Kirkland VS M1
by A_Spruce - 02/21/20 11:24 PM
Ryan Newman bar
by P10crew - 02/21/20 10:16 PM
Good aftermarket shocks and struts?
by Micahmcmeen - 02/21/20 09:49 PM
Oil Marketing
by Mathew_Boss - 02/21/20 09:45 PM
run to your walmart NOW!
by willow - 02/21/20 09:39 PM
When redundancy goes out the window
by Exhaustgases - 02/21/20 08:34 PM
Please help me decide....
by ecureed - 02/21/20 08:03 PM
Flywheel pic
by Chris142 - 02/21/20 07:49 PM
Rislone Hyper Fuel
by rrretiree7 - 02/21/20 07:40 PM
Bosch Brakes
by ChiTDI - 02/21/20 07:16 PM
Which 15W40 for an Onan generator?
by atikovi - 02/21/20 06:39 PM
Valvoline Advanced 5W40 MST
by BurntMusic - 02/21/20 06:04 PM
2014 F250, 6.7L 13,000 OCI Amsoil AME 15w40
by claluja - 02/21/20 05:43 PM
What Are These On My Caliper Pistons?
by Fitz98 - 02/21/20 05:37 PM
Gun carry insurance
by Colt - 02/21/20 05:25 PM
drywall crack. how do i fix it?
by WhyMe - 02/21/20 02:55 PM
Yokohama AVID Ascend GT
by Bottom_Feeder - 02/21/20 02:53 PM
Getting my Chevy 4.3 to 300k
by CharlotteB - 02/21/20 02:16 PM
Updated PDS for Valvoline ME
by buster - 02/21/20 01:56 PM
Hubbs1982, AW4BYT, YOUSSEF, b3e3, Bogdon
70775 Registered Users
65 registered members (2010Civic, bbhero, Blkstanger, bluesubie, BlakeB, 2 invisible), 1,540 guests, and 19 spiders.
Topics301,767
Posts5,202,373
Members70,775
Prestone vs. Asian Antifreeze #4753850 05/11/18 06:49 AM
O
OilUzer Offline OP
O
We have a Hyundai Tuscon and based on the Owners manual, I should be able to use Prestone antifreeze.
OM says ethanol glycol based antifreeze and there is no other specific requirements ...
However the antifreeze in the car is kind of blue (if I recall correctly) and few people (including the parts dept at Hyundai) have told me not to use Prestone ... another guy at auto parts place told me i need to buy a special antifreeze for Japanese cars like zerex Asian???
I have to trust the OM (unless if it is out of date) and besides I have 3 gallons of prestone in the garage... lol
something doesn't make sense here! I haven't done a lot of research but I should be able to trust the OM. No?
Re: Prestone vs. Asian Antifreeze [Re: OilUzer] #4753864 05/11/18 07:03 AM
J
JMJNet Offline
J
IIRC, the Asian antifreeze are silicate free while the regular Prestone have silicate.
Not sure why that is important but I am sure when dealing with chemicals, there may be reaction if mixed together.
The results may be undesirable for long term.
  • 2017 Toyota Sienna
Re: Prestone vs. Asian Antifreeze [Re: OilUzer] #4753870 05/11/18 07:08 AM
L
LeakySeals Offline
L
I have a Nissan that uses blue. I use this pre mixed 50/50. Guess the jug is blue for a reason. https://www.oreillyauto.com/detail/b/zer.../861398/2496985
06 Escalade 6.0L LQ9 AWD 170k M1 5w30
03 Maxima 3.5L 170k Maxlife HM 10w30
05 Malibu Classic 2.2 111k M1 5w30
06 Altima 2.5L 167k unk
Re: Prestone vs. Asian Antifreeze [Re: OilUzer] #4753891 05/11/18 07:23 AM
Brian553 Offline
Not all Prestone is the same! If you have the Dex-cool (OAT) prestone fluid, I would take it back, because Hyundai does not use OAT.
If you bought Prestone Extended Life, then you can mix it, and it will be fine; these are both HOAT fluids (their organic acids are the same, or at least have no resulting detriment to mixing.)
Typically the Asian HOAT formulas use corrosion inhibitors that are different than european formulas.
Asian formulas use phosphates to protect against corrosion on ferrous parts and preventing cavitation.
European formulas use silicates in small concentrations, which helps protect aluminum from high temperature corrosion (and can also help slow or stop a head gasket leak if one forms).
Asian formulas can be bought at the car dealer, but their suppliers in NA are generally Zerex, owned by Valvoline.
Zerex Asian : https://www.valvoline.com/our-products/antifreeze-products/zerex-asian-vehicle-antifreeze-coolant
Valvoline Asian : https://www.walmart.com/ip/Valvoline-Asian-Vehicle-Antifreeze-Ready-To-Use-1-Gallon/49660461
[As far as I have found, these are the same products... I have no idea what Valvoline is doing.]
Personally, I wish I could get a low silicate addition to either of these, but I have come up dry. Can't say I've ever heard of it being an issue anyway.
Re: Prestone vs. Asian Antifreeze [Re: OilUzer] #4753902 05/11/18 07:33 AM
K
khittner Offline
K
If your Hyundai’s owner’s manual is like the one for my ‘10 Sonata, the coolant spec is for an “ethylene glycol base for aluminum radiator”. My Sonata’s OEM coolant was also blue. Get the Zerex Asian blue stuff, and be happy. Hand off your green Prestone to someone with an older domestic vehicle.
