SATA Tools
by demarpaint - 01/24/20 05:10 AM
C-130
by Exhaustgases - 01/24/20 01:29 AM
Anyone Here Have a 9-Shot Rough Rider?
by ZeeOSix - 01/24/20 12:43 AM
Standard wix cartridge filter
by Bettez88 - 01/23/20 09:50 PM
Adaptive Driving Beam, Thoughts?
by Vern_in_IL - 01/23/20 09:07 PM
Chevron Delo XLE 15W-40 CK4 (semi synthetic)
by HDoilDude - 01/23/20 08:45 PM
Coronavirus
by buster - 01/23/20 08:04 PM
Used vehicle shopping
by 53' Stude - 01/23/20 08:01 PM
Carquest oil and filter deal.
by JTK - 01/23/20 07:35 PM
Anti seize vs silicone paste
by buck91 - 01/23/20 06:57 PM
UOA - 11 VW GTI 2.0T TSI - Purol 10w40 - 5k
by dubman - 01/23/20 06:33 PM
Old SG/CD Mopar Vintage oil useless?
by BBDartCA - 01/23/20 06:32 PM
Great Slave Lake
by 53' Stude - 01/23/20 04:57 PM
Went used car shopping today. So interesting
by WhyMe - 01/23/20 04:33 PM
Wix 51269 I think cut open
by Mightymouse - 01/23/20 04:08 PM
What oil for a new VW Beetle?
by widetrax - 01/23/20 03:52 PM
Lossless audio music
by Cujet - 01/23/20 03:38 PM
Castrol Edge on Rollback at Walmart
by Matt1980 - 01/23/20 03:35 PM
Regretted Selling a Car?
by RDY4WAR - 01/23/20 02:14 PM
Perseus, AJEwing, Mailman1995, DougCFL, Sayafi
70514 Registered Users
50 registered members (Bailes1992, cronk, Char Baby, bradepb, 750IX, d00df00d, 8 invisible), 2,066 guests, and 18 spiders.
Topics300,482
Posts5,176,888
Members70,514
Page 2 of 2 1 2
Re: Drain and fill of '14 Odyssey [Re: JHZR2] #4143429 07/05/16 03:45 AM
dlundblad Offline
Looks like you did good at least getting that magnet clean.
A D/F in another 10k might not be a bad idea IMO.
03 Jeep WJ 4.0 202k Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 195k M1 0w40 Mahle OX149D
97 Chvy Blazer 4.3 158k M1 EP 10w30 Supertech ST3980
Re: Drain and fill of '14 Odyssey [Re: NMBurb02] #4145012 07/06/16 09:52 PM
SavagePatch Offline
Originally Posted By: NMBurb02
I may see if there is an aftermarket magnetic drain plug.
I replaced the non-magnetic OE drain plug on our CX-9 with a DIMPLE magnetic drain plug for doing D&F's. 3.5qts out and 3.5qts in. Like JHZR2 said, it's easier than an oil change.
Re: Drain and fill of '14 Odyssey [Re: JHZR2] #4145229 07/07/16 08:25 AM
M
MetalSlug Offline
M
One thing I like about honda ( just 1 thing ), their transmission fluid change is SO simple. Drain and fill, heck I do it every years.
Re: Drain and fill of '14 Odyssey [Re: MetalSlug] #4146661 07/09/16 09:28 AM
J
JTK Offline
J
They're the only ones that I know of that include a dipstick, fill plug and drain plug (on most models). If you use the huge fill plug on the Ody AT and a long old school ATF funnel to reach it, ATF pours in faster than an engine oil change.
2019 Nissan Pathfinder SV
2017 Ram 1500 4x4, 3.6L.
2015 Nissan Versa 1.6 S
Re: Drain and fill of '14 Odyssey [Re: JHZR2] #4147746 07/10/16 05:04 PM
6starprez Offline
I've done a drain and fill every year on my Odyssey since the transmission was replaced in 2005. Looks like Honda kept that easy peasy.
'12 Subaru Impreza Sport Limited, 202K - Mobil 1 AP 0W20
Re: Drain and fill of '14 Odyssey [Re: JHZR2] #4149171 07/12/16 10:39 AM
M
mclasser Offline
M
Good on you for doing this. I did a D&F on my Pilot at around 20K to get all the break-in material out. I noticed VCM became a little smoother afterwards.
