Need Mice Advice
by Mr_Luke - 05/25/20 07:01 PM
pressure washer air compressor oil
by bedwards - 05/25/20 06:49 PM
2014 Elantra delayed shift 4th to 5th
by Propflux01 - 05/25/20 05:51 PM
2002 Ranger Electrical Weirdness (GEM, RAP?)
by DuckRyder - 05/25/20 05:47 PM
Oil change problems
by philipp10 - 05/25/20 05:41 PM
Denso 150 3024
by thrace - 05/25/20 04:58 PM
does ac delco warranty the replacement battery?
by apollo18 - 05/25/20 04:39 PM
Water drainage issue
by Paul_Siu - 05/25/20 04:39 PM
13 Corolla PCV
by AJB0009 - 05/25/20 04:24 PM
SpaceX Launch - Wednesday
by MasterSolenoid - 05/25/20 04:15 PM
Atf for my E4od
by R1jake - 05/25/20 04:04 PM
Having trouble finding the right part (VW)...
by gregk24 - 05/25/20 04:03 PM
Need a sensible but fun daily
by dparm - 05/25/20 03:52 PM
FJ cruiser knock sensors
by Chris142 - 05/25/20 03:51 PM
Rock Auto now carries Maval steering racks and pumps
by slacktide_bitog - 05/25/20 03:10 PM
Review: Cardone Reman Power Steering Pump
by RevelationLion - 05/25/20 02:09 PM
Carvana
by Bogdon - 05/25/20 02:06 PM
Mitsubishi SP-III universal fluid
by MontePrix28 - 05/25/20 12:22 PM
Typerguy, showtyme1958, rickyradit, YogiTheCat, StevePLR
71527 Registered Users
111 registered members (71Chevyguy, 2004tdigls, 2015_PSD, alchargo, 2K2AcuraTL, antone, 8 invisible), 2,467 guests, and 21 spiders.
Topics305,868
Posts5,281,753
Members71,527
Page 1 of 7 1 2 7
Merc 3.0CRD Oil advice please. #4761678 05/19/18 07:05 AM
T
Tikka Offline OP
T
Hi
I have a 2008 Grand Cherokee with the Merc OM642 Diesel unit in it. I have no DPF fitted, Jeep only fitted them on new model in UK I believe.
My oil spec is 229.51.Will I be ok using any Oil that is Merc approved to 229.51 or is it not as simple as that?
I am looking for ultimate Engine and Turbo protection rather then fuel economy.
What are the ingredients in the oil I should be looking for? Indeed are all 229.51 oils made to the same 'recipe'?
Any suggestions on viscosity range? My handbook calls for a 5w-30. The UK has a relatively moderate climate.
Forgive me if any of my questions are a little naÔve but I am just learning and am finding the subject very interesting.
Many thanks.
Tikka.
Re: Merc 3.0CRD Oil advice please. [Re: Tikka] #4761697 05/19/18 07:23 AM
Danno Offline
229.51 has been superseded by 229.52.
Yes any oil with 229.52 certifications will be fine.
Also, 5W-30 would be fine for England.
I had over a hundred OM642s non-DPF in my Sprinter fleet. As well, I recommend only using OE MB oil filters for the engine.
Friend of mine had the exact same JGC as you have. Traded it in as local Jeep dealer was clueless on how to maintain the truck.
2019 Jeep Grand Cherokee Summit 5.7L Hemi
2019 RAV4 Limited Hybrid
2016 Sorento SX V6 AWD
2010 Mazda 3 2.0L
Re: Merc 3.0CRD Oil advice please. [Re: Tikka] #4761710 05/19/18 07:37 AM
Z
zeng Offline
Z
Any MB 229.51 would do, and it's more likely to be an xW40 in my country.
Re: Merc 3.0CRD Oil advice please. [Re: Tikka] #4761724 05/19/18 07:57 AM
T
Tikka Offline OP
T
Hi Danno
Thanks for helping.
I noticed the 229.52 spec but I wonder when the specs move on for different engines whether they start removing ingredients that may be good for my older engine. Maybe I am over thinking this?
Yes I will only use genuine filters. I read the long thread about these filters on the oil filter section of the forum.
