two, a standalone wireless one is fine.
I have a wired Hikvision system that I like. Might not be the easiest to setup, but has been reliable. I have an NVR for for storage and remote viewing. Plus there are many more camera style and lens options that may be more suitable for their house.
^^^ THIS ^^^
1. The above is the only way to do it right. They can hire someone to do it. (Its my field of work)
The above is also best for people less tech savy, meaning they have someone come and install the system, set it up and once set up is the most reliable by far (and why they are the choice for anything commercial, stores, banks etc, also most easy to use..
Since the OP said easy to use, again, I cant stress enough this is by far the best choice, WIRED IS ALWAYS BETTER, more reliable professional and easy to use and it does not need to rely on a internet connection. Aslo as mentioned by Edward, HKvision is a very good manufacturer.
2. If they want a security system, there are wireless cameras that can be set up with the system. This is very, very, very good but not as good as number 1 for simplicity and reliability.
3. You mentioned security cameras but will chime in on Doorbell cameras. I have also installed hundreds of all three types mentioned here.
Doorbell cameras are terrific but as you know will only cover one area, if that is all someone wants they are terrific, again, if properly set up, still not as good as number 1 for ease of operation and long term reliability.
Bottom line, numbers 2 & 3 are mostly consumer items, they are good but long term reliability and ease of going back in time viewing video is not the best. They also rely heavy on the customers Internet connection, it must be fast and reliable and will not work without one. Also all one has to do is cut the Internet connection and there will be no video at all and no recording at all.
Choice #1 will work without having an internet connection and you can view video on a home monitor. The only time you would need internet is if you want to view the video remotely, like on a cell phone or tablet.