Re: Prestone vs. Asian Antifreeze [Re: OilUzer] #4754079 05/11/18 09:40 AM
B
BJD78 Offline
B
The OM that I have states :"ethylene glycol based coolant for aluminum radiators" I use regular Peak Long life full strength mixed 50/50 with distilled water. When I type year and model for my Sonata or Tuscon into the part search on Autozone the following brands fit: Prestone, Peak,OET, Pentefrost and the Autozone brands. The 50/50 mix seems a bit high since the full strength is only about $2 more and distilled water is so cheap, easy enough to do a 50/50 mix. Prestone would work fine as would the Zerox Asian blue , or the global types of coolant.
2010 Forester:122K
2009 Sonata :189K
OCI 5K using TSC conventional Travelers oil.
Re: Prestone vs. Asian Antifreeze [Re: OilUzer] #4754081 05/11/18 09:46 AM
O
OilUzer Offline OP
O
i guess Ethylene and not "ethanol" ... I got my chemicals mixed up smile
Btw, the Prestone i have doesn't say extended but it says verbatim:
"For ANY car"
"Works with ANY color antifreeze"
"Will NOT void warranty"
"ALL MAKES, ALL MODELS"
Better be on the safe side, I am going to get the valvoline zerex. I have seen it at WM. I have older cars that can use the prestone.
Thanks guys!
Re: Prestone vs. Asian Antifreeze [Re: OilUzer] #4754163 05/11/18 11:10 AM
E
E150GT Offline
E
I personally am going to use Pentofrost Asian because I cannot stand purchasing 50/50 mix and valvoline only offers that in their zerex asian.
1984 Mercedes-Benz 300SD - 100k
1995 F150 XL 4.9 reg cab 5MT - 251k 5w30
2016 Mazda6 Touring 6MT - 68k 5w30
2006 Buick Lucerne CXL 3.8 40k 5w30
Re: Prestone vs. Asian Antifreeze [Re: OilUzer] #4754416 05/11/18 05:13 PM
N
Nyogtha Offline
N
Recochem brand "OEM" Antifreeze is also sold in concentrate, at Pep Boys in this area, but I don't know cost comparison to Pentofrost. Recochem is a Canadian company.
http://www.oemantifreeze.com
Here's the OEM Blue concentrate, less than $15 / gallon.
https://m.pepboys.com/product/details/879925/00233
"No matter how paranoid you are you're not paranoid enough. Tell the truth. Reach as many people as you can with it. That's your weapon." - Susanne Modeski, aka "Holly" to The Lone Gunmen
Re: Prestone vs. Asian Antifreeze [Re: OilUzer] #4754493 05/11/18 06:53 PM
O
OilUzer Offline OP
O
I don't recall seeing the Asian concentrate in stores either. At least for the name brands i use.
Just curious why prestone (see my previous post) says use for all cars, models, any color ...
Is that marketing [censored]?!
Re: Prestone vs. Asian Antifreeze [Re: Brian553] #4757555 05/15/18 05:15 AM
P
pbm Offline
P
GO-5 is a H-OAT with a little silicate in it.
Also, I believe that Prestone AMAM is an OAT coolant (very similar to their Dexcool without the license).
I think any of these will work fine for the OP as long as he FLUSHES his system (with Distilled) water) until there is no trace of the original coolant...3X should do it.
If the OP is intent on using a phosphated H-OAT he should check his local Autozone for the Pentosin that's on CLEARANCE....the A2 green and the A4 blue are both compatible....the A2 is a concentrate and the A3 is a pre-mix. The A2 is original H-HOAT LL while the A3 is improved formula good for 'extended' long life. These are similar to what came in his Hyundai originally. I also wouldn't hesitate using the silicated H-OAT, GO-5, after a good flush.
'Journalism is Dead'
Re: Prestone vs. Asian Antifreeze [Re: OilUzer] #4762324 05/19/18 06:36 PM
J
jj51702 Offline
J
I don't discriminate against my antifreeze whether it's Asian or not
Re: Prestone vs. Asian Antifreeze [Re: jj51702] #4763609 05/21/18 04:49 AM
O
OilUzer Offline OP
O
That's not for you to decide!
Will your car marry the antifreeze in order to make it %100 legal? it will be for 3-5 years if compatible like most Other marriages ... grin
Btw, no one knows about the "any color, any car, any ..." claim On the container!
Re: Prestone vs. Asian Antifreeze [Re: OilUzer] #4763917 05/21/18 12:04 PM
J
jj51702 Offline
J
Haha
Re: Prestone vs. Asian Antifreeze [Re: OilUzer] #4780926 06/08/18 05:34 AM
O
OilUzer Offline OP
O
did some more research ... I have prestone cor-guard and it says "extended life" on it as well. I missed that before. It is the regular yellow container you see in most stores. It also says to use in any car/model, or with any color antifreeze ...
As @pbm and others have said here, it should be ok to use it in Hyundai. OM says use ethylene glycol based coolant for aluminum radiator and I called another Hyundai parts department and the parts person put me on hold and asked one of the mechanics at the service dept. and was told that it is ok to use the prestone.I
Regarding any car, and model, any color antifreeze claim:
So far ok for Asian cars ... and also this is from prestone website regarding Europen cars:
"Some European automobile manufacturers request that a phosphate-free antifreeze be used in their vehicles. This issue is related to the extremely high mineral content of the water in Europe. If you were to mix an antifreeze that contained phosphates with the type of water they have in Europe, it may produce deposits that can settle in the cooling system and promote corrosion. However, in North America we do not have this type of water problem. Typical North American coolants have contained phosphates (which is part of the corrosion inhibitor package) for many years. Therefore, the question of phosphates is a non-issue here in North America. Prestone® Antifreeze/Coolant is completely safe for use in both foreign and domestic vehicles. "
Anyways, do your own research but I will be using prestone cor-guard in our 2014 hyundai. We also have a 2005 hyundai (original owner) and I have always used regular prestone with no issues. I have also used the same in my Toyota Tacoma and no issues ...
Thanks everyone for your help!
