belt squeaking suddenly
by dogememe - 02/24/20 11:45 PM
Is Mobil 1 advanced synthetic a full synthetic?
by apollo18 - 02/24/20 11:08 PM
what stocks to buy?
by daves66nova - 02/24/20 08:55 PM
I thought Windows 7 would be insecure now?
by atikovi - 02/24/20 08:48 PM
When to replace struts
by ram_man - 02/24/20 08:40 PM
Fluid Film + Cayenne Pepper
by pitzel - 02/24/20 05:22 PM
Ford Focus RS Oil Advice!
by fastsvo - 02/24/20 04:23 PM
Cleanest wheels on same axle or same side of car?
by atikovi - 02/24/20 04:13 PM
Mixing 2 stroke oils
by Hirev - 02/24/20 03:57 PM
Insa Turbo Ecosaver Plus
by faramir9 - 02/24/20 03:45 PM
Repair Rusted Rocker Panels Without Welding
by Fitz98 - 02/24/20 03:33 PM
Stalwart tools
by P10crew - 02/24/20 03:32 PM
VOA Eneos Racing Street 0w-50
by zip15 - 02/24/20 03:09 PM
What is your favorite Candy Bar?
by ZZman - 02/24/20 02:27 PM
Help me understand
by 1978elcamino - 02/24/20 02:25 PM
2019 VW Passat Trip Mileage
by Boomer - 02/24/20 01:13 PM
Changed my ATF, difference is crazy!
by cwilliamsws6 - 02/24/20 12:36 PM
Specs on Conventional Oils 4 Comparing
by Perseus - 02/24/20 12:32 PM
EarlT500, Newbie111, Boris_Be, NHR, zip15
70798 Registered Users
27 registered members (4WD, aleneros, carviewsonic, Bogdon, Bailes1992, CATERHAM, 2 invisible), 1,293 guests, and 29 spiders.
Topics301,894
Posts5,204,858
Members70,798
Page 2 of 4 1 2 3 4
Re: Alternate 4Runner Oil [Re: 28gauge] #4764467 05/21/18 10:33 PM
1
1JZ_E46 Offline
1
Maybe buy a six pack of Mobil 1 15W-50 and add a bottle of it with each oil change? Manufacturer will have no idea, but certainly not the best approach. How big is the sump?
2019 Tesla Model 3 SR+
2016 Countryman S: Castrol 0W-40
Re: Alternate 4Runner Oil [Re: JeffKeryk] #4764469 05/21/18 10:34 PM
1
1JZ_E46 Offline
1
Originally Posted By: JeffKeryk
I like 0w stuff. 5w stuff ain't that much different; flows a little less when cold.
My guess is, 5w30 use will result in slightly worse gas mileage.
Other than that... Nada.
5W and 0W have very little difference in actual cranking and pumping rates until you get REALLY cold.
Re: Alternate 4Runner Oil [Re: Snagglefoot] #4764476 05/21/18 10:49 PM
Bryanccfshr Offline
Originally Posted By: Snagglefoot
Puerto Rico is well known as a center of engineering excellence so you should be doing what they do. It's a good thing they discuss the use of motor oil at extremely low temperatures in Puerto Rico because it may be so cold your engine might not start. Thank goodness Toyota has addressed this.
The nuance is easy to read here. The oil temperature chart for Puerto Rico is the unregulated () recommendations. This is how the engineers were able to communicate what they recomended around CAFE language requirements. It is a gift.
Another tell is to go to the Castrol Australia oil selector and see what is Recomended in other markets for the same engines. The engines are built to the same specifications worldwide. http://www.datateck.com.au/lube/castr_au/
We should not confuse regulatory driven language with engineering best practices. They are not to the same purpose.
Toyota designed the GR engine to run on ILSAC multi Grade oil. (5w30 on initial design)It will tolerate up to 15w40 and down to 0w20. It will also run well on Acea a3 selections as they fall within the heavy , fast, hard and hot running range of selections that are preferable in tougher climates.
2018 Trd Pro 4Runner
2018 Tacoma off-road
Dealer 0w20 to M1 0w40 FS -it depends
Re: Alternate 4Runner Oil [Re: 28gauge] #4764494 05/21/18 11:36 PM
N
nap Offline
N
I wish Honda would be similarly helpful.
In the end they have to please me too not only EPA. As the checkbook is in my pocket, EPA doesn’t buy Accords.
Re: Alternate 4Runner Oil [Re: Snagglefoot] #4764520 05/22/18 01:56 AM
J
jj51702 Offline
J
Lol finally someone with some humor and common sense
Lol at the guy trying to break the Toyota oil "code, that bypasses cafe requirements. Tin foil hat mode engaged. They have sent u the message brotato, u must feel blessed
Re: Alternate 4Runner Oil [Re: 28gauge] #4764550 05/22/18 03:30 AM
dlundblad Online Happy
Online Happy
Originally Posted By: 28gauge
Have a 2017 4Runner. Manual recommends 0W20. I live in Tucson, AZ and would like to run a higher viscosity, like a 5W30 syn. Manual leaves no room for alternates under different conditions except, for Puerto Rico only. Higher viscosities OK. A little confused? Is the Puerto Rico engine of a different specification or is it just gas mileage/environmental? Any opinions on a higher viscosity causing potential harm?
