belt squeaking suddenly
by dogememe - 02/24/20 11:45 PM
Is Mobil 1 advanced synthetic a full synthetic?
by apollo18 - 02/24/20 11:08 PM
what stocks to buy?
by daves66nova - 02/24/20 08:55 PM
I thought Windows 7 would be insecure now?
by atikovi - 02/24/20 08:48 PM
When to replace struts
by ram_man - 02/24/20 08:40 PM
Fluid Film + Cayenne Pepper
by pitzel - 02/24/20 05:22 PM
Ford Focus RS Oil Advice!
by fastsvo - 02/24/20 04:23 PM
Cleanest wheels on same axle or same side of car?
by atikovi - 02/24/20 04:13 PM
Mixing 2 stroke oils
by Hirev - 02/24/20 03:57 PM
Insa Turbo Ecosaver Plus
by faramir9 - 02/24/20 03:45 PM
Repair Rusted Rocker Panels Without Welding
by Fitz98 - 02/24/20 03:33 PM
Stalwart tools
by P10crew - 02/24/20 03:32 PM
VOA Eneos Racing Street 0w-50
by zip15 - 02/24/20 03:09 PM
What is your favorite Candy Bar?
by ZZman - 02/24/20 02:27 PM
Help me understand
by 1978elcamino - 02/24/20 02:25 PM
2019 VW Passat Trip Mileage
by Boomer - 02/24/20 01:13 PM
Changed my ATF, difference is crazy!
by cwilliamsws6 - 02/24/20 12:36 PM
Specs on Conventional Oils 4 Comparing
by Perseus - 02/24/20 12:32 PM
EarlT500, Newbie111, Boris_Be, NHR, zip15
70798 Registered Users
27 registered members (AnthemBassMan, DeafBrad, CATERHAM, Ctopher, Donald1953, Danimal1q2w3), 1,261 guests, and 16 spiders.
Topics301,894
Posts5,204,869
Members70,798
EcoGard X1A Cut Open 6000Km glue failure #4763529 05/20/18 09:55 PM
R
Run Offline OP
R
This was in service over the winter months and seen a bunch of short trips. Vehicle it came off from was a 2002 grand caravan. This is the first filter I cut open and discovered problems that would allow unfiltered oil to pass through. Once I cut the can open I reach in to pull the media out and off comes the endcaps. The large crack in the glue came from the base end of the canister. I always cut mine from the dome. So it was not damaged by me during the cut. I will not use these filters again.
02 Escape
Re: EcoGard X1A Cut Open 6000Km glue failure [Re: Run] #4763537 05/20/18 10:23 PM
PimTac Offline
It fractured right in line with the pleat clamp. Was the filter installed way to tight?
2017 Mazda CX5
Valvoline Advanced Synthetic 0w20
Roki OEM filter.
Re: EcoGard X1A Cut Open 6000Km glue failure [Re: PimTac] #4763547 05/20/18 11:12 PM
R
Run Offline OP
R
I remember installing it just right. I was able to remove it with my bare hands.
02 Escape
Re: EcoGard X1A Cut Open 6000Km glue failure [Re: Run] #4763613 05/21/18 04:56 AM
Zee09 Offline
Thanks for the cp!
"If I walked on water, they'd say I couldn't swim."
Re: EcoGard X1A Cut Open 6000Km glue failure [Re: Run] #4763702 05/21/18 07:42 AM
N
NormanBuntz Offline
N
Thanks for posting. What did you use to open the can, an M-80?
Porgy Tirebiter: "Heavy on the 30 weight, Mom."
2017 Toyota Camry XLE, 12K, 2nd owner
2007 Honda Ridgeline RTS, 96K, original owner
2007 Infiniti M35, 115K, original owner
Re: EcoGard X1A Cut Open 6000Km glue failure [Re: Run] #4763711 05/21/18 07:53 AM
G
goodtimes Offline
G
The whole potting media in glue to make the seal is a pretty primitive process. I don't blame you for not wanting to use them again. I have the same feelings about Fram TG, EG, Baldwin, and a couple others. Based on this I wouldn't use the Eco's either.
What is that, missing glue on one picture? Even worse than oil bypassing is loose glue IMO.
Re: EcoGard X1A Cut Open 6000Km glue failure [Re: Run] #4763896 05/21/18 11:40 AM
SirTanon Offline
Even with the glue being cracked like that, it is likely that the end caps still insured a good seal at the end of the media.
2013 Nissan Altima SV - 2.5 liter/CVT - 125,000mi
2014 Nissan Altima SL - 2.5 liter/CVT - 68,000mi
2010 Ford Fusion - 274k mi - SOLD
Re: EcoGard X1A Cut Open 6000Km glue failure [Re: Run] #4763897 05/21/18 11:42 AM
BlueOvalFitter Offline
Did you open that filter with a fire breathing beaver? shocked
2007 F150, 4.2 V6
Havoline PRO DS 5W20, M1-209A
"One Filter, One OCI!"
"One Box, One OCI!"
Re: EcoGard X1A Cut Open 6000Km glue failure [Re: Run] #4763923 05/21/18 12:13 PM
J
jj51702 Offline
J
Did u open the filter with a pitbull on meth?
Re: EcoGard X1A Cut Open 6000Km glue failure [Re: Run] #4763957 05/21/18 12:46 PM
Z
ZeeOSix Offline
Z
I don't need no stinkin' filter cutter ... grin2
Re: EcoGard X1A Cut Open 6000Km glue failure [Re: Run] #4765470 05/22/18 08:45 PM
blupupher Offline
Well that looks ugly.
Nothing what my Ecogard looked like.
'18 Santa Fe: PP 10W-30/OEM
'18 Soul: Synpower 5W-30/PG
'10 Santa Fe: Synpower 5w-30/D+
'04 F150: Magnatec 10w-30/ST
'12 xB: M1EP 0W-20/CQ Blue
'02 F150: Magnatec 5W-20/D+
'94 VT1100: Peak 15W-40/D+