2018 Hyundai Elantra VE
2013 Honda Pilot EX-L 4WD
2002 Honda Accord EX-L
Re: Drain and fill of '14 Odyssey [Re: JHZR2] #4149982 07/13/16 11:01 AM
T
threeputtpar Offline
T
I did the same thing on our 2013 at the 5k mile mark, along with its first oil change. The results were the same as yours - paste on the drain plug but very clean and bright red fluid coming out. I also used DW-1 fluid as the replacement.
At around 30k miles, the MM indicated to do what it thought was the first D&F so I did a repeat performance. I'd assume yours will indicate the same at that mileage.
2013 Honda Odyssey Touring Elite - Havoline 5W-30 Syn / Mobil1 Filter 80k miles
2014 GMC Acadia Denali - SuperTech 5W-30 Syn / Carquest Red 22k miles (yes, that low)
Re: Drain and fill of '14 Odyssey [Re: IndyIan] #4189174 08/28/16 09:50 PM
SubieRubyRoo Offline
Originally Posted By: IndyIan
A true change is supposed to be 3 in and 3 out, 3 times with some driving in between each one, but that takes a lot of time and expensive fluid.
Actually this is an oft-repeated error. The manual actually states drain, fill, drive x3, then drain and fill again. For a total of 4 times drain and fill, around 14 quarts of fluid.
Page 341 of the 2006 Odyssey owner's manual: "To thoroughly flush the transmission,the technician should drain and refill it with Honda ATF-Z1, then drive the vehicle for a short distance. Do this
three times. Then drain and refill the transmission a final time."
It's easy to overlook after you've been under the da!n van three times prior... also don't forget changing the (non-existent according to the dealer) transmission filter on the BGRA trans!
Re: Drain and fill of '14 Odyssey [Re: JHZR2] #4578903 11/19/17 11:56 AM
J
JHZR2 Offline OP
Global Moderator
Global Moderator
J
A123 came up so did another ATF drain when changing the oil. Dumped it into the same pan as the oil, only to realize I was rushing and should have done it separately to measure.
Very windy out so stopped a little bit short because splatter was getting everywhere.
Re: Drain and fill of '14 Odyssey [Re: JHZR2] #4578922 11/19/17 12:22 PM
SatinSilver Offline
Prob good to do 15k drain and fills if the van sees mostly city miles. That's an aggressive schedule but good preventative maintenance. What about on the Accord, has that seen regular drain and fills as well?
Re: Drain and fill of '14 Odyssey [Re: SatinSilver] #4579483 11/19/17 08:37 PM
J
JHZR2 Offline OP
Global Moderator
Global Moderator
J
The 15k-ish was sort of my plan...the OLM gives us 5-6k between oil changes, so I'm inclined to change fluid on the third one in the interim and then when the minder says to. I did one at 10 and one at 30 which is ok I guess.
I bought 12 qts to do the accord as well. That thing goes so far on an oil change there's fewer opportunities. Given the result on the odyssey, and given that I'm over 30k on the accord, I'm thinking when I do the next oil change, which should be soon, I'll change the trans fluid.
I really wanted to do it at 15k but for some reason didn't.
Re: Drain and fill of '14 Odyssey [Re: JHZR2] #4763501 05/20/18 08:53 PM
J
JHZR2 Offline OP
Global Moderator
Global Moderator
J
Another one done at 32k. Still a lot of residue, but imo a marked improvement from prior times.
Fluid still beautiful red.
Re: Drain and fill of '14 Odyssey [Re: JHZR2] #4763511 05/20/18 09:15 PM
J
JAG Offline
J
Thatís good that the wear rate is dropping. It sure takes a lot of miles to break in.
Re: Drain and fill of '14 Odyssey [Re: JHZR2] #4763738 05/21/18 08:26 AM
K
KrisZ Offline
K
Since these were single drains, I think the residue you see is from the contaminants still suspended in the fluid left behind. I bet that if you did a cooler line exchange at 10k, instead of a single drain, that magnet would probably have almost nothing on it.
2015 Grand Caravan 3.6L - 35k miles.
2006 Mazda 3 2.0L - 186k miles
Re: Drain and fill of '14 Odyssey [Re: JHZR2] #4764540 05/22/18 02:54 AM
The Critic Offline
If yours is the six-speed, I highly advise getting the software update. Fluid deterioration would be reduced.
2011 Toyota Prius 1.8L - 202K - Valvoline Premium Blue Restore 10W-30
2007 Honda Accord 2.4L - 143K - Valvoline Premium Blue Restore 10W-30
Page 2 of 2 1 2