At the moment my Jeep is getting PETRONAS Syntium 5w-30 as fitted by Jeep Dealer.
Diesel Jeeps are by far the most common in UK. Petro ones are rare due to our very high taxes on fuel.
Re: Merc 3.0CRD Oil advice please. [Re: Tikka] #4761727 05/19/18 07:59 AM
T
Tikka Offline OP
T
Hi Zeng
Thanks for you help.
I am guessing you guys use a 40 weight due to your hot climate?
Re: Merc 3.0CRD Oil advice please. [Re: Tikka] #4761793 05/19/18 09:14 AM
Danno Offline
229.52 covers 229.51 spec so you're good to use it.
I know MB extended OCI with the launch of 229.52, so you shouldn't have worries.
2010 Mazda 3 2.0L
Re: Merc 3.0CRD Oil advice please. [Re: Tikka] #4761875 05/19/18 10:53 AM
1
1JZ_E46 Offline
1
I believe 229.52 is identical to 229.51, with the exception of a more stringent fuel economy test. I would stick with 229.51. More options.
2019 Tesla Model 3 SR+
2016 Countryman S: Castrol 0W-40
Re: Merc 3.0CRD Oil advice please. [Re: Tikka] #4762088 05/19/18 03:22 PM
J
JAG Offline
J
MB 229.52 is more stringent than 229.51 in areas of oxidative thickening and fuel economy, and is otherwise the same, according to Lubrizol. Mobil 1 0W-30 ESP meets MB 229.52.
https://online.lubrizol.com/relperftool/pc.html
Re: Merc 3.0CRD Oil advice please. [Re: Tikka] #4762216 05/19/18 05:59 PM
CleverUserName Online Content
Online Content
If youíre looking for the ultimate in engine and turbo protection, then a Low-Mid SAPS oil isnít the best choice. I think you probably want the additional AW additives an E7 or E9 synthetic Diesel engine oil. E7 or E9 in 5w30 or 5w40 would be the lube for you.
Re: Merc 3.0CRD Oil advice please. [Re: Tikka] #4762270 05/19/18 06:44 PM
DallasTexas Offline
I have a OM648 CDI with DPF. To protect the DPF I use MB 229.31 or MB 229.51 which is usually Mobil Delvac 1 ESP. I tend to worry more about DPF.
06 E320 CDI 121k miles
14 Sienna 42k miles
96 E300 297k miles Donated
90 Volvo 240 donated.
2001Sienna donated
Re: Merc 3.0CRD Oil advice please. [Re: DallasTexas] #4762582 05/20/18 02:53 AM
edyvw Offline
Since when Mobil1 Delvac ESP carries MB 229.31 or .51?
11' BMW 328i xDrive 6MT (Pennzoil Platinum Euro 5W40+ MANN filter)
11' VW Tiguan 2.0T (Castrol 0W30+OE filter)
15' Toyota Sienna AWD (Mobil1 5W30 EP+OE filter).
Re: Merc 3.0CRD Oil advice please. [Re: Tikka] #4762593 05/20/18 04:00 AM
Z
zeng Offline
Z
Yes, I'd access to Total Quartz Ineo MC3 5W40 MB 229.51 C3.
Re: Merc 3.0CRD Oil advice please. [Re: zeng] #4762609 05/20/18 05:12 AM
T
Tikka Offline OP
T
Not PETRONAS I see. Any particular reason as I presume it is readily available?
Re: Merc 3.0CRD Oil advice please. [Re: CleverUserName] #4762612 05/20/18 05:19 AM
T
Tikka Offline OP
T
Hi
Would a 228.51 spec suit my needs better? If I am reading things correctly 228.51 seems to be a diesel specific spec.
According to Mercedes this spec is ok on the om642 without dpf.
https://bevo.mercedes-benz.com/d/d/en/Spec_223_2.pdf
They seem to be a more Truck and commercial vehicle oil. Although still low saps.
Re: Merc 3.0CRD Oil advice please. [Re: DallasTexas] #4762614 05/20/18 05:24 AM
T
Tikka Offline OP
T
Hi
I do not have dpf so I hope I have a little more wriggle room with lube choice
Page 1 of 7 1 2 7