Toyota must have changed the verbiage.
My Mom has a 2015 TRD Pro and the manual states 0w20 under normal conditions. A 5w20 can be used if 0w20 isn't available, but 0w20 must be used for the next oil change. If the vehicle is used for towing, you can go up a weight. (Be it 0w30 or 5w30.. who knows what they meant.)
I am finishing up a small 0w20 stash then I plan on running a 5w30 synthetic. 10k OCI's.
03 Jeep WJ 4.0 202k Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 195k M1 0w40 Mahle OX149D
97 Chvy Blazer 4.3 158k M1 EP 10w30 Supertech ST3980
Re: Alternate 4Runner Oil [Re: cpayne5] #4764552 05/22/18 03:32 AM
Online Happy
Originally Posted By: cpayne5
Originally Posted By: jj51702
Yeah don't listen to the engineers that designed the motor...you obviously know better than them right?
Get out of here with that baloney. Have you read the owner's manual? Didn't think so.
I also have a 2017 4Runner. Toyota's requirements with regards to oil viscosity is not specific (recommends vs requires) and gives plenty of leeway to where you can run just about anything you find on the shelf at WalMart.
Mine will be getting 5w30 (coming up on its first oil change this week, actually), as that's what I have on my shelf. My 2005 (purchased new) has the same engine and has run flawlessly for 136k miles on Xw30s and 40s.
Here are the pertinent sections of the OM:
I should have fully read the thread prior to posting.
Re: Alternate 4Runner Oil [Re: 28gauge] #4764554 05/22/18 03:36 AM
wemay Offline
When i owned my 2017 Corolla and asked the service mgr about this language he said "sure, you can go with higher viscosity, but by doing so you are saying that you're vehicle is being used under extreme conditions and you now fall under severe service intervals for all maintenance items". Good luck, i think the 4Runner will be fine with a variety of viscosity, including 0W-20.
19 VW Passat Wolfsburg TSI (VW Genuine 0W-20+OEM)
13 Hyundai Santa Fe Sport 2.0T (Shell RGT 5W-30+OEM)
Re: Alternate 4Runner Oil [Re: wemay] #4764556 05/22/18 03:45 AM
Online Happy
Was this Toyota talking or was he just sharing his opinion?
Re: Alternate 4Runner Oil [Re: dlundblad] #4764558 05/22/18 03:50 AM
wemay Offline
Not sure, but i understood his logic. Nor did i want or need the hassle.
Re: Alternate 4Runner Oil [Re: wemay] #4764562 05/22/18 04:06 AM
Online Happy
I agree. That is some major hair splitting though.. Point being, I am sure a different dealer or service adviser would have given you different results though..
Re: Alternate 4Runner Oil [Re: 28gauge] #4764563 05/22/18 04:06 AM
Shannow Online Content
Online Content
Was talking out his freckle...there's a difference between higher speeds/temperatures and dusty/offroad.
Re: Alternate 4Runner Oil [Re: 28gauge] #4764569 05/22/18 04:29 AM
A
alarmguy Offline
A
For me personally, I would use 5/30 in a heartbeat, I would ditch the 20 right away. I did years ago on my wifes Mazda Skyactive engine.
Same deal with Mazda 0/20 or 5/20 (I forgot which) in the USA but everywhere else in the world 5/30. Its all about the EPA.
and to make matters worse you live in a much warmer climate then northern states (as I do) so I wouldnt give it another thought. Do it.
14 Road King (current)
08 VStar 1300 Tourer
07 Suzuki C50
Re: Alternate 4Runner Oil [Re: cpayne5] #4764599 05/22/18 05:55 AM
2
28gauge Offline OP
2
Yes I read the manual. While the example with 0W20 oil states higher or lower viscosity might be used under different conditions, they make a point of stating should you use 5W20 due to lack of availability of 0W20, you should switch right back to the 0W20.
Re: Alternate 4Runner Oil [Re: Bryanccfshr] #4764601 05/22/18 06:00 AM
K
klt1986 Offline
K
Thanks for that link as it shows that in Australia a 5w-30 is recommended for the Lexus LX570 with the 5.7 liter engine (3UR-FE). Now, I do not own a LX570 but I do own a Tundra with the same 5.7L (3UR-FE) engine. My OM throws the same verbiage out that a higher viscosity may be better suited at higher speeds or extreme loads. I don't really have a problem with the 0w20 but IMO, a 5w30 *may* offer me a little more protection?
Page 2 of 4 1 2 3 4
