The common brands like Liquid wrench, 3-in-1, CRC, ETC almost always contain too much solvent to really be good lubricants; regardless of what other additives they have in them.
If you really want a good teflon fortified lubricant, try super lube. It comes in oil, grease and aerosol. Tri-flow is pretty good too but the flash point is low so it doesn't do well on things that get hot.
All this being said, there are much better lubricants out there that don't rely on teflon. I am not saying teflon is bad but there are plenty of other powerful lubricants that don't use it.
