Kirkland VS M1
by A_Spruce - 02/21/20 11:24 PM
Ryan Newman bar
by P10crew - 02/21/20 10:16 PM
Good aftermarket shocks and struts?
by Micahmcmeen - 02/21/20 09:49 PM
Oil Marketing
by Mathew_Boss - 02/21/20 09:45 PM
run to your walmart NOW!
by willow - 02/21/20 09:39 PM
When redundancy goes out the window
by Exhaustgases - 02/21/20 08:34 PM
Please help me decide....
by ecureed - 02/21/20 08:03 PM
Flywheel pic
by Chris142 - 02/21/20 07:49 PM
Rislone Hyper Fuel
by rrretiree7 - 02/21/20 07:40 PM
Bosch Brakes
by ChiTDI - 02/21/20 07:16 PM
Which 15W40 for an Onan generator?
by atikovi - 02/21/20 06:39 PM
Valvoline Advanced 5W40 MST
by BurntMusic - 02/21/20 06:04 PM
2014 F250, 6.7L 13,000 OCI Amsoil AME 15w40
by claluja - 02/21/20 05:43 PM
What Are These On My Caliper Pistons?
by Fitz98 - 02/21/20 05:37 PM
Gun carry insurance
by Colt - 02/21/20 05:25 PM
drywall crack. how do i fix it?
by WhyMe - 02/21/20 02:55 PM
Yokohama AVID Ascend GT
by Bottom_Feeder - 02/21/20 02:53 PM
Getting my Chevy 4.3 to 300k
by CharlotteB - 02/21/20 02:16 PM
Updated PDS for Valvoline ME
by buster - 02/21/20 01:56 PM
Hubbs1982, AW4BYT, YOUSSEF, b3e3, Bogdon
70775 Registered Users
63 registered members (2010Civic, bbhero, Blkstanger, bluesubie, BlakeB, 3 invisible), 1,537 guests, and 19 spiders.
Topics301,767
Posts5,202,373
Members70,775
What lubes do brake manufacturers recommend? #4761221 05/18/18 04:03 PM
Studly Offline OP
I'm getting ready to do my first front brake job on my Camry. I've been studying up on what lubes I need and it seems there's no general consensus on what you need, other than a silicone lubricant, high-temp brake grease and brake cleaner. Many say to use anti seize or anti squeal lubes, and others say you don't need them.
Which brake lubes are essential and which are specified by manufacturers of brake parts? Or which does AllData say you should use in their repair guide?
And what's the best value on all these essential lubes? It seems 3M stuff is quite spendy, while Permatex and CRC are much more reasonable.
Any advice would be appreciated!
Re: What lubes do brake manufacturers recommend? [Re: Studly] #4761231 05/18/18 04:17 PM
L
Leo99 Offline
L
I use this stuff. Not saying it's the best but it's all I use. $7.50 at AAP.
Without data you're just another person with an opinion. W. E. Deming
2003 Corolla 250,000 miles (RIP)
2004 Corolla 125,000 miles
2004 Rav4 392,000 miles
2015 Camry 90,000 miles
Re: What lubes do brake manufacturers recommend? [Re: Studly] #4761232 05/18/18 04:18 PM
A
artificialist Offline
A
I just use the CRC black paste with the paintbrush and I never have a problem. Whenever I encounter a brake part set with lube, it is often a heavy moly grease, so it is similar to CRC. However, I have also encountered a few ceramic based lubes.
They changed the style of the package, but the contents are the same:
http://www.crcindustries.com/products/brake-caliper-synthetic-grease-12-wt-oz-05353.html
2010 Lancer Ralliart Sportback
Re: What lubes do brake manufacturers recommend? [Re: Studly] #4761238 05/18/18 04:21 PM
M
maxdustington Offline
M
I have the Canadian equivalent of Syl-Glyde and if I could do it over I would get the 3M. Higher silicone content, and I want to lube my slide pins with silicone, not fillers.
Copper anti-seize for the pad ears, my neighbors Sante Fe came like that from the factory. Trav suggested that red anti-squeal goop but I am not a pro mechanic.
This has been discussed....too many times. Sticky time!
99 Toyota Tercel CE 5EFE/C151
Re: What lubes do brake manufacturers recommend? [Re: Studly] #4761271 05/18/18 04:53 PM
M
mcwilly Offline
M
Just curious where this lube is used?
I've replaced a couple pads and rotors in my time. Was I supposed to lube something up?
2016 Mazda CX3 48,000km
2010 Subaru Sti 77,000km
2007 Buick Rendezvous 105,000km
2001 Toyota Echo 262,000km
Re: What lubes do brake manufacturers recommend? [Re: Studly] #4761276 05/18/18 05:01 PM
slacktide_bitog Offline
welcome
Most pads come with a packet of whatever you need. The exception is Akebono, which is kinda stingy with the brake grease. Akebono is the only time I felt like I didn't have enough grease to do the brake job.
The brake lube I bought is a tuber of Permatex Ultra caliper lube. It's green.
Re: What lubes do brake manufacturers recommend? [Re: mcwilly] #4761290 05/18/18 05:20 PM
M
M
Silicone lube on the caliper slide pins and anti-seize on the pad ears. Also clean the hub surface with a roloc or wire brush and possibly apply a thin layer of anti-seize (graphite based is fine) to the hub surface.
Re: What lubes do brake manufacturers recommend? [Re: Studly] #4761305 05/18/18 05:39 PM
E
EdwardC Offline
E
I'd suggest just getting the pure silicone grease. It's spendy, but if you're like me, you'll end up buying the real stuff after buying a bunch of other cheaper stuff. I hadn't touched my brakes for almost 2 years, the slide pins came out nice and greasy when I pulled them out. I also agree with putting on a thin smear of anti seize on the wheel/rotor surface and around the hub center while you have the wheel off. If you want to get ambitious, pull off the rotor and spread some anti seize between the rotor and hub as well.
I used silicone grease on the pins, copper anti seize on the pad ears (and wheel/rotor/hub surfaces), and a leftover Permatex caliper grease on the pad backs (the ceramic purple, to be exact).
Re: What lubes do brake manufacturers recommend? [Re: Studly] #4761318 05/18/18 05:51 PM
FowVay Offline
Here are the products offered from Textar, one of the largest brake manufacturers in the world:
The yellow tube Cera TEC is for lubricating all areas that don't contain rubber. The black tube of Hydra TEC is for the slide pins and any area that has rubber (piston dust boot area as example). I use the Cera TEC but use Sil-Glyde for my slide pins due to availability.
Re: What lubes do brake manufacturers recommend? [Re: Studly] #4761340 05/18/18 06:13 PM
J
JC1 Offline
J
I used that CRC black stuff also.
2015 Grand Caravan SXT Plus 0w-20 Pennzoil Ultra/Fram Ultra Filter
1997 Honda Civic CX 5w-30 PPPP/Fram Ultra Filter
Re: What lubes do brake manufacturers recommend? [Re: Studly] #4761378 05/18/18 06:58 PM
T
Thax Online Content
Online Content
T
Often overlooked part of a brake job is cleaning the rust off of the caliper. Im talking about where the hardware attaches to the caliper. Always best to remove the rust to the bare metal , then apply hi temp grease. The pads will fit better , wont stick in the caliper ears etc.
2000 Ford Explorer Limited 5.0L AWD
2018 KIA Soul EX 2.0L
ASE P2 Parts Specialist
AIA Import Part Specialist
KIA certified Senior Technician, Hybrid certified.
Re: What lubes do brake manufacturers recommend? [Re: Studly] #4761473 05/18/18 09:08 PM
cos Offline
+1 for Sil-Glyde. Works well on back of the pads, ears and slide pins. I's also easy to clean off your hands and tools.
'15 Cadillac SRX
- Castrol Magnatec 5W30
- Valvoline Maxlife ATF
Re: What lubes do brake manufacturers recommend? [Re: Studly] #4761533 05/18/18 11:59 PM
N
nthach Offline
N
Toyota red rubber grease for sliding pins on Toyotas(duh) or Subarus, or Dow 111 for everything else. On the pad ears and hardware, Molykote M77 or the discontinued Permatex Ultra Brake Lube high-temp silicone formula.
Re: What lubes do brake manufacturers recommend? [Re: Studly] #4761782 05/19/18 08:01 AM
Studly Offline OP
Thanks for the recommendations, everyone! So it looks like most of you don't use a separate anti-seize lube.
Re: What lubes do brake manufacturers recommend? [Re: Studly] #4761920 05/19/18 11:02 AM
Yah-Tah-Hey Offline
DO NOT use any of the various colored Permatex goops because they will swell the lower pin bushing which is an elastomer of some kind. Use Sil-Glyde or one of the silicone brake greases like 3M. Stay away from that red,green,purple or any other colored goop.
